Hello,
I am using Manjaro OS, but Pihole recorded many requests from ArchLinux Domain.
Each request every 5 minutes! I did not open Arch linux website and pacman.
What are these requests from Archlinux? Why?
Sorry for my bad English
Hello,
Since we use a lot of Archlinux packages, some might phone home upstream. We have to see which of those are doing this.
When I blacklisted Archlinux.org, I see the “No Connection” icon in the taskbar. Even so, the internet works fine.
Is that related to the network?
Yes. That’s some kind of “do i have internet access” check. Maybe in networkmanager or so.
it apperently just checks the connection. It’s located in /usr/lib/NetworkManager/conf.d/20-connectivity.conf
Checking connectivity
NetworkManager can try to reach a page on Internet when connecting to a network. networkmanager is configured by default in
to check connectivity to archlinux.org. To use a different webserver or disable connectivity checking create/etc/NetworkManager/conf.d/20-connectivity.conf
, see NetworkManager.conf(5) § CONNECTIVITY SECTION.
https://wiki.archlinux.org/index.php/NetworkManager#Checking_connectivity
Don’t.
No, this isn’t even close.
Then the title might ask: Why is Manjaro phoning home all the time ...
We have to see about that.
Well, we have to see about a service if we want to change that URL. At least Archlinux does no access logging for that url …
And, make public statements attesting to that fact.
That would probably raise even more questions
Ok. we-do-not-log-anything-you-can-verify-with-wireshark.manjaro.org .
Yeah and who can asure that what’s in their git is really running on their servers? (Not that I doubt it though)
Will trust that way before something buried on page 175 of a 900 page EULA.
But, I want to know who is going to go on twitter or reddit and start screaming that Arch is collecting telemetry data.
Well, this is the code for pinging home:
If you check the defacto Gnome Upstream Distro Fedora, they install it separately:
So we might need to see if the check is needed after all to get a working connection going.
Also upstream is rethinking about that fact:
You can also read up on this topic here:
This is already known for many years:
FYI: Wireshark cannot prove there is no logging of connection details on their servers. One could only inspect network traffic.
Yeah true. They’d have your IP Address for sure. But at least you can still see what else goes over the line as you say.
