Pamac-cli and pamac-manager unreliable
TL;DR: Both pamac CLI and the pamac-manager GUI are unreliable for system upgrades. They are prone to crashing in the middle of an update, leaving the user with no feedback that the upgrade is continuing in the background.
Having previously tried to do a system update using the GUI, followed by the GUI crashing and the update continuing in the background, this time I tried the commandline:
$ pamac upgrade
Total download size: 1.4 GB
Total installed size: -1.1 GB
Apply transaction ? [y/N] y
Download of firefox (146.0.1-1) started
Download of firefox (146.0.1-1) finished
Download of rust (1:1.92.0-1) started
Download of linux612 (6.12.63-1) finished
Download of wine (10.20-2) started
Download of rust (1:1.92.0-1) finished
Download of linux612-headers (6.12.63-1) started
Download of blender (17:5.0.1-1) finished
Download of webkit2gtk-4.1 (2.50.4-1) started
809.4 MB/1.4 GB About 43 seconds remaining[1]    1202062 terminated  pamac upgrade
Then I tried again:
$ pamac upgrade
pamac: error while loading shared libraries: libalpm.so.15: cannot open shared object file: No such file or directory
I’m going to assume pamac is just a broken tool for system upgrades.
Minutes later, I tried pacman:
$ sudo pacman -Syu
:: Synchronising package databases...
 core is up to date
 extra is up to date
 multilib is up to date
 there is nothing to do
Hmm… Did the upgrade happen in the background? What has just happened? Let me try pamac again:
$ pamac upgrade
Refreshing AUR...
Nothing to do.
(plus a few extra AUR updates)
So, yeah, yet again pamac crashed, and the updated continued in the background with NO user feedback whatsoever.
Yes, I’ve seen occasional reports of something similar – as I recall, user systems were in an unsupported state at the time, for various reasons. I’ve never experienced it myself. However, search the forum and you might find a topic or three about it that might be helpful.
The suggested command is:
pamac update --no-aur
when performing a large update.
I was recently made aware of another option (topgrade) which you might find of interest. The script handles virtually everything including repo packages, software sourced via the AUR, flatpack containerised apps, and even homebrew (for Linux) if one happens to have it installed:
sudo pacman -S topgrade
It takes one simple command topgrade – sudo is not required as the script will prompt you for your password when elevated privileges are needed.
Your post has been moved to a dedicated topic.
Please provide your system information as described (below) along with any useful detail that might help others to help you.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
Running `inxi` within a `chroot` environment
Your privacy is respected
I think you are using unstable branch with pacman 7.1 which provides libalpm 16.
So I am thinking because you are running pamac to do the upgrade then pamac will upgrade itself then, the in memory version of pamac will look for libalpm 15 which has been removed and thus shut down unexpectedly.
This is the previous issue I had, half year ago: [Stable Update] 2025-05-19 - Firefox, Thunderbird, KDE Gear, KDE Frameworks - #56 by denilsonsa
I also found a few other posts of users talking about pamac crashing:
Well, that seems to be just a wrapper around common system tools across multiple distros. Specifically for Manjaro, it will call pamac upgrade. So, I’m sorry, but that seems like it won’t solve the issue. In fact, it sounds like it can suffer from the exact same issue.
I don’t remember ever switching to an unstable branch of anything. Looking at the pamac history, I see these relevant lines:
[2025-12-23T11:49:45+0100] [ALPM] upgraded pamac-gtk (11.7.4-1 -> 11.7.4-2)
[2025-12-23T11:49:45+0100] [ALPM] upgraded pamac-cli (11.7.4-1 -> 11.7.4-2)
[2025-12-23T11:49:45+0100] [ALPM] upgraded pacutils (0.15.0-1 -> 0.15.0-2)
[2025-12-23T11:49:45+0100] [ALPM] upgraded pacman-static (7.0.0.r6.gc685ae6-9 -> 7.1.0.r7.gb9f7d4a-1)
[2025-12-23T11:49:43+0100] [ALPM] upgraded pacman-contrib (1.13.0-1 -> 1.13.1-1)
[2025-12-23T11:49:35+0100] [ALPM] upgraded libpamac-flatpak-plugin (11.7.4-1 -> 11.7.4-4)
[2025-12-23T11:49:34+0100] [ALPM] upgraded libpamac (11.7.4-1 -> 11.7.4-4)
[2025-12-23T11:49:21+0100] [ALPM] upgraded pacman (7.0.0.r10.ga2d0293-3 -> 7.1.0.r7.gb9f7d4a-3)
[2025-12-23T11:49:20+0100] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2025-12-23T11:49:20+0100] [ALPM] warning: /etc/makepkg.conf.d/fortran.conf installed as /etc/makepkg.conf.d/fortran.conf.pacnew
[2025-12-23T11:49:20+0100] [ALPM] warning: /etc/makepkg.conf installed as /etc/makepkg.conf.pacnew
And the output of inxi -zv8, with several sections redacted for privacy and for brevity (as those sections are not relevant):
inxi -zv8
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=c2c41a52-2ae1-4701-a1c2-364264ddb6c0 rw quiet threadirqs
