Packages are not downloading from AUR
Today I updated my system.
At the end these packages have issues. Here is the pacman log.
Preparing...
Nothing to do.
Checking libudev0-shim dependencies...
Checking steam-native-runtime dependencies...
Checking libdbusmenu-gtk2 dependencies...
Checking libgcrypt15 dependencies...
Checking libvpx1.3 dependencies...
Checking libindicator-gtk2 dependencies...
Checking lib32-libindicator-gtk2 dependencies...
Checking video-downloader dependencies...
Checking libjpeg6-turbo dependencies...
Checking lib32-libjpeg6-turbo dependencies...
Checking libidn11 dependencies...
Checking lib32-libdbusmenu-gtk2 dependencies...
Checking lib32-libappindicator-gtk2 dependencies...
Checking winegui dependencies...
Checking pinta dependencies...
Resolving dependencies...
Checking inter-conflicts...
Cloning libdbusmenu-gtk2 build files...
Failed to prepare transaction:
Failed to clone libdbusmenu-gtk2 build files
I tried few package install one by one. All of them failed.
The AUR has been under a constant DDoS attack for months on end now, so being able to install anything from there is a matter of hit-and-miss, really.
I’m afraid the only recourse is to be patient and to try again later, one package at a time.
:man_shrugging:
Unfortunately those packages have dependencies. In case of a package is downloaded successfully then the dependency download is failing.
The easy way I often do it is by using yay.
Not pamac.
yay will access the AUR directly.
The way I also do it in a lot of cases is:
  • go to the AUR website
https://aur.archlinux.org/
  • search for the package name
  • when found, on the right side under “Package Actions”: download snapshot
    It’s an archive containing the PKGBUILD and every other thing needed.
  • unpack that, change directory into what was just unpacked
  • makepkg -i
If there are dependencies, they will be listed on the web site, they will be listed in the PKGBUILD
and they will make the build fail if not present, so you can tend to them first and then come back to the failed package.
The very first thing I’d do though is:
make sure that you actually (still) need these packages - and if you do:
make sure that the AUR is the only way to get them
because often that changes over time and what you want might be available from the repos.
Thanks for the advice.
I don’t know those packages are needing.
I would like to solve the issue without snapshots.
Anyway, thanks again.
Who will or can know if not you? :grinning_face:
Nothing from AUR is really needed.
It’s you who once decided that you wanted to have these.
Those are mostly libraries - they are not needed by themselves, but by some program.
I see only a few actual programs:
pinta - a drawing program
video-downloader - name speaks for itself
winegui - whatever that might be for - Windows programs installed through wine can be used without that
I’d try to remove it all and look at the fallout … :wink:
then install the three programs again if you really need them
AUR status shows minimal downtime in the last few weeks
Well, that’s good to hear. :+1:
All seem to be sourced via the AUR.
GTK2 has been purged from Manjaro repositories – that may also have something to do with it.
Ok, so are you using Pamac? You really should say what you’re doing when you say you have a problem… or more to the point, HOW you’re doing it.
Personally I had some errors doing queries with yay, but never with pamac… pamac is the correct tool for Manjaro, and Manjaro caches the AUR.
1 minuter 39 seconds with Pamac
pamac upgrade
Preparing...
Authenticating as: ben
Password:
Refreshing AUR...
