Pacman error after 2024.10.10 Stable Update
I just got an update notification for the newer mesa-related packages, and I applied the update — as I always do — via pacman from within a tty. By consequence, I could not copy the error verbatim, but it was shown twice, and it said something about “unable to apply restricted filesystem access due to [something to do with a] landlock file” — whatever that means.
Whatever it is, it’s clearly something new, introduced by the new pacman version. It didn’t stop the packages from downloading and getting installed, though.
:man_shrugging:
pamac search -f landlock
shows landlock.h is owned by linux*-headers packages
and also 4 manpages:
/usr/share/man/man2/landlock_add_rule.2.gz is owned by man-pages
/usr/share/man/man2/landlock_create_ruleset.2.gz is owned by man-pages
/usr/share/man/man2/landlock_restrict_self.2.gz is owned by man-pages
/usr/share/man/man7/landlock.7.gz is owned by man-pages
landlock(7) — Arch manual pages
NAME
Landlock - unprivileged access-control
DESCRIPTION
Landlock is an access-control system that enables any processes to securely restrict themselves and their future children. Because Landlock is a stackable Linux Security Module (LSM), it makes it possible to create safe security sandboxes as new security layers in addition to the existing system-wide access- controls. This kind of sandbox is expected to help mitigate the security impact of bugs, and unexpected or malicious behaviors in applications.
a local repo ?
https://archlinux.org/news/manual-intervention-for-pacman-700-and-local-repositories-required/
No, I don’t have any local repos. But I do notice this — this was merged in from the .pacnew:point_down:
#DisableSandbox
I don’t think this was there before. Should I uncomment it?
[Testing Update] 2024-10-10 - Plasma 6.2, Gnome 47, Mesa, Firefox
Notable Package Updates
I have merged all three of those. That’s where this came from. I do not have any local repos.
After the 2024-10-02 Testing update (which brought pacman to 7.0.0), I received
error: restricting filesystem access failed because the landlock rule for the temporary download directory could not be added
As mentioned in the Unstable Update: September 2024 edition
moving from linux61 to linux66 removed the error for me.
Yes, that was the error I got too — thank you. :+1:
I am indeed on 6.1 LTS. Hmmm… :thinking:
I am on kernel 6.6 on stable, everything merged and i did not see the error. I tested installing 1-2 things and the mesa stuff because i was a little worried if the new system with restricted rights and the alpm user will function properly, but it seem to work both from pacman and pamac-gui.
ok message is with sandbox option. pacman Issues and Pulls :
:raised_hands: Takakage
Well, I don’t know whether this qualifies as a solution or as a workaround, but I’ve now upgraded to 6.6 LTS. So I guess that closes the case. :man_shrugging:
