If you don’t need python2 it can be removed. As others have mentioned it was discontinued in 2020.
If you have a particular use case that you need it for, and you are happy to use the AUR, a work around has been posted here:
So after I showed you how stupid that “workaround” is, you will still post it to others? I consider this malice.