Warning: dependency cycle detected:
Warning: xdg-desktop-portal-kde will be installed before its plasma-workspace dependency
To upgrade (88):
double-conversion            3.4.0-1                   (3.3.1-1)                   extra
xdg-utils                    1.2.1-2                   (1.2.1-1)                   extra
libidn2                      2.3.8-1                   (2.3.7-1)                   core
kdecoration                  6.5.4-1                   (6.5.3-1)                   extra
qt6-declarative              6.10.1-2                  (6.10.1-1)                  extra
hwdata                       0.402-1                   (0.401-1)                   core
aurorae                      6.5.4-1                   (6.5.3-1)                   extra
plasma-activities            6.5.4-1                   (6.5.3-1)                   extra
libplasma                    6.5.4-1                   (6.5.3-1)                   extra
bluedevil                    1:6.5.4-1                 (1:6.5.3-1)                 extra
breeze                       6.5.4-1                   (6.5.3-2)                   extra
breeze-gtk                   6.5.4-1                   (6.5.3-1)                   extra
qt5-declarative              5.15.18+kde+r23-1         (5.15.18+kde+r22-1)         extra
breeze5                      6.5.4-1                   (6.5.3-2)                   extra
cmake                        4.2.1-1                   (4.2.0-1)                   extra
discover                     6.5.4-1                   (6.5.3-1)                   extra
duplicity                    3.0.6.3-2                 (3.0.6.3-1)                 extra
element-web                  1.12.6-0.1                (1.12.3-1)                  extra
element-desktop              1.12.6-0.1                (1.12.3-1)                  extra
firefox                      146.0-1                   (145.0.2-1)                 extra
flatpak-kcm                  6.5.4-1                   (6.5.3-1)                   extra
foomatic-db                  3:20251122-1              (3:20240209-1)              extra
foomatic-db-nonfree          3:20251122-1              (3:20240209-1)              extra
foomatic-db-nonfree-ppds     3:20251122-1              (3:20240209-1)              extra
foomatic-db-ppds             3:20251122-1              (3:20240209-1)              extra
python-urllib3               2.6.1-1                   (2.6.0-1)                   extra
gearlever                    4.1.1-1                   (4.0.3-2)                   extra
haskell-rio                  0.1.24.0-1                (0.1.22.0-230)              extra
js140                        140.6.0-1                 (140.5.0-1)                 extra
kactivitymanagerd            6.5.4-1                   (6.5.3-1)                   extra
kde-cli-tools                6.5.4-1                   (6.5.3-1)                   extra
kde-gtk-config               6.5.4-1                   (6.5.3-1)                   extra
kglobalacceld                6.5.4-1                   (6.5.3-1)                   extra
knighttime                   6.5.4-1                   (6.5.3-1)                   extra
layer-shell-qt               6.5.4-1                   (6.5.3-2)                   extra
libkscreen                   6.5.4-1                   (6.5.3-1)                   extra
kscreenlocker                6.5.4-1                   (6.5.3-2)                   extra
kwayland                     6.5.4-1                   (6.5.3-1)                   extra
kwin                         6.5.4-1                   (6.5.3-2)                   extra
kpipewire                    6.5.4-1                   (6.5.3-1)                   extra
libksysguard                 6.5.4-1                   (6.5.3-1)                   extra
ksystemstats                 6.5.4-1                   (6.5.3-1)                   extra
milou                        6.5.4-1                   (6.5.3-1)                   extra
ocean-sound-theme            6.5.4-1                   (6.5.3-1)                   extra
plasma-activities-stats      6.5.4-1                   (6.5.3-1)                   extra
plasma5support               6.5.4-1                   (6.5.3-2)                   extra
qqc2-breeze-style            6.5.4-1                   (6.5.3-1)                   extra
xdg-desktop-portal-kde       6.5.4-1                   (6.5.3-1)                   extra
plasma-integration           6.5.4-1                   (6.5.3-2)                   extra
plasma-workspace             6.5.4-1                   (6.5.3-2)                   extra
kdeplasma-addons             6.5.4-1                   (6.5.3-1)                   extra
systemsettings               6.5.4-1                   (6.5.3-1)                   extra
