Pamac seems to be a bit broken
@Kobold
i did nothing special,regular updates on stock configuration.
i checked with pacman -Qi before removing orphans.
@nikgnomic
indeed,for some reason Skype didn’t/couldn’t update and was out of date.
i removed and reinstalled it.
let’s see if that fixes the issue.
skypeforlinux-stable-bin was shown in previous post without AUR as source
I need help figuring why some packages appear as installed from AUR
skypeforlinux
Outdated AUR package can be replaced with skypeforlinux-bin
sof-firmware is needed on Intel laptops for digital microphone array - sofproject.org
Package would be an orphan on a desktop system
Creative Labs AE-5 cards use snd_hda_intel driver
Pamac seems to be working as expected for both scenarios
i did just that.
But you found 4 unknown packages and skype is only one… that would be strange.
OP had 6 Foreign packages of unknown origin in screenshot posted 6 Oct 2024
yes,in an earlier post; six packages from packages moved to AUR and probably some leftovers,
and it seems they changed the name of the the Skype one and removed “stable” from it which prevented it from updating(i assume).
Changelog for skypeforlinux-bin on AUR shows initial release date of 2016
+ # Wed Jul 13 14:51:23 UTC 2016
+ pkgbase = skypeforlinux-bin
+ pkgdesc = Skype for Linux WebRTC Alpha
+ source = https://go.skype.com/skypeforlinux-64-alpha.deb
My pacman log shows I had this package installed in 2017, but it was replaced in 2018
Last update for skypeforlinux-stable-bin 8.109.0.209-1 was released Dec 2023
[2017-07-21 02:21] [ALPM] installed skypeforlinux-bin (5.4.0.1-1)
[2018-03-08 01:39] [ALPM] removed skypeforlinux-bin (8.13.76.8-1)
[2018-03-08 01:39] [ALPM] installed skypeforlinux-stable-bin (8.17.0.2-1)
[2023-12-05T14:12:14+0000] [ALPM] upgraded skypeforlinux-stable-bin (8.108.0.205-1 -> 8.109.0.209-1)