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Desktop System: HP product: HP EliteDesk 800 G2 DM 65W v: N/A
    serial: <superuser required> Chassis: type: 15 serial: <superuser required>
  Mobo: HP model: 8056 v: KBC Version 05.39 serial: <superuser required>
    part-nu: L2X86AV uuid: <superuser required> Firmware: UEFI vendor: HP
    v: N21 Ver. 02.61 date: 03/17/2023
  Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1718 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1718 2: 1718 3: 1718 4: 1718 5: 1718 6: 1718
    7: 1718 8: 1718 bogomips: 54417
    sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Local Storage: total: 238.47 GiB used: 165.62 GiB (69.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7LN256HMJP-000H1
    size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1H3Q temp: 25.0 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 165.62 GiB (71.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: c2c41a52-2ae1-4701-a1c2-364264ddb6c0
    used: 328 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 8D09-CB07
  ID-1: swap-1 type: file size: 512 MiB used: 504.4 MiB (98.5%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 36.0 C pch: 37.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 2849 pm: dpkg pkgs: 0 pm: pacman pkgs: 2786 libs: 443 tools: pamac
    pm: flatpak pkgs: 63
    1: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    5: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    6: https://manjaro.ynh.ovh/stable/$repo/$arch
    7: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
Processes:
  Processes: 340 Power: uptime: 13d 15h 22m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 28 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
Also stable and testing branch got updated to pacman 7.1 and therefore libalpm 0.16.
It wasn’t intended to solve an issue; it was intended as an alternative that might have been of interest. Yes, it’s a script, or a wrapper, if that’s what you prefer to call it.
If installed, it will use yay.
Good luck.
Sorry if I sounded rude, not my intention at all. topgrade sounds like a nice tool for people managing multiple distros.
Maybe pamac should be resilient to updating libalpm. Otherwise, it will crash on every system update that upgrades the pacman version. Should I create an issue about it on GitHub - manjaro/pamac: Graphical Package Manager for Manjaro Linux with Alpm, AUR, Appstream, Flatpak and Snap support ?
You may have a fundamental misunderstanding of the process, and in particular, the relationship between Arch and Manjaro branches.
TL/DR: Most packages comprising Manjaro are inherited from Arch Linux, who in turn receive those same packages from whosoever is the “upstream” developer/maintainer/organisation.
Manjaro cannot update any of these packages without it first being available from Arch Stable – from there, it must proceed to Manjaro Unstable, Manjaro Testing and finally Manjaro Stable.
Manjaro has to wait as often as you or I for most packages.
Looking at pacman as one example (which uses libalpm), you’ll notice the same version currently in all branches, including Arch Stable:
mbn info pacman -q
Branch         : archlinux
Version        : 7.1.0.r7.gb9f7d4a-1
Repository     : core
Build Date     : Fri 12 Dec 2025 23:33:39
Packager       : Antonio Rojas <arojas@archlinux.org>
Branch         : unstable
Version        : 7.1.0.r7.gb9f7d4a-3
Repository     : core
Build Date     : Thu 18 Dec 2025 13:44:08
Packager       : Philip Mueller <philm@manjaro.org>
Branch         : testing
Repository     : core
Branch         : stable
Repository     : core
As you can hopefully now appreciate, it’s not simply a case that “Manjaro should update a random-package”. :wink:
As far as the issue itself is concerned, I have every confidence that any problem will be identified and fixed in due course.
Until then consider using yay or another AUR helper.
sudo pacman -S yay
Have an enjoyable festive season.
My mistake - I didn’t know it was rolled out to all branches.
I don’t know how this can be handled, but making the developer aware that the update to pacman’s libalpm made pamac crash mid update - I agree.
An easy solution would be to not link to the *.so.xx but to the *.so file, however I didn’t saw any crashes on my end when an update was performed. Might only happen mid-update when some download error or something else happens and some parts got updated already …
If that’s the case, maybe pamac should be more conservative whenever pacman-related packages are going to be updated. MAYBE in such cases pamac should do a two-step process: first download everything, and then start the actual update.
Or maybe pamac should actually be executed as two processes:
  • The parent process wouldn’t depend on libalpm or anything else, and its sole purpose is to monitor the child process. Due to not depending on other libraries and due to simplified logic, this parent process shouldn’t crash at all. It should be resilient.