kinfocenter                  6.5.4-1                   (6.5.3-1)                   extra
kmenuedit                    6.5.4-1                   (6.5.3-1)                   extra
kmonad                       0.4.4-82                  (0.4.4-81)                  extra
krita-plugin-gmic            3.6.4.1-1                 (3.5.3.0-1)                 extra
ksshaskpass                  6.5.4-1                   (6.5.3-1)                   extra
kwallet-pam                  6.5.4-1                   (6.5.3-1)                   extra
kwayland-integration         6.5.4-1                   (6.5.3-1)                   extra
kwin-x11                     6.5.4-1                   (6.5.3-2)                   extra
kwrited                      6.5.4-1                   (6.5.3-1)                   extra
lib32-libidn2                2.3.8-1                   (2.3.7-1)                   multilib
luajit                       2.1.1765228720+7152e15-1  (2.1.1765007043+45b771b-1)  extra
mympd                        23.0.1-1                  (23.0.0-1)                  extra
oxygen-sounds                6.5.4-1                   (6.5.3-1)                   extra
plasma-browser-integration   6.5.4-1                   (6.5.3-1)                   extra
polkit-kde-agent             6.5.4-1                   (6.5.3-1)                   extra
powerdevil                   6.5.4-1                   (6.5.3-2)                   extra
plasma-desktop               6.5.4-1                   (6.5.3-2)                   extra
plasma-disks                 6.5.4-1                   (6.5.3-1)                   extra
plasma-nm                    6.5.4-1                   (6.5.3-1)                   extra
plasma-pa                    6.5.4-1                   (6.5.3-1)                   extra
plasma-sdk                   6.5.4-1                   (6.5.3-1)                   extra
plasma-systemmonitor         6.5.4-1                   (6.5.3-1)                   extra
plasma-workspace-wallpapers  6.5.4-1                   (6.5.3-1)                   extra
plasma-x11-session           6.5.4-1                   (6.5.3-2)                   extra
plasma5-integration          6.5.4-1                   (6.5.3-2)                   extra
print-manager                1:6.5.4-1                 (1:6.5.3-1)                 extra
python-pybcj                 1.0.7-1                   (1.0.6-1)                   extra
python-pyzstd                0.19.0-1                  (0.18.0-1)                  extra
sddm-kcm                     6.5.4-1                   (6.5.3-1)                   extra
spectacle                    1:6.5.4-1                 (1:6.5.3-1)                 extra
usb_modeswitch               2.6.2.20251207-1          (2.6.2-1)                   extra
vivaldi                      7.7.3851.61-1             (7.7.3851.58-1)             extra
wxwidgets-common             3.2.9-3                   (3.2.9-2)                   extra
wxwidgets-gtk3               3.2.9-3                   (3.2.9-2)                   extra
yt-dlp                       2025.12.08-1              (2025.11.12-2)              extra
To install (1):
python-backports-zstd        1.2.0-3                                               extra
Total installed size: 6.1 MB
Apply transaction ? [y/N] y
Checking keyring...        [89/89]
Checking integrity...        [89/89]
Loading package files...        [89/89]
Checking file conflicts...                                                              [89/89]
Checking available disc space...                                                        [89/89]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade...                                             [1/3]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove Firefox Distribution Settings                                                      [2/3]
Unregistering Haskell modules...                                                          [3/3]
Upgrading double-conversion (3.3.1-1 -> 3.4.0-1)...                                      [1/89]
Upgrading xdg-utils (1.2.1-1 -> 1.2.1-2)...                                              [2/89]
Upgrading libidn2 (2.3.7-1 -> 2.3.8-1)...                                                [3/89]
Upgrading kdecoration (6.5.3-1 -> 6.5.4-1)...                                            [4/89]
Upgrading qt6-declarative (6.10.1-1 -> 6.10.1-2)...                                      [5/89]
Upgrading hwdata (0.401-1 -> 0.402-1)...                                                 [6/89]
Upgrading aurorae (6.5.3-1 -> 6.5.4-1)...                                                [7/89]
Upgrading plasma-activities (6.5.3-1 -> 6.5.4-1)...                                      [8/89]
