Hi,since some time I get an error message when I try update my AUR packages.
pamac update -a --force-refresh
Fehler: restricting filesystem access failed because landlock is not supported by the kernel!
The updates seem to work, but how do I get rid of this error? Do I need to disable the sandbox ( -disable-sandbox )?
FYI: I am on Kernel 6.13.7-1 but this happened before this kernel as well.
BG405
28 March 2025 18:18
2
I wonder if this thread with a similar issue is of any help?
Which other kernels have you tried?
Cheers!
A good question. Of course, I read the thread beforehand, but I didn’t find anything in it that I could relate to.
6.13 is the header I have installed. So I do not see any reason to install the linux66 version like mentioned in the linked thread
BG405
28 March 2025 20:03
4
This is from an older thread, however it is worth trying linux66
as it’s still currently maintained, being LTS.
Sorry I don’t know about possible issues with sandboxing as I have never used that. I wouldn’t rule it out as a possibility.
What I would say, though, is do the system updates using sudo pacman -Syu
first and, when complete, do the AUR package rebuilds/updates.
Olli
29 March 2025 13:06
5
you can enable landlock as kernel-parameter in the grub-config. it’s up to you to do this.
This is a configuration issue.
You have a system where the DownloadUser = alpm
tries to access a restricted folder.
You can add lsm=landlock,lockdown,yama,integrity,apparmor,bpf
to your cmdline as defined in /etc/default/grub
or you can uncomment the line #DisableSandbox
in /etc/pacman.conf
If you choose to add it to your kernel cmdline - you need to rebuild your init and grub config.
[SOLVED] pacman 7 - landlock is not supported by the kernel! / Pacman & Package Upgrade Issues / Arch Linux Forums
Pacman 7 added a sandbox for the downloaduser, read the current news item, or pass --disable-sandbox
or configure the DisableSandbox option if you really need to use a kernel without landlock.
Update NEWS for 7.0.0 release
@linux-aarhus
Thanks a lot
I added lsm=landlock,lockdown,yama,integrity,apparmor,bpf
to /etc/default/grub
and I worked!
system
Closed
2 April 2025 09:02
9
