Hi guys!
At first I though this behavior was limited to Firefox, but after this thread I’m thinking it’s a bit (perhaps a lot) more widespread.
I think the behavior, for me at least, started after the loast I might be wrong, but that’s what I think.
Any customisation I make in Firefox, page zoom etc., will not persist after Firefox restarts, making me suspect it’s not being saved. And after the thread I mentioned above, it would seem it’s not limited to Firefox, leading me to suspect the ~./config folder’s (or /home directory, ~/.* directory) permissions are out of whack. My directories’ permissioons are below:
`stat ~/.mozilla'
File: /home/mirdarthos/.mozilla
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: 10302h/66306d Inode: 5541378 Links: 7
Access: (0700/drwx------) Uid: ( 1000/mirdarthos) Gid: ( 1000/mirdarthos)
Access: 2020-09-14 14:11:44.907076903 +0200
Modify: 2020-11-13 13:09:47.566418928 +0200
Change: 2020-11-13 13:09:47.566418928 +0200
Birth: 2020-09-14 14:11:44.907076903 +0200
stat ~/.config
File: /home/mirdarthos/.config
Size: 12288 Blocks: 24 IO Block: 4096 directory
Device: 10302h/66306d Inode: 5242889 Links: 124
Access: (0755/drwxr-xr-x) Uid: ( 1000/mirdarthos) Gid: ( 1000/mirdarthos)
Access: 2020-09-14 13:02:35.581471217 +0200
Modify: 2021-05-12 08:40:24.123455104 +0200
Change: 2021-05-12 08:40:24.123455104 +0200
Birth: 2020-09-14 13:02:35.491471217 +0200
stat ~/
Device: 10302h/66306d Inode: 5242882 Links: 63
Modify: 2021-05-12 09:09:48.276468565 +0200
Change: 2021-05-12 09:09:48.276468565 +0200
And just for giggles, here is my inxi -Faaazy --no-host for you:
$ inxi -Faaazy --no-host
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=9a26c8d0-43f4-44ad-a7d3-861d6f6cdbfa rw quiet apparmor=1
security=apparmor resume=UUID=1b3f894f-5481-4241-ace5-c129a0cdb412
udev.log_priority=3
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A serial: N/A
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: N/A
UEFI: American Megatrends v: F5 date: 10/30/2017
Info: 6-Core model: Intel Core i7-8700 socket: LGA1151 (U3E1) note: check
bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: A (10) microcode: DE cache: L1: 384 KiB
L2: 12 MiB L3: 12 MiB
bogomips: 76799
Speed: 4299 MHz min/max: 800/4600 MHz base/boost: 4300/8300 volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 4299 2: 4299 3: 4301 4: 4301
5: 4299 6: 4299 7: 4300 8: 4299 9: 4295 10: 4300 11: 4300 12: 4301
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1080 s-dpi: 97 s-size: 1341x283mm (52.8x11.1")
s-diag: 1371mm (54")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
Monitor-2: DVI-D-0 res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.2") diag: 730mm (28.8")
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.18 running: no
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: f000 bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 8.41 TiB used: 2.76 TiB (32.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 3B7QCXE7 temp: 25.9 C
scheme: GPT
SMART: yes health: PASSED on: 120d 4h cycles: 1,406
read-units: 36,278,673 [18.5 TB] written-units: 23,168,811 [11.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST5000VX0011-1T317X
family: Surveillance size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: VN02 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 262d 8h cycles: 787
read: 52.69 TiB written: 12.78 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM000-1F2168
family: Desktop HDD.15 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5900 rpm serial: <filter>
rev: CC54 temp: 24 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 173d 22h cycles: 1719
read: 55.84 TiB written: 36.78 TiB Old-Age: UDMA CRC errors: 13567
alert: Bad cable/connection? Pre-Fail: end-to-end: 99 threshold: 99
alert: FAILING_NOW attribute: Spin_Retry_Count value: 100 worst: 100
threshold: 97
ID-1: / raw-size: 224.58 GiB size: 220.06 GiB (97.99%)
used: 96.01 GiB (43.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3
maj-min: 259:3
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nvidia temp: 26 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Processes: 331 Uptime: 42m wakeups: 0 Memory: 15.59 GiB
used: 4.54 GiB (29.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: 1783 apt: 0 pacman: 1757 lib: 464
flatpak: 26 Shell: Zsh (sudo) v: 5.8 running-in: yakuake inxi: 3.3.04 inxi -Faaazy --no-host
udev.log_priority=3
base: Arch Linux
bogomips: 76799
Type: l1tf
diag: 730mm (28.8")
direct render: Yes
class-ID: 0403
class-ID: 0403
scheme: GPT
threshold: 97
maj-min: 259:2
maj-min: 259:3
udev.log_priority=3
base: Arch Linux
bogomips: 76799
Type: l1tf
diag: 730mm (28.8")
direct render: Yes
class-ID: 0403
class-ID: 0403
scheme: GPT
threshold: 97
maj-min: 259:2
maj-min: 259:3
Any help to get this right would be much appreciated. I suspect it’s something small, however, I don’t know what it can be.
(Also, don’t worry about “failiing now” hard drive. There’s not data on it; it’s not being used. It’s ust not unpugged yet.)