Upgrading libplasma (6.5.3-1 -> 6.5.4-1)...                                              [9/89]
Upgrading bluedevil (1:6.5.3-1 -> 1:6.5.4-1)...                                         [10/89]
Upgrading breeze (6.5.3-2 -> 6.5.4-1)...                                                [11/89]
Upgrading breeze-gtk (6.5.3-1 -> 6.5.4-1)...                                            [12/89]
Upgrading qt5-declarative (5.15.18+kde+r22-1 -> 5.15.18+kde+r23-1)...                   [13/89]
Upgrading breeze5 (6.5.3-2 -> 6.5.4-1)...                                               [14/89]
Upgrading cmake (4.2.0-1 -> 4.2.1-1)...                                                 [15/89]
Upgrading discover (6.5.3-1 -> 6.5.4-1)...                                              [16/89]
Upgrading duplicity (3.0.6.3-1 -> 3.0.6.3-2)...                                         [17/89]
Upgrading element-web (1.12.3-1 -> 1.12.6-0.1)...                                       [18/89]
Upgrading element-desktop (1.12.3-1 -> 1.12.6-0.1)...                                   [19/89]
Upgrading firefox (145.0.2-1 -> 146.0-1)...                                             [20/89]
Upgrading flatpak-kcm (6.5.3-1 -> 6.5.4-1)...                                           [21/89]
Upgrading foomatic-db (3:20240209-1 -> 3:20251122-1)...                                 [22/89]
Upgrading foomatic-db-nonfree (3:20240209-1 -> 3:20251122-1)...                         [23/89]
Upgrading foomatic-db-nonfree-ppds (3:20240209-1 -> 3:20251122-1)...                    [24/89]
Upgrading foomatic-db-ppds (3:20240209-1 -> 3:20251122-1)...                            [25/89]
Upgrading python-urllib3 (2.6.0-1 -> 2.6.1-1)...                                        [26/89]
Upgrading gearlever (4.0.3-2 -> 4.1.1-1)...                                             [27/89]
Upgrading haskell-rio (0.1.22.0-230 -> 0.1.24.0-1)...                                   [28/89]
Upgrading js140 (140.5.0-1 -> 140.6.0-1)...                                             [29/89]
Upgrading kactivitymanagerd (6.5.3-1 -> 6.5.4-1)...                                     [30/89]
Upgrading kde-cli-tools (6.5.3-1 -> 6.5.4-1)...                                         [31/89]
Upgrading kde-gtk-config (6.5.3-1 -> 6.5.4-1)...                                        [32/89]
Upgrading kglobalacceld (6.5.3-1 -> 6.5.4-1)...                                         [33/89]
Upgrading knighttime (6.5.3-1 -> 6.5.4-1)...                                            [34/89]
Upgrading layer-shell-qt (6.5.3-2 -> 6.5.4-1)...                                        [35/89]
Upgrading libkscreen (6.5.3-1 -> 6.5.4-1)...                                            [36/89]
Upgrading kscreenlocker (6.5.3-2 -> 6.5.4-1)...                                         [37/89]
Upgrading kwayland (6.5.3-1 -> 6.5.4-1)...                                              [38/89]
Upgrading kwin (6.5.3-2 -> 6.5.4-1)...                                                  [39/89]
Upgrading kpipewire (6.5.3-1 -> 6.5.4-1)...                                             [40/89]
Upgrading libksysguard (6.5.3-1 -> 6.5.4-1)...                                          [41/89]
Upgrading ksystemstats (6.5.3-1 -> 6.5.4-1)...                                          [42/89]
Upgrading milou (6.5.3-1 -> 6.5.4-1)...                                                 [43/89]
Upgrading ocean-sound-theme (6.5.3-1 -> 6.5.4-1)...                                     [44/89]
Upgrading plasma-activities-stats (6.5.3-1 -> 6.5.4-1)...                               [45/89]
Upgrading plasma5support (6.5.3-2 -> 6.5.4-1)...                                        [46/89]
Upgrading qqc2-breeze-style (6.5.3-1 -> 6.5.4-1)...                                     [47/89]
Upgrading xdg-desktop-portal-kde (6.5.3-1 -> 6.5.4-1)...                                [48/89]
Upgrading plasma-integration (6.5.3-2 -> 6.5.4-1)...                                    [49/89]
Upgrading plasma-workspace (6.5.3-2 -> 6.5.4-1)...                                      [50/89]
Upgrading kdeplasma-addons (6.5.3-1 -> 6.5.4-1)...                                      [51/89]
Upgrading systemsettings (6.5.3-1 -> 6.5.4-1)...                                        [52/89]
Upgrading kinfocenter (6.5.3-1 -> 6.5.4-1)...                                           [53/89]
Upgrading kmenuedit (6.5.3-1 -> 6.5.4-1)...                                             [54/89]
Upgrading kmonad (0.4.4-81 -> 0.4.4-82)...                                              [55/89]
Upgrading krita-plugin-gmic (3.5.3.0-1 -> 3.6.4.1-1)...                                 [56/89]
Upgrading kscreen (6.5.3-1 -> 6.5.4-1)...                                               [57/89]
Upgrading ksshaskpass (6.5.3-1 -> 6.5.4-1)...                                           [58/89]
