Error: symbol 'grub_cli_set_auth_needed' not found
I have struggled quite a bit with grub recently.
Here is my previous issue.
Now my PC goes into grub rescue mode, with this error:
error: symbol 'grub_cli_set_auth_needed' not found.
Here’s my inxi:
  Kernel: 6.12.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2503 quiet
    systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  Desktop: Xfce v: N/A wm: xfwm4 with: xfce4-panel tools: xfce4-screensaver
    dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop System: Micro-Star product: MS-7C56 v: 6.0 serial: N/A
    Chassis: type: 3 v: 6.0 serial: N/A
  Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0 serial: <filter>
    uuid: 2854a392-e160-1712-ab9a-345a603bd601 UEFI: American Megatrends LLC.
    v: A.I0 date: 07/13/2024
  System RAM: total: 16 GiB available: 15.55 GiB used: 2.35 GiB (15.1%)
  Array-1: capacity: 128 GiB slots: 4 modules: 1 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: no module installed
  Device-3: Channel-B DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-16GVK serial: N/A
  Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
    bus-ID: 00:01.0
  Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
    bus-ID: 00:1c.3
  Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
    bus-ID: 00:1c.4
  Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
    bus-ID: 00:1c.5
  Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
    bus-ID: 00:1c.6
  Slot: 5 type: PCIe status: in use info: J8D1 length: short volts: 3.3
    bus-ID: 00:1c.7
  Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
    bus-ID: 00:1e.0
  Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3
    bus-ID: 00:03.1 children: 1: 2b:00.0 class-ID: 0604 type: bridge children:
    1: 2c:00.0 class-ID: 0604 type: bridge children: 1: 2d:00.0 class-ID: 0300
    type: display 2: 2d:00.1 class-ID: 0403 type: audio
  Slot: 14 type: PCIe status: available info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:1f.7
  Slot: 128 type: PCIe status: in use info: J3708 length: short volts: 3.3
    bus-ID: 03:00.0
  Slot: 134 type: PCIe status: available info: J3703 length: short
  Slot: 135 type: PCIe status: available info: J3702 length: short
  Slot: 132 type: PCIe status: available info: J3707 length: short
  Slot: 137 type: PCIe status: in use info: J3701, M.2 length: short
    volts: 3.3 bus-ID: 03:09.0
  Info: model: AMD Ryzen 5 3500X socket: AM4 bits: 64 type: MCP arch: Zen 2
    gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 smt: <unsupported> cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 550 min/max: 550/4120 boost: enabled
    base/boost: 3600/4100 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 550 2: 550 3: 550 4: 550 5: 550
    6: 550 bogomips: 43219
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: spec_rstack_overflow mitigation: SMT disabled
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
    XT/6750 XT / 6800M/6850M XT] vendor: Sapphire driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2,
    HDMI-A-1, Writeback-1 bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: xfwm4 driver: X: loaded: amdgpu unloaded: modesetting,radeon
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
  Monitor-1: DP-3 model: 27E1Q serial: <filter> built: 2021 res: 2560x1440
    dpi: 108 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.200 y: 0.690
    blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1600x900,
    1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x576,
    720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi
    inactive: wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.0.5-arch1.1
    note: incomplete (EGL sourced) renderer: AMD Radeon RX 6700 XT (radeonsi
    navi22 LLVM 19.1.7 DRM 3.61 6.12.28-1-MANJARO), llvmpipe (LLVM 19.1.7 256
    bits)
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.28-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: n/a (root, process) with:
    1: wireplumber status: active 2: pipewire-alsa type: plugin 3: pw-jack
    type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: off with:
    tools: pacat,pactl,pavucontrol
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 2a:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.27 TiB used: 372.04 GiB (16.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR311 temp: 36.9 C
  SMART: yes health: PASSED on: 302d 4h cycles: 461
    read-units: 19,634,673 [10.0 TB] written-units: 12,991,026 [6.65 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    family: BarraCuda 3.5 (CMR) size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC43 temp: 33 C
  SMART: yes state: enabled health: PASSED on: 2y 291d 2h cycles: 997
    read: 68.35 TiB written: 124.77 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8480G
    family: Driven SSDs size: 447.13 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 62B3 temp: 35 C
  SMART: yes state: enabled health: PASSED on: 2y 286d 6h cycles: 987
    read: 84906 GiB written: 38639 GiB
  ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Cruzer Blade
    size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 1.00
  Optical-1: /dev/sr0 vendor: ■■■■■■■■ model: DVD-RAM SW830 rev: 1.00
    dev-links: cdrom
  ID-1: / raw-size: 438.03 GiB size: 430.09 GiB (98.19%)
    used: 372.03 GiB (86.5%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
    maj-min: 8:18 label: N/A uuid: 1ac35c4b-154d-4d98-94b4-2d5193b3401e
    used: 304 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    label: NO_LABEL uuid: 61E7-70C5
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 931.51 GiB fs: btrfs label: speed
    uuid: 4f066a13-a950-486d-8a25-b69c1fa9ec94
  ID-2: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: steam
    uuid: 8429e1cf-59ff-4c60-8719-afef771111fb
  ID-3: /dev/sdb3 maj-min: 8:19 size: 8.8 GiB fs: swap label: N/A
    uuid: 10f62d63-c416-461c-9990-b380d99d2019
  ID-4: /dev/sdc1 maj-min: 8:33 size: 3.71 GiB fs: N/A
