Using the “update tab” on pamac leads to the % of refreshing the packages from the mirrorlist. But rather than showing updates available after hitting the 100% mark, it crashes without any GUI error logs.
If I try running pamac-manager from the terminal and try the update again, it leads to the following stack trace: zsh: segmentation fault (core dumped) pamac-manager
❯ pacman --sync --refresh --upgrade
pamac upgrade
error: only one operation may be used at a time
Preparing...
Authenticating as: Sharan (sharan)
Password:
Refreshing chaotic-aur.db...
Nothing to do.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
