linub
5 October 2024 10:42
1
inxi
Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=2c155c12-a203-4f76-83f3-c5a47e892804 rw
resume=UUID=906e149c-5c8b-4b11-91fd-041805a54c5a udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Mobo: ASUSTeK model: TUF GAMING Z790-PLUS WIFI D4 v: Rev 1.xx
UEFI: American Megatrends v: 0809 date: 01/06/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
microcode: 0x129
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 164088
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti GDDR6X] vendor: ASUSTeK
driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24c9 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: Unknown-1 mapped: DP-2 res: 2560x1440 dpi: 65024
size: 1x1mm (0.04x0.04") modes: 2560x1440
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 550.120 device-ID: 10de:24c9
surfaces: xcb,xlib
Device-1: Intel Raptor Lake High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:125c
class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 931.51 GiB used: 366.32 GiB (39.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QJXD7 temp: 41.9 C
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%)
used: 366.32 GiB (40.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB note: est. available: 31.09 GiB used: 4.46 GiB (14.4%)
Processes: 390 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1292 libs: 381 tools: pamac pm: flatpak pkgs: 0
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.32 running-in: konsole inxi: 3.3.36
Vmware and Skype i have no issue with,but why Pulseaudio-ctl
and spectre-meltdown-checker
are from AUR,were they removed from the repository?
are they a dependency for something?
and what about the others?how do i verify?
They were indeed dropped to the AUR because of compatibility issues and the fact that they have not been maintained anymore in a long time.
Possibly an optional dependency, but not a requirement.
They are not required.
Itβs quite possible that something you have installed from AUR has also installed some of these as dependencies.
I donβt know if there is an easy way (someone else might know) but you could always check them one by one:
pacman -Qs <packagename>
This might reveal enough information to trace them further.
Aragorn:
Related:
linub
5 October 2024 11:01
4
can i safely remove all of these:
pacman Qs + pacman Qi
pacman -Qs pulseaudio-ctl ξ² β
local/pulseaudio-ctl 1.70-2
Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
ο ξ° ο ~ ξ° pacman -Qi pulseaudio-ctl ξ² β
Version : 1.70-2
Description : Control pulseaudio volume from the shell or mapped to keyboard shortcuts.
Architecture : any
URL : https://github.com/graysky2/pulseaudio-ctl
Licenses : MIT
Groups : None
Provides : None
Depends On : bc libpulse pulse-native-provider
Optional Deps : libnotify: to display volume and mute status [installed]
Required By : None
Optional For : None
Conflicts With : pulseaudio_ctl
Replaces : pulseaudio_ctl
Installed Size : 14.90 KiB
Packager : Unknown Packager
Build Date : Sat 05 Oct 2024 13:18:06
Install Date : Sat 05 Oct 2024 13:18:08
Install Reason : Explicitly installed
Install Script : Yes
Validated By : None
ο ξ° ο ~ ξ° pacman -Qs kdelibs4support ξ² β
local/kdelibs4support 5.116.0-2 (kf5-aids)
Porting aid from KDELibs4
ο ξ° ο ~ ξ° pacman -Qi kdelibs4support ξ² β
Version : 5.116.0-2
Description : Porting aid from KDELibs4
Architecture : x86_64
URL : https://community.kde.org/Frameworks
Licenses : LGPL
Groups : kf5-aids
Provides : None
Depends On : kunitconversion5 kitemmodels5 kemoticons kparts5 perl
Optional Deps : None
Required By : khotkeys
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 18.02 MiB
Build Date : Sat 05 Oct 2024 13:16:45
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : None
ο ξ° ο ~ ξ° pacman -Qs khotkeys ξ² β
local/khotkeys 5.27.11-1 (plasma)
KHotKeys
ο ξ° ο ~ ξ° pacman -Qi khotkeys ξ² β
Version : 5.27.11-1
Description : KHotKeys
URL : https://kde.org/plasma-desktop/
Licenses : LGPL
Groups : plasma
Provides : None
Depends On : plasma-workspace kdelibs4support
Required By : None
Optional For : None
Replaces : None
Installed Size : 4.02 MiB
Packager : Philip Mueller <philm@manjaro.org>
Build Date : Fri 08 Mar 2024 05:24:14
Install Date : Thu 14 Mar 2024 16:01:03
Install Script : No
Validated By : Signature
ο ξ° ο ~ ξ° pacman -Qs manjaro-settings-manager-kcm ξ² β ξ² OVERTYPE
local/manjaro-settings-manager-kcm 0.5.7-21
Manjaro Linux System Settings Tool (KCM for Plasma 5)
ο ξ° ο ~ ξ° pacman -Qi manjaro-settings-manager-kcm ξ² β
Version : 0.5.7-21
Description : Manjaro Linux System Settings Tool (KCM for Plasma 5)
URL : https://gitlab.manjaro.org/applications/manjaro-settings-manager
Licenses : GPL
Groups : None
Provides : None
Depends On : kcmutils5 kconfigwidgets5 manjaro-settings-manager
