Linux pretty much guarantees the original version of the library stays available until the program exits. The update must do something very exotic for pamac to know about some of itâs libraries being overwritten while the program is open, and this should not happen with a program like this.
I have seen one valid special case where it was understandable the running program crashed due to running an upgrade, and it was systemd due to a very special case for that specific update.
Generally, if an upgrade crashes a running program itâs a serious bug that should be fixed, not worked around by pushing everyone to use CLI. Of course you can use CLI to minimize the chance you experiencing such a corner case. But it should not be necessary on the stable branch, as the rare cases should have been caught and fixed during unstable and testing.
what i am saying is basically if you run stable, then you should be able to use GUI update, unless the release notes say that there is a know issue and CLI is recommended.
It doesnât have to be exotic. All it takes is for an application to try and use a library that was not in use before and that was overwritten with a newer version, or for an application to make separate multi-threaded calls into the on-disk library, whereby one or several spawned-off threads are trying to access the library after it was already updated on disk.
This sort of thing happens more frequently than one would think, though.
Itâs not necessarily a bug. It all depends on the design of the running program. Anything relying on threaded execution can be affected by this.
Maybe, and maybe not. It is always possible for things to slip through unnoticed, or perhaps noticed but unreported.
In a perfect world, pamac would be free of bugs. But we do not live in a perfect world, and pamac has loads of open issues.
If you want a stable GUI front-end to the package manager, then use octopi. It uses pacmanâ the original and 99.99% bug-free package manager created by Arch Linux â in the background, along with an AUR helper.
pamac on the other hand was written from scratch, and even though it uses the ALPM database and package format, it does not use pacman itself. Instead, it was designed to handle repo packages, AUR packages, Snaps and FlatPaks all from within a single package manager, which makes it more into âa jack of all trades, but a master of noneâ.
My comment was a guess - not knowledge - a guess based on previous experience with other libraries, past experience with Windows libraries - a situation referred to dll-hell.
If the library is statically linked, there is no issue because the library will be attached to pamac binary itself.
But if it is dynamically linked, there is the risk of the library being replaced and therefore no longer available.
I have been in situations where I have updated my system - I usually look for a kernel update - that I know require restart - but if I forget - and that happens - I have had issues where I could not mount a file system.
After a restart - the file system mount as I expect; that kind of behaviour can only be attributed to expected libraries - dynamically linked - is no longer there - and that is why I suggested what you are referring to.
And yet, I think this isnât the cause of the crashes. As previously mentioned, the crash happened during an update that seemingly did not update lipalpm or any pacman/pamac-related package.
Also, it looks like it often (but not always) crashes during the download phase, before the backend even starts updating any package.
Or, rather, the update didnât complete due to the crash, and libalpm (and pacman and/or pamac related packages) failed as a result â a classic incomplete update scenario.
Donât put too much into it, the opinions et.al. - my use of pacman is habit - I started my Arch journey with Arch and I went several Arch based distribution until a landed with Manjaro back in 2016.
I do use pamac as well - I have also used pamac gui to run complex updates and never had any issues, so you will never see me actively discourage the use of Pamac.
I did some research once on why pamac was eating memory which ultimately lead to crashes on low-spec systems; this was reported to the developer and then I left the topic.
But because there is so many issues with updates, and because one go tired in the explaining of the same over and over, then again, the recommendation on how to update was born.
The recommendation is based on logic; what happens when you update; a restart is required when kernel and gpu drivers are updated.
The preparation guide is also logic based; based on the fact that custom packages are unsupported; based on complaints that a system update can be huge, the recommendation is to clean the system for unused packages and orphans.
The last time it crashed for me, the list of packages to-be-updated/being-updated did NOT include any pacman/pamac-related package.
Additionally, pamac crashed, but the updated continued happening in the background. I could observe on my network monitor that packages were still being downloaded, and aterwards I could observe high CPU and I/O activity by monitoring in htop. After several minutes, the update was completed, which I could confirm by reopening pamac and seeing it shows zero remaining updates. (Well, maybe not zero, because it would show up pending AUR updates.)
And these are the main problems:
Pamac crashes. It shouldnât. (But I understand this can be tricky to fix.)
It leaves the user with not feedback whatsoever that the update has continued in the background. I believe there should be at least some âsafety netâ fallback code that should trigger upon crashing, and that would provide bare-bones minimalistic feedback to the user until the update is finished.
Definitely not my case. 32GB of RAM, and I constantly look at the RAM usage in a KDE Plasma panel. Plenty of memory available, nothing that even remotely looks like OOM at all.
Donât assume that - pamac is quite reliable - but as anything where humans are involved - it is not perfect.
This happens very rarely - pacman/libalpm updates - so one cannot deduce that pamac is broken for system updates.
We can speculate and speculate and discuss the speculations
If I recall correct - I have been looking at Pamacâs vala codebase from time to time - the GUI is separate from the code that processes the packages.
When the GUI crashes but the process that handles the updates continues, it logically points to a situation where one or more libraries used by the GUI has been changed by the underlying process.
As I mentioned earlier - and as I am not the developer nor do I contribute to Pamac codebase so my comment on your question - should I create an issue about it still stands
but stable branch updates for 2025-05-04 and 2025-07-12 do not include any pamac packages to suggest that updating via pamac should be problematic
Issue was reported for both versions of pamac GUI and pamac CLI, but only a small number of users were affected and not much information to help maintainers
Users reported pamac-daemon continues to update packages in the background, so pamac-daemon.service would probably not show any errors that would help
Pamac GUI users can check if the update was completed in View History or check /var/log/pacman.log. Pacman log does not include messages to advise if a .pacnew file has been created, so users should also use pacdiff -o to check
All the libraries that have been loaded during program execution are safe and will not be updated for the runtime of the program. The previously mentioned case of newly loading a new library after version has been updated without the name reflecting it is the main issue case i guess.
But the main design of Linux memory management is that Linux tries to guarantee that in normal cases a running program will have the resources available to it for the duration of execution.
For this problem, one KDE system has been reported to have had sufficient resources available to update stable branch packages, but pamac-cli was unable to provide feedback to confirm all packages were updated.
libpamac, pamac-cli and pamac-gtk were last updated on stable branch 2025-12-22
I highly doubt there are human resources free to invest in maintaining 2 versions of the same thing for much longer, so i wisely switched to the gtk4 version, although i use xfce. There is no problem at all, except some theming issues which are fixable.
Both of us use pamac-manager (the gtk3 edition on KDE Plasma) for all our updates. My partner on her 2 in 1, running Stable, myself on my laptop running Testing, and on the media machine running Stable.
Nether of us has any issues. Not when doing a full upgrade or when doing smaller updates on AURs and Flatpaks, or the firefox security updates.
Two of the machines in question have 8 Gig of RAM, while the Starlite has 16 Gig.
The Manjaro developer team has already long been planning to drop it in favor of the gtk4 version. To be honest, Iâm surprised they havenât done so yet.
Mind you, I personally donât have a dog in that fight. I only use pamac-cli, and only so for AUR packages â I use pacman for anything from the repos.
