Running latest stable. Just switched to Wayland.
Pamac seems to default to an ugly theme and has no font anti aliasing under Wayland. How can I fix this?
For one thing pamac is a GTK application …
yes, but it was happy using the Breeze theme under X
So you were/are using breeze-gtk ?
Might want to double-check your gtk theme.
Then again … I dont know what you are referring to as ‘ugly’ … breeze should be about the same as it ever was.
my system config hasn’t changed, I have breeze set under gnome/gtk application style.
I’m fairly sure Pamac is using Adwaita. Also, there is no anti-aliasing of fonts at all. Clearly it seems to be using some kind of default as it can’t find the proper config file under Wayland.
I know it’s an old topic, but I’m having the same issue.
Try it with GTK_USE_PORTAL=0 it worked for me
yes but that means any program uses Gnome open/save dialogs on KDE which is a bit ugly.
anyway, my solution was to go back to X. maybe Wayland next year!
You could set it just for pamac. But anyway I agree, wayland is not ready for daily usage yet, there’s no comparison with X11
