Hello everyone. I have a headset called Creative SXFI Air. It has a USB, AUX and Bluetooth connection. On Windows, if I connect the headset via USB it will charge and I’ll be able to use it freely. On Linux, it won’t charge unless it’s turned off, or connected via a different connection, which I do not want for reasons I’ll talk about later. I’ve read about the headset on Creative’s website and they claim it won’t charge when it’s in USB Mass Storage mode. Someone online gave me a udev script that’d make it not mount to USB Mass Storage, but unfortunately it didn’t work. Maybe I made a mistake of some kind. I’m new to Linux, I am tech savvy, but still a newb when it comes to Linux. I reached out to Creative, and I got the classic response “Linux is unsupported”. Well, the headset works great. It’s just this charging thing that’s annoying.
Output of inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.11.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=5146f14c-7a19-457d-9742-d9db97819870 rw quiet apparmor=1
security=apparmor resume=UUID=046a30e8-66df-42fe-8a4f-1f50282738ea
udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7A39 v: 1.0 serial: <filter>
Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 2.L0 date: 01/22/2019
RAM: total: 13.68 GiB used: 5.9 GiB (43.2%)
Info: Quad Core model: AMD Ryzen 5 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17) stepping: 0
microcode: 810100B cache: L2: 2 MiB bogomips: 57623
Speed: 2438 MHz min/max: 1600/3600 MHz boost: enabled Core speeds (MHz):
1: 2438 2: 2505 3: 1503 4: 1503 5: 3689 6: 3600 7: 3755 8: 3720
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 38:00.0
chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0
5.11.14-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 38:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 38:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-3: Creative Creative SXFI AIR type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2
chip-ID: 041e:3258 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.11.14-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.048.03-NAPI modules: r8169
port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 1.35 TiB (66.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: ABB0 scheme: GPT
ID-1: / raw-size: 228.59 GiB size: 224 GiB (97.99%) used: 87.81 GiB (39.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 5146f14c-7a19-457d-9742-d9db97819870
used: 25.6 MiB (8.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5D02-5729
ID-3: /home raw-size: 488.28 GiB size: 479.62 GiB (98.23%)
used: 149.34 GiB (31.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: b7a8be89-ebdb-451a-9e4b-eeedfc265730
ID-4: /run/media/fdgod/Data_HDD raw-size: 1.16 TiB size: 1.14 TiB (98.34%)
used: 1014.2 GiB (86.8%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 4b20b94a-b9cd-4f2c-9dac-7decaf17b57a
ID-5: /run/media/fdgod/Windows_10_HDD raw-size: 186.25 GiB
size: 186.25 GiB (100.00%) used: 133.51 GiB (71.7%) fs: ntfs dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: C62ED2BC2ED2A529
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 4 GiB fs: swap label: N/A
uuid: 046a30e8-66df-42fe-8a4f-1f50282738ea
ID-2: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 3-2:2 info: Full speed (or root) Hub ports: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: ffa1:0201 class-ID: 0900
Device-1: 3-2.1:3 info: SiGma Micro Keyboard TRACER Gamma Ivory
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0002 class-ID: 0300
Device-2: 3-2.2:4 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Device-1: 5-1:2 info: Creative Creative SXFI AIR
type: HID,Abstract (modem),CDC-Data,Audio
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 041e:3258 class-ID: 0300
serial: <filter>
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.8 C mobo: 0 C gpu: amdgpu temp: 47.0 C
Processes: 339 Uptime: 40m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 2294 apt: 0 pacman: 2276
lib: 554 flatpak: 7 snap: 11 Shell: Bash v: 5.1.0 running-in: yakuake
inxi: 3.3.04
Output of dmesg | grep usb
[ 0.169323] usbcore: registered new interface driver hub
[ 0.169323] usbcore: registered new device driver usb
[ 0.438777] usbcore: registered new interface driver usbserial_generic
[ 0.438781] usbserial: USB Serial support registered for generic
