I was trying to install pipewire but it seems like while trying to install pipewire-pulse it gives me this error message (I’m just going to copy paste what the console says as I don’t know how to make it look pretty in this format)
[vicente@vicentes-death-machine ~]$ sudo pacman -S pipewire-pulse
[sudo] password for vicente:
resolving dependencies…
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y
:: pipewire-pulse and pulseaudio-bluetooth are in conflict. Remove pulseaudio-bluetooth? [y/N] y
:: removing pulseaudio breaks dependency ‘pulseaudio=14.2-3’ required by pulseaudio-equalizer
:: removing pulseaudio breaks dependency ‘pulseaudio=14.2-3’ required by pulseaudio-jack
:: removing pulseaudio breaks dependency ‘pulseaudio=14.2-3’ required by pulseaudio-lirc
:: removing pulseaudio breaks dependency ‘pulseaudio=14.2-3’ required by pulseaudio-rtp
:: removing pulseaudio breaks dependency ‘pulseaudio=14.2-3’ required by pulseaudio-zeroconf
I don’t know what I’m suppose to do with this info as I recently changed to linux and I searched for my problem in other forums and there doesn’t seem to be any troubleshooting for this.
When it asked me to remove pulseaudio and pulseaudio-bluetooth I tried by putting yes yes and no no but it gave me the same error message in case someone tells me to try that.
Just one question: According to Pamac, Pipewire (KDE here) is already installed. When and how will that replace PulseAudio then? Will this happen sometime by an update by itself? Reading about the problems people are having with Pipewire so far, I think I’ll wait for that time.
Just in case if other noobs see that by using “pactl info” (to see the current sound server) and it says PulseAudio instead of PulseAudio (on PipeWire 0.3.26), you need to restart your computer.
