Hi there, I managed to solve most of the journalctl errors. But I keep getting this strange error.
systemd-udevd[374]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Earlier I used to get this error occasionally and a reboot fixed it. But after the recent update, it pops up at every boot, and rebooting simply ain’t solving this!
Any Idea why I get this and is there anything I can do about it!?
**System details**
Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=10b8e11c-af3f-4c91-a5c9-2771d84a5bda rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP Laptop 15g-dr0xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84A7 v: 80.31 serial: <filter> UEFI: Insyde v: F.07
date: 11/21/2018
ID-1: BAT1 charge: 11.1 Wh condition: 34.7/41.9 Wh (83%) volts: 11.0/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Discharging
Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10) microcode: D6
L2 cache: 6144 KiB
bogomips: 28808
Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 450.57 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:174e
Device-3: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04f2:b65d serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.7.15-1-MANJARO
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 4000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8821ce v: N/A modules: 8821ce port: 3000
bus ID: 03:00.0 chip ID: 10ec:c821
Local Storage: total: 931.51 GiB used: 23.35 GiB (2.5%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010B7E610
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A03 scheme: GPT
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
ID-1: / raw size: 100.00 GiB size: 97.93 GiB (97.93%)
used: 23.29 GiB (23.8%) fs: ext4 dev: /dev/sda7
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: file size: 4.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 41.0 C mobo: 29.8 C
Processes: 235 Uptime: 25m Memory: 7.69 GiB used: 1.62 GiB (21.0%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1316 lib: 384
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
TIA!!!
