Hi, English is not my main language so sorry for any mistakes, I tried to search about it here but I couldn’t find anything similar
Today I installed Manjaro KDE on my laptop (already used this version once) and for some reason Add/Remove Software aka Pamac firstly didn’t want to finish to update/download the software and I couldn’t close the program, so I restarted Manjaro, and I tried again: When I click to apply the updates on Add/Remove software it gets stuck for hours on “Checking Inter-conflicts”, and when it happens the close button also freezes
That’s my info:
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=54d4aa2c-b1e5-4333-9169-64a9b7586e5c rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: SAMSUNG product: 300E5K/300E5Q v: P03RDQ
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: SAMSUNG model: NP300E5K-KF1BR v: SGL8732A0Z-C01-G001-S0001+10.0.10586
serial: <filter> UEFI: American Megatrends v: P03RDQ.035.170807.JJ
date: 08/07/2017
ID-1: BAT1 charge: 29.6 Wh (100.0%) condition: 29.6/43.1 Wh (68.8%)
volts: 12.5 min: 11.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: Full cycles: 1139
RAM: total: 11.6 GiB used: 2.36 GiB (20.4%)
Info: Dual Core model: Intel Core i3-5005U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache:
L2: 3 MiB bogomips: 15971
Speed: 1943 MHz min/max: 500/2000 MHz Core speeds (MHz): 1: 1943 2: 1995
3: 1912 4: 1995
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx
avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d
fma fpu fsgsbase fxsr ht ibpb ibrs intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 5500 vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: Silicon Motion Web Camera type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 2232:1080 class-ID: 0e02 serial: <filter>
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Samsung Co driver: ath9k v: kernel port: f040 bus-ID: 01:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Samsung Co
driver: r8169 v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-4:5 chip-ID: 0cf3:3004 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 223.57 GiB used: 29.79 GiB (13.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hikvision model: HS-SSD-C100 240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2 scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 29.79 GiB (13.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 54d4aa2c-b1e5-4333-9169-64a9b7586e5c
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 04A1-B3E3
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
Device-1: 1-1:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-4:5 info: Qualcomm Atheros AR3012 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-3: 1-5:4 info: Silicon Motion Web Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2232:1080
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 52.0 C mobo: 52.0 C
Processes: 198 Uptime: 1h 25m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: N/A Packages: 1207 pacman: 1198 lib: 331
flatpak: 0 snap: 9 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
I would really appreciate any help because I really don’t want to re-install Manjaro all over again, My internet connection is fine, I’m not much of a terminal command kind of person so If there’s anything I would have to do there please pass me the full command so I can copy-paste if necessary, thanks
