XJia
28 February 2025 10:36
1
I’m just having this problem (Pamac worked a few days ago), and I found this topic
I tried the solutions suggested with:
sudo pacman -S pamac-gtk
or
sudo pacman -S pamac-gtk3
I tried both and found the gtk4 version doesn’t work but the gtk3 works.
gtk4 version launched from menu never works now, but run pamac-manager from a terminal sometimes works. But sometimes I got:
(pamac-manager:8054): Adwaita-WARNING **: 10:28:11.721: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
[1] 8054 segmentation fault (core dumped) pamac-manager
The gtk3 version works from the menu, and run from a terminal, it works but gives me an error:
(pamac-manager:8128): Gdk-CRITICAL **: 10:28:38.064: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
What does it mean? And how to get gtk4 to work?
Launching the GUI from commandline is a hit or miss.
I don’t know why - it could be dbus not answering in a timely manner when queried for pamac-daemon.
To use pamac commandline use
pamac <command>
Ben
28 February 2025 12:49
3
If it’s any consolation, it works perfectly for me
To be frank, though, I prefer using a web browser to search for software - then I find the terminal is just so much more noob friendly that I just do that.
So try this:
sudo pacman-mirrors --continent && sudo pacman -Syu
Feel free to follow it up with AUR/flatpak
pamac update && flatpak update
Then have another go at launching the GUI.
XJia:
I get a similar error on Xfce with pamac-gtk3, but it works normally
$ pamac-manager
(pamac-manager:540049): Gdk-CRITICAL **: 12:49:25.131: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
If I redirect standard terminal messages (stdout) to /dev/null/ I still see this message
$ pamac-manager 1>/dev/null
(pamac-manager:543951): Gdk-CRITICAL **: 13:11:33.115: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
But if I redirect error message (stderr) message is not displayed
pamac-manager 2>/dev/null
IMO this is a non-critical error since pamac-gtk3 works normally
XJia
28 February 2025 13:35
5
Thanks for the replies.
But what’s the deal with gtk4? Should I better gtk4 working?
pamac-gtk (Gtk4) is developed for Manjaro Gnome.
pamac-gtk3 was created in 2023 for GTK Desktops that did not have Gtk4 support (Xfce, Cinnamon, Mate etc)
For KDE, opinions are divided about which version is best
Best suggestion for pamac is to try both versions and see which works best on your system
Or use Octopi GUI package manager
