Pacman package *corrupted
i have 200 packages that need updates i do pacman -Syu then says i have corrupted package so i do y to delete and it fails
This is usually the case when you’re trying to update from a mirror that hasn’t fully synced yet. Refresh your mirrors and try again. :arrow_down:
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
why can’t i share a link with a photo of my terminal error
error: amd-ucode: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/amd-ucode-20221109.60310c2-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
why i do Y to all it fails
Do you want to delete it? [Y/n] y
error: apparmor: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/apparmor-3.1.2-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd-libs: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-libs-251.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pacman: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pacman-6.0.2-5-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-251.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: lib32-systemd: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/lib32-systemd-251.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpackagekit-glib: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpackagekit-glib-1.2.5-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: libpamac: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/libpamac-11.4.1-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware-whence: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-whence-20221109.60310c2-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux-firmware: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux-firmware-20221109.60310c2-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: linux515: signature from "Manjaro Build Server <build@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/linux515-5.15.78-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-release: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-release-22.0.0rc-1-any.pkg.tar.xz is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-0.5.7-12-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
First of all, photos of terminal output are useless, because we cannot copy/paste from them. Use three backticks (```) on a new line instead, mark the output with the mouse and paste it below that line, and then add another line with three backticks.
As for why you cannot include links or screenshots, this is a security precaution with new members. Your privileges will grow as you become a regular member. See… :arrow_down:
okay i understand. Heyy did you see the code snippet
error: manjaro-settings-manager-kcm: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-kcm-0.5.7-12-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: manjaro-settings-manager-knotifier: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/manjaro-settings-manager-knotifier-0.5.7-12-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: packagekit: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/packagekit-1.2.5-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-cli: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-cli-10.4.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: pamac-gtk: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/pamac-gtk-10.4.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: spectre-meltdown-checker: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/spectre-meltdown-checker-0.45+1+gb68ebe6-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: systemd-sysvcompat: signature from "Philip Müller (Called Little) <philm@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/systemd-sysvcompat-251.8-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: timeshift: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/timeshift-22.06.5+12+g92ad80c-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: vivaldi: signature from "Mark Wagie <mark@manjaro.org>" is unknown trust
:: File /var/cache/pacman/pkg/vivaldi-5.5.2805.44-1.1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
Ah yeah… that happens when the keyrings are outdated… maybe that helps to work around that:
@Aragorn thanks bro fixed it should i restart and re edit /etc/pacman.conf and change siglevel back to SigLevel = Required DatabaseOptional
Perhaps you can wait until the signature issue has been fixed. Once it has, you can change the siglevel back. :wink:
