Pacman freezes gnome shell
Whenever I use pacman over a wifi the system freezes. this doesn’t happen when connected via USB tethering and wifi is on. I am not sure what logs to show as I am new to manjaro and arch linux so please help !!
$ inxi -Fazy
  Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=309ca3ff-c802-4b03-afa7-a70610060e41 ro quiet udev.log_priority=3
  Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Latitude E5430 non-vPro v: 01
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0MYF02 v: A00 serial: <filter> UEFI: Dell v: A12
  date: 08/07/2013
  ID-1: BAT0 charge: 16.0 Wh condition: 33.4/48.8 Wh (68%) volts: 11.3/11.1
  model: Samsung SDI DELL P8TC727 type: Li-ion serial: <filter>
  status: Discharging
  Info: Dual Core model: Intel Core i5-3340M bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  L2 cache: 3 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21538
  Speed: 1265 MHz min/max: 1200/3400 MHz Core speeds (MHz): 1: 1265 2: 1261
  3: 1197 4: 1240
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Device-2: Microdia Laptop_Integrated_Webcam_E4HD type: USB driver: uvcvideo
  bus ID: 1-1.5:5 chip ID: 0c45:6449
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: intel unloaded: modesetting alternate: fbdev,vesa
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
  v: 4.2 Mesa 20.3.3 compat-v: 3.0 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
  Sound Server: ALSA v: k5.4.89-1-MANJARO
  Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
  driver: wl v: kernel modules: bcma port: f040 bus ID: 02:00.0
  chip ID: 14e4:4727
  Device-2: Broadcom NetXtreme BCM5761 Gigabit Ethernet PCIe vendor: Dell
  driver: tg3 v: 3.137 port: f040 bus ID: 0c:00.0 chip ID: 14e4:1681
  IF: enp12s0 state: down mac: <filter>
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: f060 bus ID: 00:1f.2 chip ID: 8086.282a rev: 04
  Local Storage: total: 494.4 GiB used: 6.74 GiB (1.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500VT000-1DK142
  size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: SDC1
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
  size: 28.64 GiB block size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.00
  ID-1: / raw size: 463.26 GiB size: 463.26 GiB (100.00%)
  used: 6.71 GiB (1.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
  ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
  used: 688 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  Kernel: swappiness: 10 (default 60) cache pressure: 50 (default 100)
  ID-1: swap-1 type: partition size: 2 GiB used: 22.2 MiB (1.1%) priority: -2
  dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 52.0 C mobo: 44.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 2778
  Processes: 239 Uptime: 1h 38m wakeups: 7 Memory: 3.72 GiB
  used: 2.36 GiB (63.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
  pacman: 977 lib: 270 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal
  inxi: 3.2.02
$ sudo dmesg -l emerg,alert,crit,err,warn
[    0.700917] i8042: Warning: Keylock active
[    0.760560] mmc0: Internal clock never stabilised.
[    0.760561] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.760572] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.760582] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.760593] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.760604] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.760615] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.760626] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00001003
[    0.760637] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.760647] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.760657] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.760668] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.760677] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.760688] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.760698] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.760703] mmc0: sdhci: Host ctl2: 0x00000000
[    0.760704] mmc0: sdhci: ============================================
[    0.780745] mmc0: Internal clock never stabilised.
[    0.780746] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.780757] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.780766] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.780777] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.780788] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.780799] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.780810] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00001003
[    0.780821] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.780831] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.780842] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.780850] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.780859] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.780870] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.780880] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.780886] mmc0: sdhci: Host ctl2: 0x00000000
[    0.780886] mmc0: sdhci: ============================================
[    0.843960] mmc0: Internal clock never stabilised.
[    0.843961] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.843973] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.843983] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.843994] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.844006] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.844016] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.844027] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00001003
[    0.844038] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.844048] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.844059] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.844070] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.844081] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.844092] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.844102] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.844107] mmc0: sdhci: Host ctl2: 0x00000000
[    0.844107] mmc0: sdhci: ============================================
[    0.864137] mmc0: Internal clock never stabilised.
[    0.864138] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.864149] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.864160] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.864169] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.864180] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.864190] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.864201] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00001003
[    0.864211] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.864223] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.864234] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.864244] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.864255] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.864266] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.864277] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.864283] mmc0: sdhci: Host ctl2: 0x00000000
[    0.864283] mmc0: sdhci: ============================================
[    0.927298] mmc0: Internal clock never stabilised.
