OS won't boot after installing a new Motherboard
When I start the PC now, i get these errors:
error: no server is specified.
error: no suitable video mode found.
error: symbol ‘grub_efi_set_variable_to_string’ not found.
I have already timeshifted to before I installed the last system update, so I’m sure it’s an issue with the motherboard.
Any help is appreciated ^^
Inxi Output:
sudo inxi --verbosity=8 --filter
  Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2503 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: Xfce v: N/A wm: xfwm4 with: xfce4-panel tools: xfce4-screensaver
    dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7C56 v: 6.0 serial: N/A
    Chassis: type: 3 v: 6.0 serial: N/A
  Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0 serial: <filter>
    uuid: 2854a392-e160-1712-ab9a-345a603bd601 UEFI: American Megatrends LLC.
    v: A.I0 date: 07/13/2024
  System RAM: total: 16 GiB available: 15.55 GiB used: 2.38 GiB (15.3%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: no module installed
  Device-3: Channel-B DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-16GVK serial: N/A
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
    bus-ID: 00:1c.3
  Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
    bus-ID: 00:1c.4
  Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
    bus-ID: 00:1c.5
  Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
    bus-ID: 00:1c.6
  Slot: 5 type: PCIe status: in use info: J8D1 length: short volts: 3.3
    bus-ID: 00:1c.7
  Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
    bus-ID: 00:1e.0
  Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3
    bus-ID: 00:03.1 children: 1: 2b:00.0 class-ID: 0604 type: bridge children:
    1: 2c:00.0 class-ID: 0604 type: bridge children: 1: 2d:00.0 class-ID: 0300
    type: display 2: 2d:00.1 class-ID: 0403 type: audio
  Slot: 14 type: PCIe status: available info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:1f.7
  Slot: 128 type: PCIe status: in use info: J3708 length: short volts: 3.3
    bus-ID: 03:00.0
  Slot: 134 type: PCIe status: available info: J3703 length: short
  Slot: 135 type: PCIe status: available info: J3702 length: short
  Slot: 132 type: PCIe status: available info: J3707 length: short
  Slot: 137 type: PCIe status: in use info: J3701, M.2 length: short
    volts: 3.3 bus-ID: 03:09.0
  Info: model: AMD Ryzen 5 3500X socket: AM4 bits: 64 type: MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 3600 min/max: 550/4120 boost: enabled
    base/boost: 3600/4100 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 3600 2: 3600 3: 3600 4: 3600
    5: 3600 6: 3600 bogomips: 43212
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
    HDMI-A-1, Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: xfwm4 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
  Monitor-1: DP-3 model: 27E1Q serial: <filter> built: 2021 res: 2560x1440
    dpi: 108 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.200 y: 0.690
    blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi
    inactive: wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.0.5-arch1.1
    note: incomplete (EGL sourced) renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 19.1.7 DRM 3.61 6.12.28-1-MANJARO), llvmpipe (LLVM 19.1.7 256
    bits)
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: n/a (root, process) with:
    1: wireplumber status: active 2: pipewire-alsa type: plugin 3: pw-jack
    type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: off with:
    tools: pacat,pactl,pavucontrol
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.27 TiB used: 372.03 GiB (16.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR311 temp: 39.9 C
  SMART: yes health: PASSED on: 302d 2h cycles: 458
    read-units: 19,634,437 [10.0 TB] written-units: 12,991,026 [6.65 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    family: BarraCuda 3.5 (CMR) size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC43 temp: 34 C
  SMART: yes state: enabled health: PASSED on: 2y 291d 0h cycles: 994
    read: 68.35 TiB written: 124.77 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8480G
    family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 62B3 temp: 35 C
  SMART: yes state: enabled health: PASSED on: 2y 286d 6h cycles: 984
    read: 84905 GiB written: 38638 GiB
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
    size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1.00
  Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM SW830 rev: 1.00
    dev-links: cdrom
