after upgrading to 6.9.0_1kernel (&plasma 6.0.4) i v made few small updates through pamac (though pamac looks glitchi now).
yesterdey saw lots of updates but pamac couldnot perform none becouse of some conflits.
tried in console
sudo pacman -Syu ✔ 16s
:: Sinkroniziram baze podataka paketa...
core je ažuriran
extra 8,3 MiB 34,7 MiB/s 00:00 [##############################] 100%
community je ažuriran
multilib je ažuriran
:: Započinjem punu nadogradnju sustava...
:: Zamjeni dbus-python sa extra/python-dbus? [D/n] d
rješavam zavisnosti...
tražim sukobljene pakete...
greška: greška pri pripremanju transakcije (ne mogu zadovoljiti zavisnosti)
:: instaliranje icu (75.1-1) slama zavisnost 'libicuuc.so=74-64' koju zahtjeva qt5-webkit
:: instaliranje icu (75.1-1) slama zavisnost 'libicui18n.so=74-64' koju zahtjeva qt5-webkit
inxi -Farz ✔
Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=0d364986-ebc2-409b-9f11-23bae7ccfe1f rw apparmor=1
bootsplash.bootfile=/bootsplash-themes/arch/bootsplash
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
wm: kwin_x11 tools: avail: xscreensaver vt: 2 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: Maximus II Formula v: Rev 1.xx
serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: 2302 date: 04/15/2010
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
status: discharging
Info: model: Intel Core2 Quad Q6600 bits: 64 type: MCP arch: Core2 Merom
level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
stepping: 0xB (11) microcode: 0xBA
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1603 min/max: 1603/2403 scaling: driver: acpi-cpufreq
governor: schedutil cores: 1: 1603 2: 1603 3: 1603 4: 1603 bogomips: 19209
Flags: ht lm nx pae sse sse2 sse3 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA GK107 [GeForce GTX 650] driver: nvidia v: 470.239.06
alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:0fc6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50")
s-diag: 600mm (23.62") monitors: <missing: xrandr>
Monitor-1: Unknown-1 size-res: N/A modes: 1280x1024
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.239.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 650/PCIe/SSE2
memory: 1000 MiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 650 driver: nvidia v: 470.239.06
device-ID: 10de:0fc6 surfaces: xcb,xlib
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b
class-ID: 0403
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.5 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK
driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c800
bus-ID: 03:00.0 chip-ID: 11ab:4364 class-ID: 0200
Device-2: Marvell 88E8056 PCI-E Gigabit Ethernet vendor: ASUSTeK
driver: sky2 v: 1.30 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d800
bus-ID: 04:00.0 chip-ID: 11ab:4364 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 1.58 TiB used: 130.89 GiB (8.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000AAKX-00ERMA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A02 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: R013 scheme: MBR
ID-1: / raw-size: 153.61 GiB size: 150.14 GiB (97.74%)
used: 130.89 GiB (87.2%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 58.0 C mobo: 49.0 C psu: 54.0 C
Fan Speeds (rpm): cpu: 1534 psu: 922
Power: 12v: 12.15 5v: N/A 3.3v: 3.20 vbat: N/A
Packages: pm: pacman pkgs: 1540 libs: 406 tools: octopi,pamac
1: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
3: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
4: https://mirrors2.manjaro.org/stable/$repo/$arch
5: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
7: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Memory: total: 8 GiB available: 7.76 GiB used: 2.14 GiB (27.6%)
Processes: 202 Power: uptime: 1h 51m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 3.09 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 255
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
