Hi,
I have an issue with pamac and AUR packages.
Every time that an AUR update is detected (I use pamac update -a), pamac tries to reinstall same version instead of updating to latest.
This happens with all packages. It all started apparently random some months ago. It used to work correctly for a long time, than for no reason I started facing this issue.
The only way to update to latest version is to remove my installed package, and rebuild it from scratch.
I tried to clean package cache and also build cache to no avail.
This is a log showing the last time it happened (today):
[user@host ~]$ pamac update
Preparing...
Authenticating as: Redacted (user)
Password:
Nothing to do.
[user@host ~]$ pamac update -a
Preparing...
Checking netstandard-targeting-pack-bin dependencies...
Checking openhab3 dependencies...
Checking dotnet-sdk-bin dependencies...
Checking aspnet-runtime-bin dependencies...
Checking dotnet-host-bin dependencies...
Checking dotnet-runtime-bin dependencies...
Checking dotnet-targeting-pack-bin dependencies...
Password:
Warning: dotnet-sdk-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Warning: aspnet-runtime-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Warning: netstandard-targeting-pack-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Warning: openhab3-3.1.0-2 is up to date -- reinstalling
Warning: dotnet-targeting-pack-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Warning: dotnet-runtime-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Warning: dotnet-host-bin-5.0.8.sdk302-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (7):
dotnet-host-bin 5.0.8.sdk302-1 AUR
dotnet-runtime-bin 5.0.8.sdk302-1 AUR
netstandard-targeting-pack-bin 5.0.8.sdk302-1 AUR
dotnet-targeting-pack-bin 5.0.8.sdk302-1 AUR
dotnet-sdk-bin 5.0.8.sdk302-1 AUR
aspnet-runtime-bin 5.0.8.sdk302-1 AUR
openhab3 3.1.0-2 AUR
I tried cleaning pamac cache but nothing changed:
[user@host ~]$ pamac clean -k 0
[user@host ~]$ pamac clean -b
Removing packages works:
[user@host ~]$ pamac remove dotnet-host-bin dotnet-runtime-bin netstandard-targeting-pack-bin dotnet-sdk-bin aspnet-runtime-bin openhab3
Preparing...
Checking dependencies...
To remove (7):
openhab3 3.1.0-2
dotnet-targeting-pack-bin 5.0.8.sdk302-1 (Depends On: netstandard-targeting-pack-bin)
Total removed size: 516.5 MB
[user@host ~]$ pamac build dotnet-host-bin dotnet-runtime-bin netstandard-targeting-pack-bin dotnet-sdk-bin aspnet-runtime-bin openhab3
Preparing...
Checking dotnet-host-preview dependencies...
To build (7):
dotnet-host-bin 5.0.9.sdk400-1 AUR
dotnet-runtime-bin 5.0.9.sdk400-1 AUR
netstandard-targeting-pack-bin 5.0.9.sdk400-1 AUR
dotnet-targeting-pack-bin 5.0.9.sdk400-1 AUR
dotnet-sdk-bin 5.0.9.sdk400-1 AUR
openhab3 3.1.0-3 AUR
aspnet-runtime-bin 5.0.9.sdk400-1 AUR
Can anyone help me what to do to fix this strange issue?
Thanks!