  ID-1: / raw-size: 438.03 GiB size: 430.09 GiB (98.19%)
    used: 372.03 GiB (86.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
    maj-min: 8:18 label: N/A uuid: 1ac35c4b-154d-4d98-94b4-2d5193b3401e
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 931.51 GiB fs: btrfs label: speed
    uuid: 4f066a13-a950-486d-8a25-b69c1fa9ec94
  ID-2: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: steam
    uuid: 8429e1cf-59ff-4c60-8719-afef771111fb
  ID-3: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: fat (32 bit)
    label: NO_LABEL uuid: 61E7-70C5
  ID-4: /dev/sdb3 maj-min: 8:19 size: 8.8 GiB fs: swap label: N/A
    uuid: 10f62d63-c416-461c-9990-b380d99d2019
  ID-5: /dev/sdc1 maj-min: 8:33 size: 3.71 GiB fs: N/A
    label: MANJARO_XFCE_2503 uuid: 2025-05-26-07-03-28-00
  ID-6: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: N/A label: MISO_EFI
    uuid: E85C-D58C
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-2.3:4 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Device-2: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
    serial: <filter>
  Device-3: 1-10:5 info: SINOWEALTH Game Mouse type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:1007 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Microdia USB DEVICE type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:7698 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 52.4 C mobo: N/A gpu: amdgpu temp: 52.0 C
    mem: 44.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 2474 pm: dpkg pkgs: 0 pm: pacman pkgs: 2432 libs: 561
    tools: pamac,yay pm: flatpak pkgs: 42
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    7: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    8: https://manjaro.ynh.ovh/stable/$repo/$arch
    9: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    10: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 300
  1: cpu: 10.0% command: firefox pid: 2520 mem: 518.9 MiB (3.2%)
  2: cpu: 3.3% command: firefox pid: 2779 mem: 279.7 MiB (1.7%)
  3: cpu: 1.6% command: Xorg pid: 1531 mem: 168.9 MiB (1.0%)
  4: cpu: 1.4% command: gpg-agent pid: 1067 mem: 3.84 MiB (0.0%)
  5: cpu: 0.6% command: [kworker/u25:0-events_unbound] pid: 56
    mem: 0.00 MiB (0.0%)
  Memory top: 5 of 300
  1: mem: 518.9 MiB (3.2%) command: firefox pid: 2520 cpu: 10.0%
  2: mem: 279.7 MiB (1.7%) command: firefox pid: 2779 cpu: 3.3%
  3: mem: 168.9 MiB (1.0%) command: Xorg pid: 1531 cpu: 1.6%
  4: mem: 154.2 MiB (0.9%) command: firefox pid: 2685 cpu: 0.4%
  5: mem: 136.2 MiB (0.8%) command: xfwm4 pid: 1673 cpu: 0.3%
  Processes: 300 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: N/A tool: systemctl
  Compilers: clang: 19.1.7 alt: 20 gcc: 15.1.1 alt: 14 Shell: N/A (sudo)
    running-in: pty pts/0 inxi: 3.3.38
Insufficient information.
What did change?
Just the mainboard?
Is the BIOS/UEFI of the new one set up the same as the old one?
(Bios vs UEFI or CSM)
Does the very same disk (HDD or NVME or other SSD) still boot on the old, but not on the new?
Are you booting from the same disk as before?
Different graphics hardware on the new vs old?
What does that mean?
That you are trying to boot a system of which you assume, but don’t know, that it works?
Are those efiberrors or grub errors?
Well it should either be the uefi and variables, or the integrated video. Check the uefi settings (the prerequisites for running manjaro -uefi,no csm,no raid,acpi,no secure boot),check the boot order and menu. Reinstalling grub will also update the variables.
On the other hand if it is the video, you can check mkinit hooks and boot line - insert or remove kms hook, remove plymouth. Regenerate mkinit, update grub.
That will be the troubleshooting algorithm, say if you need help with a particular step.
Yes, only the mainboard changed. It’s actually the same one as before, because my old one broke.
I am booting from the same disk and the graphics hardware is the same.
Two days ago, I updated my System, which I initially assumed to have potentially caused the issue, which is why i loaded a Timeshift backup, which didn’t help.
lets have the talk :wink:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the 3 dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
  1. Or we can try to play hide and seek :wink:
    Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
check BIOS/UEFI firmware settings … they should match what was there before
or
the new board is as broken as the old one … :man_shrugging:
That is all that can be deduced from the info provided.
Can you boot from USB? A Manjaro ISO - or any other Linux live system?