[    0.927300] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.927308] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.927318] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.927328] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.927339] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.927350] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.927361] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00002003
[    0.927372] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.927383] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.927394] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.927402] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.927412] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.927421] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.927432] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.927437] mmc0: sdhci: Host ctl2: 0x00000000
[    0.927437] mmc0: sdhci: ============================================
[    0.947474] mmc0: Internal clock never stabilised.
[    0.947475] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    0.947486] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    0.947497] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    0.947507] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    0.947517] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    0.947528] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    0.947537] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00002003
[    0.947548] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    0.947558] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    0.947566] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    0.947588] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    0.947596] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    0.947607] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    0.947617] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    0.947623] mmc0: sdhci: Host ctl2: 0x00000000
[    0.947623] mmc0: sdhci: ============================================
[    1.010619] mmc0: Internal clock never stabilised.
[    1.010621] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    1.010632] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    1.010643] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    1.010654] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    1.010665] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    1.010676] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    1.010685] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004003
[    1.010695] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    1.010706] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    1.010716] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    1.010727] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    1.010738] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    1.010748] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    1.010767] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    1.010775] mmc0: sdhci: Host ctl2: 0x00000000
[    1.010776] mmc0: sdhci: ============================================
[    1.030801] mmc0: Internal clock never stabilised.
[    1.030802] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[    1.030813] mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
[    1.030823] mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[    1.030833] mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
[    1.030852] mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
[    1.030862] mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
[    1.030872] mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004003
[    1.030880] mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[    1.030890] mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
[    1.030900] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[    1.030910] mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
[    1.030921] mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
[    1.030931] mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[    1.030942] mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[    1.030947] mmc0: sdhci: Host ctl2: 0x00000000
[    1.030947] mmc0: sdhci: ============================================
[   11.446921] i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[   11.554368] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20190816/utaddress-204)
[   11.554380] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   11.554385] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   11.554389] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20190816/utaddress-204)
[   11.554392] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   11.596122] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[   12.008558] dell-smbios PNP0C14:00-A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[   12.219050] wl: loading out-of-tree module taints kernel.
[   12.219055] wl: module license 'MIXED/Proprietary' taints kernel.
[   12.219055] Disabling lock debugging due to kernel taint
[   12.570273] wlan0: Broadcom BCM4727 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[   15.116895] kauditd_printk_skb: 4 callbacks suppressed
[   30.212292] proc: Bad value for 'hidepid'
[   30.872713] proc: Bad value for 'hidepid'
[   37.260222] proc: Bad value for 'hidepid'
[   37.335348] kauditd_printk_skb: 16 callbacks suppressed
[  262.178451] proc: Bad value for 'hidepid'
[  262.210226] proc: Bad value for 'hidepid'
[  262.314237] kauditd_printk_skb: 4 callbacks suppressed
[  265.682695] proc: Bad value for 'hidepid'
[  587.274152] proc: Bad value for 'hidepid'
[  699.464978] proc: Bad value for 'hidepid'
[  835.573929] proc: Bad value for 'hidepid'
[ 1005.582731] proc: Bad value for 'hidepid'
[ 1146.272732] proc: Bad value for 'hidepid'
[ 1195.204527] proc: Bad value for 'hidepid'
[ 1231.537908] proc: Bad value for 'hidepid'
[ 1412.002716] proc: Bad value for 'hidepid'
[ 1774.295545] proc: Bad value for 'hidepid'
[ 2243.258440] proc: Bad value for 'hidepid'
[ 2372.378307] proc: Bad value for 'hidepid'
[ 2480.110723] proc: Bad value for 'hidepid'
[ 2532.488831] proc: Bad value for 'hidepid'
[ 2699.269542] proc: Bad value for 'hidepid'
[ 2815.496610] kauditd_printk_skb: 98 callbacks suppressed
[ 2834.033544] kauditd_printk_skb: 117 callbacks suppressed
[ 2881.030966] ERROR @wl_cfg80211_scan :
[ 2881.030968] WLC_SCAN error (-22)
[ 3650.212013] ERROR @wl_cfg80211_scan :
[ 3650.212015] WLC_SCAN error (-22)
[ 3767.685688] proc: Bad value for 'hidepid'
[ 3827.224868] proc: Bad value for 'hidepid'
[ 4054.058905] proc: Bad value for 'hidepid'
$ journalctl --since “2 days ago” -p “emerg”…"err"
-- Journal begins at Mon 2021-02-01 09:44:07 IST, ends at Mon 2021-02-01 11:30:46 IST. --
Feb 01 09:44:07 havoc kernel: mmc0: Internal clock never stabilised.