    label: MANJARO_XFCE_2503 uuid: 2025-05-26-07-03-28-00
  ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: N/A label: MISO_EFI
    uuid: E85C-D58C
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-2.3:4 info: SanDisk Cruzer Blade type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5567 class-ID: 0806
    serial: <filter>
  Device-2: 1-7:3 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c56 class-ID: 0300
    serial: <filter>
  Device-3: 1-10:5 info: SINOWEALTH Game Mouse type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:1007 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Microdia USB DEVICE type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 0c45:7698 class-ID: 0301
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 53.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
    mem: 42.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: 2474 pm: dpkg pkgs: 0 pm: pacman pkgs: 2432 libs: 561
    tools: pamac,yay pm: flatpak pkgs: 42
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    7: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    8: https://manjaro.ynh.ovh/stable/$repo/$arch
    9: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    10: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 338
  1: cpu: 20.6% command: firefox pid: 3896 mem: 439.9 MiB (2.7%)
  2: cpu: 14.0% command: firefox pid: 4098 mem: 275.9 MiB (1.7%)
  3: cpu: 2.4% command: Xorg pid: 1534 mem: 173.0 MiB (1.0%)
  4: cpu: 1.2% command: firefox pid: 4003 mem: 138.7 MiB (0.8%)
  5: cpu: 1.0% command: [kworker/u26:0-events_power_efficient] pid: 57
    mem: 0.00 MiB (0.0%)
  Memory top: 5 of 338
  1: mem: 439.9 MiB (2.7%) command: firefox pid: 3896 cpu: 20.6%
  2: mem: 275.9 MiB (1.7%) command: firefox pid: 4098 cpu: 14.0%
  3: mem: 173.0 MiB (1.0%) command: Xorg pid: 1534 cpu: 2.4%
  4: mem: 140.1 MiB (0.8%) command: xfwm4 pid: 1672 cpu: 0.5%
  5: mem: 138.7 MiB (0.8%) command: firefox pid: 4003 cpu: 1.2%
  Processes: 338 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.17 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: N/A tool: systemctl
  Compilers: clang: 19.1.7 alt: 20 gcc: 15.1.1 alt: 14
    Shell: u25:1-async (sudo) default: Bash v: 5.2.37 running-in: kthreadd
    inxi: 3.3.38
I appreciate any help :]
It seems a common issue of late;
I haven’t noticed any mentions of the problem with Manjaro. Perhaps you are the first.
All I can suggest for the time being is to keep monitoring this thread and also the Update announcement topics.
Hopefully more information will be forthcoming.
In the meantime, you might wish to boot into your BIOS and make sure Manjaro’s GRUB is properly selected as the first in boot order.
The boot order is correct I think ;(
So what, am I just locked out until it gets fixed?
At least until someone responds with deeper knowledge of the issue; or, at least, moreso than yours truly.
It might be worth checking other recent search results, as well as those I provided. Perhaps you will find something useful.
You can also try installing refind as boot manager.
A good idea.
At least this should allow easy access to the system until the problem with GRUB can be identified and corrected.
@mattus
To do this, you would need to boot from a Manjaro Installer USB (or Ventoy USB) and enter a chroot environment.
The following assumes you use EXT4 filesystems, and not BTRFS; Use the terminal app from the Live Installer;
1. Enter a chroot environment :
sudo manjaro-chroot -a
sudo isn’t required in the chroot environment because you are already the root user.
2. Install refind from the Manjaro repo:
pacman -S refind
3. Run the script to install refind to the #ESP:
refind-install
The script should make refind the default bootloader;
If it doesn’t, run:
refind-mkdefault
You can now exit chroot and reboot; all being well, you should land at the refind boot screen (icons are clickable with mouse, or navigate with the keyboard arrow buttons).
One of the Manjaro entries on the refind screen will allow you to boot the kernel stub, bypassing GRUB completely. The other will try to chainload GRUB, if possible.
I’d suggest bypassing GRUB.
While this doesn’t immediately solve your issue, it will at least give you access to your system, until there’s a cure.
I hope this helps in the meantime.
Quick Update:
The boot order actually was incorrect. I have gotten to the startup screen, but it gets stuck.
Installing Refind, according to your instructions at least either hasn’t worked or didn’t do anything.
Could you expand on that? What exactly didn’t work?
Did it boot to the refind screen, or did it not? If it did, did clicking the entry icon fail?
If refind did not show at all, did you check that it was first in boot order? It needs to be, otherwise the exercise is pointless.
There is a hint in the refind docs:
Warning: When refind-install is run in chroot (e.g. in live system when installing Arch Linux) /boot/refind_linux.conf is populated with kernel options from the live system not the one on which it is installed. Edit /boot/refind_linux.conf and make sure the kernel parameters in it are correct for your system, otherwise you could get a kernel panic on your next boot. See #refind_linux.conf for an example file.
I guess this requires some manual modification. I couldn’t manage setting the required kernel parameters.
I recall choosing to edit refind_linux.conf once a long time ago (to bypass Grub, and specifically use kernel 6.1, I think). I did edit it manually, but usually if you use the refind-install script, that’s set automatically.
This is the /boot/refind_linux.conf from a VM I installed rEFInd on last week. In this case it used kernel 6.6 which was installed by default; I removed the UUIDs for brevity:
"Boot with standard options" "root=UUID=xxxx... rw quiet splash resume=UUID=xxxx... udev.log_priority=3"
"Boot to single-user mode"   "root=UUID=xxxx... rw quiet splash resume=UUID=xxxx... udev.log_priority=3"
"Boot with minimal options"  "ro root=/dev/nvme0n1p2"