[ 2.099736] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.11
[ 2.099739] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.099741] usb usb1: Product: xHCI Host Controller
[ 2.099743] usb usb1: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.099744] usb usb1: SerialNumber: 0000:15:00.0
[ 2.100322] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.100340] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.11
[ 2.100342] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.100344] usb usb2: Product: xHCI Host Controller
[ 2.100345] usb usb2: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.100346] usb usb2: SerialNumber: 0000:15:00.0
[ 2.101709] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.11
[ 2.101712] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.101713] usb usb3: Product: xHCI Host Controller
[ 2.101714] usb usb3: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.101716] usb usb3: SerialNumber: 0000:38:00.3
[ 2.102051] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.102069] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.11
[ 2.102070] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.102072] usb usb4: Product: xHCI Host Controller
[ 2.102073] usb usb4: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.102074] usb usb4: SerialNumber: 0000:38:00.3
[ 2.103577] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.11
[ 2.103579] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.103581] usb usb5: Product: xHCI Host Controller
[ 2.103582] usb usb5: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.103583] usb usb5: SerialNumber: 0000:38:00.4
[ 2.103818] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.103835] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.11
[ 2.103837] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.103838] usb usb6: Product: xHCI Host Controller
[ 2.103840] usb usb6: Manufacturer: Linux 5.11.14-1-MANJARO xhci-hcd
[ 2.103841] usb usb6: SerialNumber: 0000:38:00.4
[ 2.430051] usb 3-2: new full-speed USB device number 2 using xhci_hcd
[ 2.578146] usb 3-2: New USB device found, idVendor=ffa1, idProduct=0201, bcdDevice= 1.10
[ 2.578153] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.346694] usb 3-2.1: new low-speed USB device number 3 using xhci_hcd
[ 3.461211] usb 3-2.1: New USB device found, idVendor=1c4f, idProduct=0002, bcdDevice= 1.10
[ 3.461218] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.461222] usb 3-2.1: Product: USB Keyboard
[ 3.461224] usb 3-2.1: Manufacturer: SIGMACHIP
[ 3.623363] usb 3-2.2: new low-speed USB device number 4 using xhci_hcd
[ 3.733209] usb 3-2.2: New USB device found, idVendor=18f8, idProduct=0f97, bcdDevice= 1.00
[ 3.733216] usb 3-2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.733219] usb 3-2.2: Product: USB OPTICAL MOUSE
[ 5.473629] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.1/3-2.1:1.0/0003:1C4F:0002.0001/input/input10
[ 5.530665] hid-generic 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:38:00.3-2.1/input0
[ 5.535740] input: SIGMACHIP USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.1/3-2.1:1.1/0003:1C4F:0002.0002/input/input11
[ 5.590252] input: SIGMACHIP USB Keyboard System Control as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.1/3-2.1:1.1/0003:1C4F:0002.0002/input/input12
[ 5.590617] hid-generic 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:38:00.3-2.1/input1
[ 5.594580] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.2/3-2.2:1.0/0003:18F8:0F97.0003/input/input13
[ 5.594704] hid-generic 0003:18F8:0F97.0003: input,hidraw2: USB HID v1.10 Mouse [USB OPTICAL MOUSE ] on usb-0000:38:00.3-2.2/input0
[ 5.600875] input: USB OPTICAL MOUSE Keyboard as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:18F8:0F97.0004/input/input14
[ 5.656936] input: USB OPTICAL MOUSE Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:38:00.3/usb3/3-2/3-2.2/3-2.2:1.1/0003:18F8:0F97.0004/input/input15
[ 5.657416] hid-generic 0003:18F8:0F97.0004: input,hiddev0,hidraw3: USB HID v1.10 Keyboard [USB OPTICAL MOUSE ] on usb-0000:38:00.3-2.2/input1
[ 5.657483] usbcore: registered new interface driver usbhid
[ 5.657486] usbhid: USB HID core driver
[ 1526.380205] usb 5-1: new high-speed USB device number 2 using xhci_hcd
[ 1526.522467] usb 5-1: New USB device found, idVendor=041e, idProduct=3258, bcdDevice= 1.00