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Sys addr:  0x00000000 | Version:  0x0000c001
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Argument:  0x00000000 | Trn mode: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Present:   0x01f70000 | Host ctl: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Power:     0x0000000f | Blk gap:  0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00001003
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Int enab:  0x00ff0083 | Sig enab: 0x00ff0083
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Caps:      0x21e608b2 | Caps_1:   0x00002077
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Cmd:       0x00000000 | Max curr: 0x00000064
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Host ctl2: 0x00000000
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: ============================================
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00002003
Feb 01 09:44:07 havoc kernel: mmc0: sdhci: Wake-up:   0x00000000 | Clock:    0x00004003
Feb 01 09:44:28 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:44:35 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:15 havoc gdm-password][1484]: gkr-pam: unable to locate daemon control file
Feb 01 09:48:20 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:20 havoc sudo[1802]: pam_unix(sudo:auth): conversation failed
Feb 01 09:48:20 havoc sudo[1802]: pam_unix(sudo:auth): auth could not identify password for [retr>
Feb 01 09:48:23 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:48:24 havoc pipewire[1978]: Failed to receive portal pid: org.freedesktop.DBus.Error.Na>
Feb 01 09:50:23 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:51:24 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:52:36 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:53:45 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:54:53 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:55:37 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:56:31 havoc systemd[1494]: Failed to start Application launched by gnome-shell.
Feb 01 09:56:52 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 09:57:53 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 09:58:19 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:17 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:35 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:00:43 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:01:20 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:02:35 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:03:00 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:03:04 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:03:49 havoc systemd-coredump[2942]: Process 2606 (gjs) of user 1000 dumped core.
                                              Stack trace of thread 2606:
                                              #0  0x00007f1955c83d86 n/a (libgtk-3.so.0 + 0x29ad8>
                                              #1  0x00007f195ab4343c g_cclosure_marshal_VOID__FLA>
                                              #2  0x00007f195ab6198a g_signal_emit_valist (libgob>
                                              #3  0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #4  0x00007f1955d2ffa0 n/a (libgtk-3.so.0 + 0x346fa>
                                              #5  0x00007f1955d212d8 n/a (libgtk-3.so.0 + 0x3382d>
                                              #6  0x00007f1955c84d10 gtk_switch_set_state (libgtk>
                                              #7  0x00007f1955c84f6e n/a (libgtk-3.so.0 + 0x29bf6>
                                              #8  0x00007f1955a6dcac n/a (libgtk-3.so.0 + 0x84cac)
                                              #9  0x00007f195ab6198a g_signal_emit_valist (libgob>
                                              #10 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #11 0x00007f1955c84900 gtk_switch_set_active (libgt>
                                              #12 0x00007f195ab4d6cf n/a (libgobject-2.0.so.0 + 0>
                                              #13 0x00007f195ab54dac g_object_setv (libgobject-2.>
                                              #14 0x00007f195ab54e7c g_object_set_property (libgo>
                                              #15 0x00007f195aa5ef95 n/a (libgio-2.0.so.0 + 0xe8f>
                                              #16 0x00007f195ab45052 g_closure_invoke (libgobject>
                                              #17 0x00007f195ab6d9c5 n/a (libgobject-2.0.so.0 + 0>
                                              #18 0x00007f195ab6159d g_signal_emit_valist (libgob>
                                              #19 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #20 0x00007f195aa52673 n/a (libgio-2.0.so.0 + 0xdc6>
                                              #21 0x00007f195a9e2325 n/a (libgio-2.0.so.0 + 0x6c3>
                                              #22 0x00007f195ab6198a g_signal_emit_valist (libgob>
                                              #23 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #24 0x00007f195aa53eaf n/a (libgio-2.0.so.0 + 0xdde>
                                              #25 0x00007f195aa4ed8b n/a (libgio-2.0.so.0 + 0xd8d>
                                              #26 0x00007f195abdc155 g_main_context_invoke_full (>
