Hey everyone, so I have a bit of a persistent issue. I want to use Linux on my HP Spectre folio 13-ak0802, but it has a big issue.
The screen only seems to refresh around the cursor, and when I use the touchpad and lift my finger to adjust it leaves cursors I have to manually “move to” to refresh that area and remove them.
Its an issue on other distros as well.
The issue begins even on boot, at the login screen where I have to “clear” the screen with my cursor to remove the splash screen. It seems to clear the screen in horizontal lines spanning the display.
Same issue on gnome, kde, budgie and cinnamon so it doesnt seem to be DE related. Neither does it seem to wayland or xorg, as Ive tried both.
I know it works just fine when I use any 4.x kernel, the problem is only with 5.x kernel but Id obviously like to use that.
Its only on the native laptop screen, when I dock it to an external monitor it works just fine.
Only intel integrated graphics
It does have a touchscreen which may be relevant?
Example gif of the issue: imgur com/99V9lK6
**System**:
Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=f9ecb6a8-c8bf-4f64-ba87-3debc989b67e rw quiet splash apparmor=1
security=apparmor udev.log_priority=3 intel_idle.max_cstate=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Convertible System: HP product: HP Spectre Folio Convertible 13-ak0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: HP model: 8503 v: 14.54 serial: <filter> UEFI: Insyde v: F.40
date: 12/01/2020
ID-1: BAT1 charge: 47.2 Wh (92.0%) condition: 51.3/54.3 Wh (94.5%)
volts: 8.3 min: 7.7 model: COMPAL PABAS0241231 type: Li-ion serial: <filter>
status: Discharging
Device-1: hid-0018:04F3:284A.0001-battery model: ELAN2514:00 04F3:284A
serial: N/A charge: N/A status: N/A
RAM: total: 7.66 GiB used: 1.82 GiB (23.7%)
Info: Dual Core model: Intel Core i5-8200Y bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
microcode: DE cache: L2: 4 MiB bogomips: 12805
Speed: 500 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 500 2: 500 3: 508
4: 601
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d
fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 615 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:591c class-ID: 0300
Device-2: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-9:3 chip-ID: 04f2:b634 class-ID: 0e02 serial: <filter>
Display: wayland server: X .org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 615 (AML-KBL) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_soc_skl v: kernel alternate: snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0401
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3040
bus-ID: 6d:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-3:2 chip-ID: 8087:0a2b class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 476.94 GiB used: 9.94 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 rotation: SSD serial: <filter> rev: AAHA4102 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 9.94 GiB (2.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: f9ecb6a8-c8bf-4f64-ba87-3debc989b67e
label: NO_LABEL uuid: 09AB-7ED9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-9:3 info: Chicony HP Wide Vision FHD Camera type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 31.0 C mobo: 29.8 C
Processes: 220 Uptime: 4m wakeups: 403 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1156 lib: 292 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.04
xrandr
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 290mm x 170mm
1920x1080 59.96*+
Thanks for any help!
