Please forgive me for asking something that will be obvious for a seasoned user.
I have an issue very similar to Pacman: error while loading shared libraries: libcrypto.so.3 after updating openssl, however, the proposed solution doesn’t work; i.e.: After downloading openssl-3.1.4-1-x86_64.pkg.tar.zst, and extracting libcrypto.so.3 from it and chown it to root:root, chmod it 777 and moving it to /usr/lib/, pacman still doesn’t do anything/throws the same error (with everything, even a mere pacman --version).
Hardware is a newly bought PinePhone Pro, if that matters.
It matters that if you followed the link in that thread verbatim you downloaded the package for x86_64 (while your system is ARM).
Not to mention the version, but you probably gathered that from looking at what the mirror was providing.
Probably that or a similar tar would be better, but I can’t install it via the package manager, since it doesn’t function anymore (even a mere pacman --version throws the aforementioned error). Any suggestions on where to find the latest stable openssl release for ARM devices?