                                              #27 0x00007f195aa4f511 n/a (libgio-2.0.so.0 + 0xd95>
                                              #28 0x00007f195400f498 n/a (libdconfsettings.so + 0>
                                              #29 0x00007f195400f772 n/a (libdconfsettings.so + 0>
                                              #30 0x00007f195aaa468b n/a (libgio-2.0.so.0 + 0x12e>
                                              #31 0x00007f195aa5f333 n/a (libgio-2.0.so.0 + 0xe93>
                                              #32 0x00007f195ab45052 g_closure_invoke (libgobject>
                                              #33 0x00007f195ab6d9c5 n/a (libgobject-2.0.so.0 + 0>
                                              #34 0x00007f195ab6159d g_signal_emit_valist (libgob>
                                              #35 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #36 0x00007f195ab4bf76 n/a (libgobject-2.0.so.0 + 0>
                                              #37 0x00007f195ab4d242 g_object_notify_by_pspec (li>
                                              #38 0x00007f1955c84910 gtk_switch_set_active (libgt>
                                              #39 0x00007f1955c84a76 n/a (libgtk-3.so.0 + 0x29ba7>
                                              #40 0x00007f1955d1f316 n/a (libgtk-3.so.0 + 0x33631>
                                              #41 0x00007f195ab6198a g_signal_emit_valist (libgob>
                                              #42 0x00007f195ab61b00 g_signal_emit (libgobject-2.>
                                              #43 0x00007f195592a05d n/a (libgdk-3.so.0 + 0x4005d)
                                              #44 0x00007f19559178ac n/a (libgdk-3.so.0 + 0x2d8ac)
                                              #45 0x00007f195abdd2c4 n/a (libglib-2.0.so.0 + 0x53>
...skipping...
Feb 01 10:47:45 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:48:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:51:23 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:51:32 havoc kernel: proc: Bad value for 'hidepid'
Feb 01 10:51:58 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:52:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:53:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:53:53 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:54:34 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:55:42 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:56:57 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 10:57:51 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:01:07 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:02:20 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:02:49 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:03:40 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:04:37 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:05:11 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:09:51 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:10:59 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:14:36 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:16:10 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:16:44 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:20:30 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
Feb 01 11:24:11 havoc wpa_supplicant[855]: bgscan simple: Failed to enable signal strength monito>
lines 314-338/338 (END)
Just to help this along and to clarify what that means:
does the pacman process stall? and how does that look?
Or does your whole system stall/go down?
… anything in the system logs?
journalctl and/or dmesg ?
So whenever I try to do any command with pacman whole screen freezes, mouse doesn’t work neither does keyboard. only way to get out of it is doing a reboot.
I also checked the journalctl of the time when it happens and there were no entries at that time.
So this:
journalctl --since "2 days ago" -p "emerg".."err"
yields nothing?
Example?
You don’t need to actually do it, you can look in your bash_history for the commands you did.
The command
history
will list all your recent commands, the most recent at the bottom of the list
Also, since this could be driver related, please post the output of:
inxi -Fazy
Thank you very much for the rules!! I have updated my post to include the jounal and other things mentioned in the rules. Please have a look.
Also I should mention that I re-installed the manjaro OS with LTS kernel and the system is not freezing like before but there are some short spikes where I am not able to do anything. Besides this I am seeing some Internal clock never stabilised in the journalctl and dmesg output
I see your shell isn’t bash but zsh.
The command history - for what you did (pacman) when the system froze - in that case is:
history 1
I had to look it up - I never used zsh myself so I’m not sure of the result
btw: it is confusing to amend your first post instead of putting the info here, after it has been asked for :wink:
So this is basically solved? Until it happens again?
Which hopefully doesn’t happen.
Yea the system is not freezing but there are some spikes where it is irresponsive for 5 seconds and there is also the issue of internal clock never stablilised in the kernel log in journalctl so any idea about that ?
BTW I thought it would be better if I put the info in original post for someone reading it later so that is why. sorry for the inconviniece :slight_smile:
