Newest version appears to be completely messed up. Pamac update indicator warns me about updates that pacman and yay fail to pick up, clicking into either “installed” or “updates” also causes it to hang indefinitely.
hmmm disabling preferences>aur>check for updates seems to partly solve the issue. At least pamac is responding again.
While Pamac is capable of the role as AUR helper - remember that it is not the primary role.
Remember that AUR package builds is unsupported on Manjaro.
Please inform yourself of the reasons for the latest change in Pamac functionality.
I understand the recent incident has caused the dev team to disable aur letter-by-letter search, but I don’t see how this has anything to do with pamac hanging when aur updates are enabled. ![]()
It was hanging because it couldn’t connect to the aur as it was blocked. This shouldn’t happen now since the update so if its still happening then there’s another issue
The keyword here is AUR - please disable checking for AUR script changes.
The correct way of knowing when an AUR buildscript is updated is to subscribe to the get a notification when the script is updated.
I suggest you try running the update from the terminal using pacman - as this will give you more information - information you can provide as part of your issue.
sudo pacman -Syu
disabled aur script change checking.
output of sudo pacman -Syu is:
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: gnome-shell-extension-nightthemeswitcher: local (52-1) is newer than community (51-2)
warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
there is nothing to do
and for yay -Syu it is:
core is up to date
extra 1900.3 KiB 9.14 MiB/s 00:00 [######################] 100%
:: Searching databases for updates...
:: Searching AUR for updates...
-> gnome-shell-extension-nightthemeswitcher: local (52-1) is newer than community (51-2)
-> manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
-> cpu-x: local (4.2.0.r179.gadaba75-1) is newer than AUR (4.2.0-1)
-> libcpuid: local (0.5.1.r10.g7a580fd-1) is newer than AUR (0.5.1-1)
-> python2-decorator: local (4.4.2-3) is newer than AUR (4.4.2-1)
-> python2-gobject2: local (2.28.7-7) is newer than AUR (2.28.7-6)
-> python2-pickleshare: local (0.7.5-5) is newer than AUR (0.7.5-1)
-> Missing AUR Packages: gnome-getting-started-docs gnome-shell-extension-nightshellswitcher js60 lib32-libnm-glib libnm-glib libopenaptx linux-latest linux-latest-virtualbox-host-modules plank-theme-numix
-> Orphaned AUR Packages: deepin-wine-helper-full ipython2 python2-backports.shutil_get_terminal_size python2-pathlib python2-prompt_toolkit1 python2-traitlets
-> Flagged Out Of Date AUR Packages: pop-gtk-theme
I’m not spotting anything that might cause pamac to hang…maybe like @sawdoctor said this is another issue and looking into pamac logs might help?
Also my second Manjaro device is manifesting the same bug after updating pamac.
It is difficult to say - but yes there is something else in play.
It appears you are not using a default Manjaro system.
You have customized your system and then any attempt to troubleshoot is very difficult.
Maybe you are using deepin? which makes it harder as deepin has been notoriously difficult.
I’m on gnome. the deepin packages you see are related to deepin-wine, a fork of ordinary wine.
Are there any pamac logs I can look into? It appears this is not an isolated issue as two of my systems are showing the same problem.
Also this problem only started to pop up following the most recent pamac update. Maybe the culprit might be in something that was changed in the new version?
is a problem with only one aur package ? in pamac you can view where pamac “stop”
And you can also use yay “only for aur” : yay -Sua
It has nothing to do with any particular aur package. the problem is that searching for updates (with aur updates enabled) in pamac causes the app to load to 90% before hanging indefinitely. Pamac becomes unresponsive and often the only way to stop it is with taskkill. In fact this occurs even when pacman and yay tell me no updates are available.
From my side it appears that yay is operating normally, not sure if this is an issue with pamac or the aur.
I missed something:
how everybody decided that the user has latest pamac and libpamac versions
or
how the case was recognized/categorized/classified as version-independent.
Do you have any problems if you check for AUR updates with pamac in CLI ?
pamac update --aur
Okay I’ve noticed several interesting things.
Pamac CLI works with no problems:
Preparing...
Cloning nordic-polar-theme-git build files...
Generating nordic-polar-theme-git information...
Checking nordic-polar-theme-git dependencies...
Cloning adapta-gtk-theme-colorpack-joshaby-git build files...
Generating adapta-gtk-theme-colorpack-joshaby-git information...
Checking adapta-gtk-theme-colorpack-joshaby-git dependencies...
Checking google-chrome dependencies...
Cloning highway-git build files...
Generating highway-git information...
Checking highway-git dependencies...
Checking visual-studio-code-bin dependencies...
Warning: gnome-shell-extension-nightthemeswitcher: local (52-1) is newer than community (51-2)
Warning: manjaro-hello: local (0.6.7-2) is newer than extra (0.6.6-9)
Resolving dependencies...
Checking inter-conflicts...
To build (5):
adapta-gtk-theme-colorpack-joshaby-git 1.202101191000.r3.g942015c-1 (1.202101191000.r1.g54837dc-1) AUR
google-chrome 95.0.4638.54-1 (94.0.4606.81-1) AUR
highway-git 0.14.2.r48.gc90067e-1 (0.14.2.r42.g79126ad-1) AUR
nordic-polar-theme-git v1.9.0.r38.gdb4a671-1 (v1.9.0.r37.g24ef67c-1) AUR
visual-studio-code-bin 1.61.2-1 (1.61.1-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N]
These packages are also reflected in the pamac update indicator extension.
clicking into pamac to actually check the updates though causes it to hang at this screen:
yay, on the other hand, tells me I only have two updates instead of five:
core is up to date
extra is up to date
:: 2 Packages to upgrade.
2 aur/google-chrome 94.0.4606.81-1 -> 95.0.4638.54-1
1 aur/visual-studio-code-bin 1.61.1-1 -> 1.61.2-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
So now we have two problems: pamac gui stalling and yay disagreeing with pamac CLI. Coincidence?
EDIT: on my other device disabling dev package update checks in pamac gui causes pamac cli to report I have two aur updates, but disabling it causes it to report none.
Now I’m really confused…someone please help. ![]()
See
Pamac is re-downloading sources for each -git package when you search for updates. That can be terribly slow if you have many -git packages.
Do not use yay and pamac for -git package updates at the same time. yay has it’s internal database to store -git package metadata.
say that 50% of my aur packages were installed through pamac and 50% were through yay. How do I correctly update?
Github commit for pamac shows function of checking AUR for updates in pamac-manager GUI has been removed
https://gitlab.manjaro.org/applications/pamac/-/commit/125033f1da74b617c9ef3b74c8b26d4156ed7daa
But pamac CLI is working with no problems for me too, so there is a workaround for no GUI updates
I don’t use yay but it appears to be unable to see updates for *.git packages in AUR
EDIT for post#16: I would consider using either pamac or yay for 100% of AUR updates would be
better than using both
Not sure if this is a bug, but having aur settings still visible in pamac GUI and the app stalling when they are toggled sounds kind of…conflicting?
I use yay most of the time, but right now pamac cli is seeing more updates than yay and I’m not sure how to solve this without breaking things.
Wasn’t that only for the searching of packages? Updates should still work I’d assume.
I’d just use yay -Syu --devel for everything. That will check for repo/AUR + -git packlage updates.
If you want to stick to pamac GUI, you should disable the “check for development package updates”. But then you need to take care of the -git packages some other way, e.g. yay
I ran yay -Syu --devel and it told me I have a total of nine upgradeable packages (the five showed in pamac cli + four other *git packages I don’t remember updating in a long time).