Upgrading kwallet-pam (6.5.3-1 -> 6.5.4-1)...                                           [59/89]
Upgrading kwayland-integration (6.5.3-1 -> 6.5.4-1)...                                  [60/89]
Upgrading kwin-x11 (6.5.3-2 -> 6.5.4-1)...                                              [61/89]
Upgrading kwrited (6.5.3-1 -> 6.5.4-1)...                                               [62/89]
Upgrading lib32-libidn2 (2.3.7-1 -> 2.3.8-1)...                                         [63/89]
Upgrading luajit (2.1.1765007043+45b771b-1 -> 2.1.1765228720+7152e15-1)...              [64/89]
Upgrading mympd (23.0.0-1 -> 23.0.1-1)...                                               [65/89]
Upgrading oxygen-sounds (6.5.3-1 -> 6.5.4-1)...                                         [66/89]
Upgrading plasma-browser-integration (6.5.3-1 -> 6.5.4-1)...                            [67/89]
Upgrading polkit-kde-agent (6.5.3-1 -> 6.5.4-1)...                                      [68/89]
Upgrading powerdevil (6.5.3-2 -> 6.5.4-1)...                                            [69/89]
Upgrading plasma-desktop (6.5.3-2 -> 6.5.4-1)...                                        [70/89]
Upgrading plasma-disks (6.5.3-1 -> 6.5.4-1)...                                          [71/89]
Upgrading plasma-nm (6.5.3-1 -> 6.5.4-1)...                                             [72/89]
Upgrading plasma-pa (6.5.3-1 -> 6.5.4-1)...                                             [73/89]
Upgrading plasma-sdk (6.5.3-1 -> 6.5.4-1)...                                            [74/89]
Upgrading plasma-systemmonitor (6.5.3-1 -> 6.5.4-1)...                                  [75/89]
Upgrading plasma-workspace-wallpapers (6.5.3-1 -> 6.5.4-1)...                           [76/89]
Upgrading plasma-x11-session (6.5.3-2 -> 6.5.4-1)...                                    [77/89]
Upgrading plasma5-integration (6.5.3-2 -> 6.5.4-1)...                                   [78/89]
Upgrading print-manager (1:6.5.3-1 -> 1:6.5.4-1)...                                     [79/89]
Upgrading python-pybcj (1.0.6-1 -> 1.0.7-1)...                                          [80/89]
Installing python-backports-zstd (1.2.0-3)...                                           [81/89]
Upgrading python-pyzstd (0.18.0-1 -> 0.19.0-1)...                                       [82/89]
Upgrading sddm-kcm (6.5.3-1 -> 6.5.4-1)...                                              [83/89]
Upgrading spectacle (1:6.5.3-1 -> 1:6.5.4-1)...                                         [84/89]
Upgrading usb_modeswitch (2.6.2-1 -> 2.6.2.20251207-1)...                               [85/89]
Upgrading vivaldi (7.7.3851.58-1 -> 7.7.3851.61-1)...                                   [86/89]
Upgrading wxwidgets-common (3.2.9-2 -> 3.2.9-3)...                                      [87/89]
Upgrading wxwidgets-gtk3 (3.2.9-2 -> 3.2.9-3)...                                        [88/89]
Upgrading yt-dlp (2025.11.12-2 -> 2025.12.08-1)...                                      [89/89]
Reloading system manager configuration...                                                [1/17]
Reloading user manager configuration...                                                  [2/17]
Restarting marked services...                                                            [3/17]
Reloading device manager configuration...                                                [4/17]
Arming ConditionNeedsUpdate...                                                           [5/17]
Updating the MIME type database...                                                       [6/17]
Refreshing PackageKit...        [7/17]
Reloading system bus configuration...                                                    [8/17]
Copy Firefox Distribution Settings                                                       [9/17]
Registering Haskell modules...                                                          [10/17]
Compiling GSettings XML schema files...                                                 [11/17]
Updating icon theme caches...                                                           [12/17]
Removing old packages from pacman cache...                                              [13/17]
Removing old installed packages...
==> no candidate packages found for pruning
Removing old uninstalled packages...
Looking for Pacnew/Pacsave created.                                                     [14/17]
Checking which packages need to be rebuilt                                              [15/17]
Updating the info directory file...                                                     [16/17]
Updating the desktop file MIME type cache...                                            [17/17]
A restart is required for the changes to take effect.
 ~         1m 39s  22.21.1
