Phavo Gnome Clean Install Fails
AMD Ryzen 5, NVidia Geforce 1650
I run the live install with open source drivers, and try a clean install, but I get the below error. Not new to Linux, but new to Manjaro. What other information would be helpful on troubleshooting this?
Boost.Python error in job "unpackfs".
Command '['unsquashfs', '-l', '/run/miso/bootmnt/manjaro/x86_64/desktopfs.sfs']' returned non-zero exit status 1.
I’m typing this post from my other PC, but imagemagick is mentioned as part of the rest of the error message.
b'squashfs-root\nsquashfs-root/.manjaro-tools\nsquashfs-root/boot\nsquashfs-root/desktopfs-pkgs.txt\nsquashfs-root/etc\nsquashfs-root/etc/.gnome40new\nsquashfs-root/etc/.pwd.lock\nsquashfs-root/etc/ImageMagick-7\nsquashfs-root/etc/ImageMagick-7/colors.xml\nsqu
File "/usr/lib/python3.9/subprocess.py", line 528, in run
raise CalledProcessError(retcode, process.args,
Any thoughts on why this is failing? I should mention that a clean install of XFCE works just fine.
Hi there, Welcome to the forum! :wave:
That statement is not in question. :+1:
However, in order to get proper assistance from our community, we recommend that you provide information from your system as per below:
Also, I’ve noticed you reported another issue on an existing thread. See below.
Please note that bumping threads is discouraged. See the guidelines under the section "How to Post" on the forum rules
Thanks. Have fun!
Apologies for the bump. I can open a separate thread when needed on that one. For now just trying to get a good install on Gnome.
From the live boot:
  Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  misobasedir=manjaro misolabel=MANJARO_GNOME_2111 quiet systemd.show_status=1
  driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
  serial: <filter> UEFI: American Megatrends v: A.A0 date: 09/07/2020
  RAM: total: 31.27 GiB used: 1.68 GiB (5.4%)
  Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
  family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
  L2: 3 MiB bogomips: 86438
  Speed: 3599 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 3599 2: 2054 3: 2202 4: 2197 5: 2056 6: 2200 7: 2200 8: 2197 9: 3599
  10: 2054 11: 2054 12: 2200
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
  mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
  nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
  pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
  pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
  skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
  succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  conditional, RSB filling
  Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Micro-Star MSI
  driver: nouveau v: kernel bus-ID: 2d:00.0 chip-ID: 10de:1f82 class-ID: 0300
  Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: nouveau note: n/a (using device driver) - try sudo/root
  display-ID: 0 resolution: <missing: xdpyinfo>
  OpenGL: renderer: NV167 v: 4.3 Mesa 21.2.1 direct render: Yes
  Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
  bus-ID: 2d:00.1 chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: no
  vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel port: d000
  bus-ID: 27:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.03 TiB used: 0 KiB (0.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT525MX300SSD1
  size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: R031 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
  size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 2B6Q
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3320813AS
  size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: CC6H scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 type: USB model: Mass Storage Device
  size: 29.72 GiB block-size: physical: 512 B logical: 512 B type: N/A
  serial: <filter> rev: 1.00 scheme: MBR
  Message: No partition data found.
  ID-1: /dev/sda1 maj-min: 8:1 size: 1024 MiB fs: vfat label: NO_LABEL
  uuid: C5A8-AB71
  ID-2: /dev/sda2 maj-min: 8:2 size: 64 GiB fs: btrfs label: N/A
  uuid: 2d881620-b25d-4eaa-b102-f0915e888acd
  ID-3: /dev/sdd1 maj-min: 8:49 size: 2.9 GiB fs: iso9660
  ID-4: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: 0EB2-6D2B
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
  Device-1: 3-3:2 info: Super Top microSD card reader (SY-T18)
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 14cd:1212 class-ID: 0806
  serial: <filter>
  Device-2: 3-4:3 info: OpenMoko Ultimate Hacking Keyboard
  type: HID,Keyboard,Mouse driver: hid-generic,usbhid interfaces: 5 rev: 2.0
  speed: 12 Mb/s power: 150mA chip-ID: 1d50:6122 class-ID: 0301
  Device-3: 3-5:4 info: Micro Star MYSTIC LIGHT type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 500mA chip-ID: 1462:7c37 class-ID: 0300 serial: <filter>
  Hub-4: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 3-6.2:6 info: Corsair CORSAIR Lighting Node CORE type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 50mA
  chip-ID: 1b1c:0c1a class-ID: 0300 serial: <filter>
  Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Hub-7: 5-2:2 info: Realtek 4-Port USB 2.0 Hub ports: 5 rev: 2.1
  speed: 480 Mb/s chip-ID: 0bda:5423 class-ID: 0900
  Hub-8: 5-2.1:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 0bda:5411 class-ID: 0900
  Device-1: 5-2.1.2:5 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
  type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
  rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
  Device-2: 5-2.1.3:7 info: Microchip LUXAFOR FLAG type: HID
  driver: hid-led,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
  chip-ID: 04d8:f372 class-ID: 0300
  Device-3: 5-2.1.4:9 info: Realtek BillBoard Device type: Billboard
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip-ID: 0bda:5450
  class-ID: 1100 serial: <filter>
  Hub-9: 5-2.4:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  Device-1: 5-2.4.3:12 info: Elecom TrackBall Mouse M-DPT1MR Wired
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 056e:0131 class-ID: 0300
  Device-2: 5-2.4.4:13 info: Realtek BillBoard Device type: Billboard
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Hub-11: 6-1:2 info: Realtek 4-Port USB 3.0 Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 0bda:0423 class-ID: 0900
  System Temperatures: cpu: 48.1 C mobo: N/A gpu: nouveau temp: 32.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 0
  Processes: 309 Uptime: 2m wakeups: 0 Init: systemd v: 248 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1186 lib: 294 flatpak: 0 Shell: Zsh
  v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Not sure how much is relevant from dmesg, but there were a handful of these errors:
[   10.454749] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:2f:00.4/sound/card1/input21
[   10.534471] MCE: In-kernel MCE decoding enabled.
