So, I have two OSs: OpenSUSE and Manjaro and I need the os-prober to use one grub menu but every time it types me to create a folder aka mount but when I re-create grub then this folder removes and I see this error again
Found linux image: /boot/vmlinuz-5.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
mount: /var/lib/os-prober/mount: mount(2) system call failed: No such file or directory.
Found openSUSE Tumbleweed on /dev/sda3
done
When asking questions in the forum it is most helpful to everyone for you to provide some basic information.
When sharing information to either give or receive assistance, please be aware of the following:
1 ) In almost every situation not explicitly involving appearance, Text is preferred over Images.
2 ) When providing code or text output, please format it so the content is easy to read.
How to Format “Code” in the Forum
Its easy to make your text and code easy on the eyes
Firs…
Please, post
inxi -Fxxxza --no-host
sudo parted -l
sudo fdisk -l
sudo efibootmgr -v
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=eed5f38c-dcb4-4562-808f-d9b67c6267e0 rw quiet splash apparmor=1
security=apparmor resume=UUID=5ec7e255-ac6a-4ba3-b01e-39a199ea6cd5
udev.log_priority=3
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Desktop System: LENOVO product: 10US000BRU v: V530-22ICB AIO
serial: <filter> Chassis: type: 13 serial: <filter>
Mobo: LENOVO model: 313D v: No DPK serial: <filter> UEFI: LENOVO v: M20KT32A
date: 05/31/2018
Info: 6-Core model: Intel Core i5-8400T bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE
L2 cache: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20409
Speed: 858 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 858 2: 858 3: 824
4: 871 5: 892 6: 887
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e92
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus ID: 1-7:6
chip ID: 174f:2425 serial: <filter>
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: i915
note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 3000 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:3166
Local Storage: total: 931.51 GiB used: 8.57 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: LCM2
ID-1: / raw size: 65.97 GiB size: 64.43 GiB (97.67%) used: 8.26 GiB (12.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw size: 1.53 GiB size: 1.53 GiB (99.80%) used: 10.4 MiB (0.7%)
fs: vfat dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw size: 136.58 GiB size: 133.44 GiB (97.70%) used: 303.7 MiB (0.2%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
ID-1: swap-1 type: partition size: 7.01 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 231 Uptime: 3m wakeups: 0 Memory: 7.63 GiB used: 1.82 GiB (23.9%)
Init: systemd v: 247 Compilers: gcc: N/A Packages: pacman: 1177 lib: 366
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.2.01
Model: ATA ST1000LM035-1RK1 (scsi)
Disk /dev/sda: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
7 1049kB 1648MB 1647MB fat32 msftdata
2 1648MB 577GB 575GB ext4
3 577GB 766GB 189GB btrfs
1 766GB 837GB 70.8GB ext4
5 837GB 844GB 7532MB linux-swap(v1) swap
6 844GB 991GB 147GB ext4
4 991GB 1000GB 9449MB linux-swap(v1) swap
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: ST1000LM035-1RK1
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: F5EE70F0-67A3-D348-AF2B-4EEE43E6497A
Device Start End Sectors Size Type
/dev/sda1 1495578624 1633925119 138346496 66G Linux filesystem
/dev/sda2 3219456 1127184383 1123964928 535.9G Linux filesystem
/dev/sda3 1127184384 1495578623 368394240 175.7G Linux filesystem
/dev/sda4 1935065126 1953520063 18454938 8.8G Linux swap
/dev/sda5 1633925120 1648635903 14710784 7G Linux swap
/dev/sda6 1648635904 1935065125 286429222 136.6G Linux filesystem
/dev/sda7 2048 3219455 3217408 1.5G Microsoft basic data
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0003,0024,0025,0019,0001,0023,0022,000F,0000,0002
Boot0000* ubuntu VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0001* opensuse-secureboot VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0002* debian VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0003* Manjaro HD(7,GPT,fca31bfb-6c2d-d648-90bb-b0757efd4f1c,0x800,0x311800)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot000F* CD/DVD Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0019* Generic Usb Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0022* Generic Usb Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0023* CD/DVD Device VenHw(99e275e7-75a0-4b37-a2e6-c5385e6c00cb)
Boot0024* UEFI OS HD(7,GPT,fca31bfb-6c2d-d648-90bb-b0757efd4f1c,0x800,0x311800)/File(\EFI\BOOT\BOOTX64.EFI)..BO
Boot0025* opensuse HD(7,GPT,fca31bfb-6c2d-d648-90bb-b0757efd4f1c,0x800,0x311800)/File(\EFI\OPENSUSE\GRUBX64.EFI)..BO
Your ESP (/dev/sda7) should have ESP and BOOT flag, major problem is probably that OpenSUSE is on a btrfs formatted partition…
Hmm… OpenSUSE uses BTRFS partition by default for snapper. Is there a way to fix os-prober in my case?
You can try to start Manjaro with /etc/grub.d/40_custom
and commenting out os-prober.
This will start the bootloader of Manjaro afaik and not manjaro entry direct.
If openSuse or Manjaro update kernels, otherwise there will be much work to repair…
EDIT:
look for: “chainloader”
(Can't boot into windows after updating )
system
Closed
17 January 2021 15:17
7
