Just removing Python2 isn’t a solution for this issue as many things still depend on it, such as Gimp plugins. Luckily I was able to remove standard Gimp package and reinstall it with plugins as Flat packages.
I’m unable to install Python2 from AUR even with correct OpenSSL version installed:
No, I don’t use AUR. My python2 package is left from the old system updates. That’s fine until I found the same problem in this thread in a recent pacman update. What should I do except removing python2 package…
Well, you are using AUR if you have python2 installed.
Look, it’s your job to figure that out. Nobody forced you to use arch-based distro. So if you want to use it, then learn how to maintain it. This is not windows, you have to know and do some stuff yourself.
All you need is already written in wikis and other documentation. So I don’t understand why would it need to be repeated to individuals on this forum each and every week ad nauseam.
2 weeks ago it was ceph-lib, week after python2, now there will be 20 people asking about openssl - every 8 hours there will be another topic.
Can anyone search and read anything by themselves anymore?
This is so stupid my head hurts (note that people don’t actually read AUR comments anyway). A “workaround” is DON’T REBUILD PYTHON2!
Where do you see an extra patch? Please… look at PKGBUILD which patches are applied. And then download gentoo’s p15 and p16 patch revisions and compare those patches.
Your usecase perhaps but python2 went out of service almost 2 years ago - there is no updated systems which uses python2 anymore (that is - unless customised - but then you know all about it)
Python2 is out of service - deprecated - as in sunsetted - no more maintenance unless custom build - but then you know all about it.
That depends on your branch - if you are on stable - you are using 1.0 - testing and unstable has 1.1