  • The child process would be the actual pamac that actually interacts with the packages.
Whenever an update starts, the parent process should observe if the child pamac crashes. If it does, for whatever reason, then the parent process should be able to recover from it, even if that means a partial recovery. After all, if pamac crashes, the upgrade already continues happening in background by some other process; thus the parent process should be able to fork a new child that would contact with that background process.
In the worst case, the new child process could be equivalent to tail -f on whatever the pacman/pamac daemon is doing. This would be a partial recovery. The user would still be able to see some feedback, even though the user wouldn’t be able to interact/stop it at all. (If this was a GUI, this partial recovery would be a minimalist dialog that outputs the results of the logs, but without the normal pamac-manager buttons and widgets.)
As a developer myself, I know this is easier said than done. It’s not unfeasible, but requires some work to get it implemented correctly. Additionally, I understand it’s difficult to fix something that cannot be easily reproduced.
Anecdotal:-
As mentioned, this isn’t the first time I’ve seen similar issues mentioned in the forum, where the update would seem to freeze or stall in the GUI, but complete in the background, regardless.
For a long while the general recommendation when using pamac was to maintain separation between software sources;
Effectively, a two step process:
1. Update packages from the Manjaro repo(s):
  • pamac update --no-aur
2. Build/update software sourced via the AUR:
  • pamac update --aur
It seems pamac was changed sometime earlier this year to handle that separation internally. Whether it was believed that not having that separation contributed in some way to the issue at hand, I can’t say, but if so, those changes haven’t helped.
Please make the upgrade process a two step process: First upgrade repo packages only, then upgrade AUR packages #488
Photon89 opened on Feb 23
Mar 1 - fixed in manjaro/libpamac@c629d1d
If I recall correct, pamac was alleged to be less reliable than another AUR helper that had a 2 stage process, and that it was possible to have an AUR package replace a repository package
I think that may have been the case with pamac in the past, but if so, then that situation was remedied quite a while ago already.
Either way, pamac will prioritize and update the repo packages first, and will only update the AUR packages after that, just as yay does.
Once again, pamac GUI crashed and disappeared while the update continued running in background. This happened while the updates were still being downloaded. As a workaround, I had to open htop and keep monitoring the CPU usage to have a feeling of when the update was completed.
This time, AFAIK, neither libalpm nor any pacman/pamac-related package was updated.
Could this potentially happen because I had uninstalled packagekit and packagekit-qt5 and packagekitd years ago?
I took note that multiple times in 2022 and 2023 it was using between 5% and 12% of my 32GB RAM. That’s a lot of memory to be eaten for something that is only needed a few times per week. The Arch Wiki recommends against it anyway, and someone else also had similar trouble with packagekit.
System is using GTK4 version of pamac GUI
I suggest install pamac-gtk3 to replace this package
https://download.manjaro.org/kde/26.0.1/manjaro-kde-26.0.1-260114-linux618.iso.pkgs
pamac-gtk3 10.7.0-1
Unlikely since these packages have not been included in Manjaro Live ISOs since Manjaro 24.1 Xahea released October 2024
No, pamac does not use packagekit.
If you don’t use any Snaps or FlatPaks, then, given that you are on Plasma, I recommend using octopi as a graphical package manager. It acts as a direct GUI front-end to pacman and to an AUR helper — we recommend installing yay for that. :backhand_index_pointing_down:
It also comes with its own notifier icon for the system tray.
sudo pacman -S octopi yay
You’ll need to configure it a bit though, because it doesn’t know which AUR helper you want it to use.
Why? I’m curious to know why we should prefer one over another.
Also worth noting that pamac-cli crashed (on the message from 24 days ago). So it wasn’t related to GTK3 or GTK4. (But yesterday I used the GTK4 GUI and it also crashed.)
So far I’ve only faced this kind of issue after a new stable update, when updating the whole system. So I can only “reproduce” it a few times per year. If someone tells me what are the extra steps I can do so I can get some kind of stacktrace to help pinpoint the source of this bug… Please tell me!
True, but pamac-gtk3 is scheduled to be dropped in favor of pamac-gtk.
(Don’t ask me when, though. :man_shrugging:)
Anyway, my recommendation to use octopi still stands. It’s a more than viable alternative to pamac-gtk{,3}, and especially so if you’re using Plasma, because it’s qt6-based.
The only downside — as I said already — is if you want to use Snaps or FlatPaks, because octopi doesn’t cover those. Personally I have no need for Snaps or FlatPaks, but many people here do. :man_shrugging:
Nobody should use snaps and for flatpak there are other tools (flatseal, warehouse, flathub.org, flatpak update from terminal).
So this is ok.