[ 1526.522475] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 1526.522478] usb 5-1: Product: Creative SXFI AIR
[ 1526.522480] usb 5-1: Manufacturer: Creative Technology Ltd
[ 1526.522482] usb 5-1: SerialNumber: 95EAE8EBCB918507
[ 1526.544777] input: Creative Technology Ltd Creative SXFI AIR as /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0005/input/input17
[ 1526.600388] hid-generic 0003:041E:3258.0005: input,hidraw4: USB HID v1.10 Device [Creative Technology Ltd Creative SXFI AIR] on usb-0000:38:00.4-1/input0
[ 1526.603311] hid-generic 0003:041E:3258.0006: hiddev1,hidraw5: USB HID v1.10 Device [Creative Technology Ltd Creative SXFI AIR] on usb-0000:38:00.4-1/input6
[ 1527.222683] usbcore: registered new interface driver cdc_acm
[ 1527.327170] usbcore: registered new interface driver snd-usb-audio
Output of udevadm monitor -u when I connect the headset
UDEV [3099.444747] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0 (usb)
UDEV [3099.445557] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.1 (usb)
UDEV [3099.447145] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.2 (usb)
UDEV [3099.447916] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.5 (usb)
UDEV [3099.448742] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.4 (usb)
UDEV [3099.449000] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3 (usb)
UDEV [3099.450865] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6 (usb)
UDEV [3099.451555] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.2 (usb)
UDEV [3099.451746] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0007 (hid)
UDEV [3099.451899] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.5 (usb)
UDEV [3099.452622] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.4 (usb)
UDEV [3099.454308] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3/sound/card3 (sound)
UDEV [3099.454642] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.1/tty/ttyACM0 (tty)
UDEV [3099.456409] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6/usbmisc/hiddev1 (usbmisc)
UDEV [3099.457103] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6/0003:041E:3258.0008 (hid)
UDEV [3099.457555] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0007/input/input18 (input)
UDEV [3099.461535] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3/sound/card3/pcmC3D0p (sound)
UDEV [3099.461937] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3/sound/card3/pcmC3D0c (sound)
UDEV [3099.462508] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.1 (usb)
UDEV [3099.465779] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0007/hidraw/hidraw4 (hidraw)
UDEV [3099.467929] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3/sound/card3/controlC3 (sound)
UDEV [3099.469344] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6/0003:041E:3258.0008/hidraw/hidraw5 (hidraw)
UDEV [3099.470483] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6/0003:041E:3258.0008 (hid)
UDEV [3099.472126] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.6 (usb)
UDEV [3099.473535] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3 (usb)
UDEV [3099.506191] add /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0007/input/input18/event16 (input)
UDEV [3099.508178] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0/0003:041E:3258.0007 (hid)
UDEV [3099.510917] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.0 (usb)
UDEV [3099.527426] bind /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1 (usb)
UDEV [3099.529386] change /devices/pci0000:00/0000:00:08.1/0000:38:00.4/usb5/5-1/5-1:1.3/sound/card3 (sound)
Output of lsusb
Bus 005 Device 003: ID 041e:3258 Creative Technology, Ltd Creative SXFI AIR
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 18f8:0f97 [Maxxter] Optical Gaming Mouse [Xtrem]
Bus 003 Device 003: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 003 Device 002: ID ffa1:0201
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
So why don’t I use a different connection? Because the headset will turn off after 10 minutes of not playing anything, the microphone will not work, and I have to unplug and replug for charging to work, which is annoying.
Is something like this fixable? I’d really appreciate your input. I’m struggling with this for months. Thanks for having me and thanks for your time.