[   10.703958] usb 5-2.4.1: device descriptor read/64, error -110
[   10.813847] intel_rapl_common: Found RAPL domain package
[   10.813849] intel_rapl_common: Found RAPL domain core
Then this toward the bottom
[  475.162102] BTRFS info (device sda2): disk space caching is enabled
[  475.162105] BTRFS info (device sda2): has skinny extents
[  475.162106] BTRFS info (device sda2): flagging fs with big metadata feature
[  475.163910] BTRFS info (device sda2): enabling ssd optimizations
[  475.164089] BTRFS info (device sda2): checking UUID tree
[  475.219710] BTRFS info (device sda2): disk space caching is enabled
[  475.219714] BTRFS info (device sda2): has skinny extents
[  475.221546] BTRFS info (device sda2): enabling ssd optimizations
[  475.355657] BTRFS info (device dm-0): disk space caching is enabled
[  475.355660] BTRFS info (device dm-0): has skinny extents
[  475.355661] BTRFS info (device dm-0): flagging fs with big metadata feature
[  475.357525] BTRFS info (device dm-0): enabling ssd optimizations
[  475.357696] BTRFS info (device dm-0): checking UUID tree
[  510.086208] SQUASHFS error: zstd decompression error: 14
[  510.086213] SQUASHFS error: zstd decompression failed, data probably corrupt
[  510.086214] SQUASHFS error: Failed to read block 0x5af1bfb5: -5
[  510.086216] SQUASHFS error: Unable to read metadata cache entry [5af1bfb3]
[  510.086217] SQUASHFS error: Unable to read inode 0xf6201f06
[  510.086242] SQUASHFS error: Failed to read block 0x5af23e43: -5
[  510.086244] SQUASHFS error: Unable to read metadata cache entry [5af23e41]
[  510.086244] SQUASHFS error: Unable to read inode 0x174ae1572
[  510.086329] SQUASHFS error: Unable to read metadata cache entry [5af23e41]
[  510.086330] SQUASHFS error: Unable to read inode 0x174ae1a12
[  510.086355] SQUASHFS error: Unable to read metadata cache entry [5af23e41]
[  510.086357] SQUASHFS error: Unable to read inode 0x174ae1a5a
[  510.086364] SQUASHFS error: Unable to read metadata cache entry [5af23e41]
[  510.086365] SQUASHFS error: Unable to read inode 0x174ae1c1a
[  510.086465] SQUASHFS error: Failed to read block 0x5af27aae: -5
[  510.086466] SQUASHFS error: Unable to read metadata cache entry [5af27aac]
[  510.086467] SQUASHFS error: Unable to read inode 0x1b1191866
[  510.086490] SQUASHFS error: Failed to read block 0x5af2b7b8: -5
[  510.086491] SQUASHFS error: Unable to read metadata cache entry [5af2b7b6]
[  510.086492] SQUASHFS error: Unable to read inode 0x1ee23188b
[  510.086519] SQUASHFS error: Unable to read inode 0x2148f1f3f
[  510.088121] SQUASHFS error: Failed to read block 0x5af2ed67: -5
[  510.088123] SQUASHFS error: Unable to read metadata cache entry [5af2ed65]
[  510.088123] SQUASHFS error: Unable to read inode 0x223d2191f
[  510.088129] SQUASHFS error: Unable to read metadata cache entry [5af2ed65]
[  510.088130] SQUASHFS error: Unable to read inode 0x223d21a9c
[  510.088134] SQUASHFS error: Unable to read metadata cache entry [5af2ed65]
[  510.088135] SQUASHFS error: Unable to read inode 0x223d21c1c
[  510.088149] SQUASHFS error: Failed to read block 0x5af2f4c3: -5
[  510.088150] SQUASHFS error: Unable to read metadata cache entry [5af2f4c1]
[  510.088151] SQUASHFS error: Unable to read inode 0x22b2e013c
[  510.088945] SQUASHFS error: Unable to read metadata cache entry [5af2f4c1]
[  510.088947] SQUASHFS error: Unable to read inode 0x22b2e197c
[  731.292414] audit: type=1101 audit(1630461948.409:170): pid=6917 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  731.292496] audit: type=1110 audit(1630461948.409:171): pid=6917 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[  731.294495] audit: type=1105 audit(1630461948.412:172): pid=6917 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
What else might be helpful for troubleshooting?
:+1: Welcome to Manjaro! :+1:
  • Looks like a dodgy download: did you verify the SHA1 of your .iso?
  • Better take the proprietary ones as nouveau is good for older cards, but as nVidia doesn’t publish its source code, the Nouveau Team has to reverse-engineer everything so they’re playing catch-up all the time…
:crossed_fingers:
Checksum and GPG checked out for both full and minimal. I tried the full and the minimal installs as plain vanilla for partitioning as could be had. Ideally, I’d like to go with a partioned home directory, but to eliminate potential issues, I’m doing nothing manual. No swap either for these attempts.
Minimal installed just fine as of this morning. Although it still suffers from the same (and separate) GDM login issue mentioned earlier.
Just as a follow up to this. I couldn’t figure the issue out after a couple of days of troubleshooting. I just installed XFCE and moved on as this is my primary machine.