Required By : None
Optional For : None
Replaces : kcm-msm
Installed Size : 5.57 MiB
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Sat 06 Jan 2024 20:15:19
Install Date : Sun 14 Jan 2024 17:01:20
Install Script : No
ο ξ° ο ~ ξ° pacman -Qs spectre-meltdown-checker ξ² β
local/spectre-meltdown-checker 0.46+26+gbd0c7c9-1
Zenbleed, ZombieLoad, RIDL, Fallout, Foreshadow, Spectre, Meltdown vulnerability/mitigation checker
ο ξ° ο ~ ξ° pacman -Qi spectre-meltdown-checker ξ² β
Version : 0.46+26+gbd0c7c9-1
Description : Zenbleed, ZombieLoad, RIDL, Fallout, Foreshadow, Spectre, Meltdown vulnerability/mitigation checker
Architecture : any
URL : https://github.com/speed47/spectre-meltdown-checker
Licenses : GPL-3.0-or-later
Groups : None
Provides : None
Depends On : sh sqlite
Required By : None
Optional For : None
Replaces : None
Installed Size : 287.95 KiB
Build Date : Sun 19 May 2024 05:13:01
Install Date : Sun 19 May 2024 18:16:54
Install Script : No
ο ξ° ο ~ ξ° pacman -Qs kemoticons ξ² β
local/kemoticons 5.116.0-2 (kf5)
Support for emoticons and emoticons themes
ο ξ° ο ~ ξ° pacman -Qi kemoticons ξ² β
Version : 5.116.0-2
Description : Support for emoticons and emoticons themes
Licenses : LGPL
Groups : kf5
Provides : None
Depends On : karchive5 kservice5
Required By : kdelibs4support
Optional For : None
Replaces : None
Installed Size : 2.48 MiB
Build Date : Sat 05 Oct 2024 13:16:19
Install Date : Sat 05 Oct 2024 13:16:45
Install Script : No
Validated By : None
ο ξ° ο ~ ξ° pacman -Qs manjaro-hotfixes ξ² β
local/manjaro-hotfixes 2024.1-2
Obsolete dummy package
ο ξ° ο ~ ξ° pacman -Qi manjaro-hotfixes ξ² β
Version : 2024.1-2
Description : Obsolete dummy package
Architecture : any
URL : None
Licenses : None
Groups : None
Provides : None
Depends On : None
Required By : None
Optional For : None
Replaces : None
Installed Size : 0.00 B
Build Date : Thu 18 Jan 2024 20:03:41
Install Date : Fri 19 Jan 2024 16:25:38
ο ξ° ο ~ ξ° pacman -Qs plasma-simplemenu ξ² β
local/plasma-simplemenu 1.0.12-1
Simplified menu for the plasma desktop
ο ξ° ο ~ ξ° pacman -Qi plasma-simplemenu ξ² β
Version : 1.0.12-1
Description : Simplified menu for the plasma desktop
Architecture : any
URL : https://github.com/KDE/plasma-simplemenu
Licenses : GPL-2.0
Groups : None
Provides : None
Depends On : None
Required By : None
Optional For : None
Replaces : None
Installed Size : 80.47 KiB
Packager : Bernhard Landauer <oberon@manjaro.org>
Build Date : Sat 11 Jan 2020 20:23:29
Install Date : Sun 03 Sep 2023 07:19:01
Install Script : No
ο ξ° ο ~ ξ° pacman -Qs systemd-kcm ξ² β
local/systemd-kcm 1.2.1-8
Systemd control module for KDE
ο ξ° ο ~ ξ° pacman -Qi systemd-kcm ξ² β
Version : 1.2.1-8
Description : Systemd control module for KDE
URL : https://github.com/rthomsen/kcmsystemd
Licenses : GPL
Groups : None
Provides : None
Depends On : kauth5 kconfigwidgets5 kcoreaddons5 ki18n5 kio5 kwidgetsaddons5 qt5-base systemsettings systemd-libs
Required By : None
Optional For : None
Replaces : None
Installed Size : 677.71 KiB
Build Date : Fri 06 Oct 2023 18:30:33
Install Date : Mon 06 Nov 2023 20:04:24
Install Script : No
does that mean i can remove them?
cscs
5 October 2024 11:04
5
Yes. Most should be explicitly avoided, and if you dont know/want any then they are all expendable.
Uninstall them all.
cscs
5 October 2024 11:08
7
Maybe follow up with an orphan check.
pacman -Qdtq
linub
5 October 2024 11:10
8
just did and removed quit a few.
pulseaudio-ctl from AUR was included in Manjaro ISOs before Manjaro switched to PipeWire.
I removed it from my systems a few years ago but my partnerβs system still uses it for the remote control to adjust audio level
Why does pipewire-pulse
no longer declare provides=(pulseaudio)
? Β· Issues Β· Arch Linux Β· GitLab
Jan Alexander Steffens (heftig) Β· 2 months ago
pipewire-pulse
really shouldnβt provide pulseaudio
, as itβs not 100% compatible. For example, pacmd
is missing and the CLI protocol that pacmd
depends on isnβt implemented, either.
There are a bunch of packages that continue depending on pulseaudio
because of this, and they were silently broken by pipewire-pulse
linub
6 October 2024 03:43
10
i remember a few updates ago in the announcement it was written:
" pulseaudio-ctl is not compatible with PipeWire and should be removed:"
but i still use pulseaudio.
anyhow,i already removed it and have working sound.
pulseaudio-ctl
was always incompatible with pipewire-pulse
because it uses pacmd
rather than pactl
commands. But it was not a conflicting package until recent changes to PipeWire dependencies
Was audio not working before you removed it?
linub
6 October 2024 12:41
12
it was working,but i assumed only persons using Pipewire should remove it.
system
Closed
9 October 2024 12:41
13