I am struggling to actually reinstall grub. I have tried to, but when I run grub-install through chroot it says: ‘grub-install: error: cannot find the EFI directory.’
I have looked up solutions for this, but they didn’t work.
I will add my inxi output soon, to see if that helps.
I am in a live USB right now, and I’ve already adjusted the UEFI firmware settings as far as I can tell.
I have attached my inxi output to the post now, so maybe that helps?
The inxi is not from chroot. Which might explain why you cannot reinstall grub - EFI partition is not mounted.
I think there was a guide somewhere in the forum how to chroot btrfs, i do not use that filesystem.
I have found an online solution to install grub that worked, but now it just goes into grub rescue mode with
error: symbol 'grub_cli_set_auth_needed' not found.
Also, here is an inxi from inside the actual chroot
  System RAM: total: 16 GiB available: 15.55 GiB used: 2.35 GiB (15.1%)
    bus-ID: 00:01.0
    bus-ID: 00:1c.3
    bus-ID: 00:1c.4
    bus-ID: 00:1c.5
    bus-ID: 00:1c.6
    bus-ID: 00:1c.7
    bus-ID: 00:1e.0
    bus-ID: 03:00.0
  Speed (MHz): avg: 550 min/max: 550/4120 boost: enabled
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 550 2: 550 3: 550 4: 550 5: 550
    6: 550 bogomips: 43219
    xtopology
    bits)
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.27 TiB used: 372.04 GiB (16.0%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR311 temp: 36.9 C
  SMART: yes health: PASSED on: 302d 4h cycles: 461
    read-units: 19,634,673 [10.0 TB] written-units: 12,991,026 [6.65 TB]
    serial: <filter> fw-rev: CC43 temp: 33 C
  SMART: yes state: enabled health: PASSED on: 2y 291d 2h cycles: 997
  SMART: yes state: enabled health: PASSED on: 2y 286d 6h cycles: 987
    read: 84906 GiB written: 38639 GiB
    fw-rev: 1.00
    dev-links: cdrom
    used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
  ID-3: /dev/sdb3 maj-min: 8:19 size: 8.8 GiB fs: swap label: N/A
  ID-4: /dev/sdc1 maj-min: 8:33 size: 3.71 GiB fs: N/A
  ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: N/A label: MISO_EFI
    uuid: E85C-D58C
    serial: <filter>
    serial: <filter>
  System Temperatures: cpu: 53.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
    mem: 42.0 C
Processes:
  CPU top: 5 of 338
  1: cpu: 20.6% command: firefox pid: 3896 mem: 439.9 MiB (2.7%)
  2: cpu: 14.0% command: firefox pid: 4098 mem: 275.9 MiB (1.7%)
  3: cpu: 2.4% command: Xorg pid: 1534 mem: 173.0 MiB (1.0%)
  4: cpu: 1.2% command: firefox pid: 4003 mem: 138.7 MiB (0.8%)
  5: cpu: 1.0% command: [kworker/u26:0-events_power_efficient] pid: 57
  Memory top: 5 of 338
  1: mem: 439.9 MiB (2.7%) command: firefox pid: 3896 cpu: 20.6%
  2: mem: 275.9 MiB (1.7%) command: firefox pid: 4098 cpu: 14.0%
  3: mem: 173.0 MiB (1.0%) command: Xorg pid: 1534 cpu: 2.4%
  4: mem: 140.1 MiB (0.8%) command: xfwm4 pid: 1672 cpu: 0.5%
  5: mem: 138.7 MiB (0.8%) command: firefox pid: 4003 cpu: 1.2%
  Processes: 338 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    Shell: u25:1-async (sudo) default: Bash v: 5.2.37 running-in: kthreadd
    inxi: 3.3.38```
Seems not limited to Manjaro;
Whatever the cause, the mainboard likely isn’t part of it.
can you from USB iso live manjaro ,
use UEFI detect > select your disk
then open a terminal
sudo mount -a
sudo lsblk -fs
check at this point that /boot/efi is your disk , not usb live iso
if ok retry for grub-install
after reboot go in UEFI motherboard and select your disk ( it should be manjaro )
This may or may not have anything to do with your boot problem but it looks like your memory module is mounted in the wrong DIMM slot. If you look at your motherboard manual, you will see a diagram of where the first DIMM should be installed.
