curl https://upwork-usw2-desktopapp.upwork.com/webapp/scripts/main.js
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to upwork-usw2-desktopapp.upwork.com:443
How can i fix this. i’ve noticed this when i was tying to use UpWork Desktop App, so i reported it and they told me to run that script. i did and showed them the error and they told me the issue is on my side.
It appears that the connection is interrupted or otherwise broken or unreliable
midway during the TLS handshake.
I do not have the knowledge to tell what the reason might be.
Don’t you think it is anything to do with ISP?.
because i come from Ubuntu, i used Ubuntu for few years, then suddenly i started to get problem with Internet. (Like i would get an error saying not internet connection even when i’m browsing the same internet with my phone)
Cave!
This is just my guess!
This, to me, looks like something in between you and your target
is interrupting the connection attempt.
I do not think that this is due to software on your end - and the other end works as well,
as evidenced by me succeeding to get the file
and as evidenced by you being able to get files from other locations (earlier in this thread).
I have no real idea how or why this would or could happen for this specific location.
… not necessarily your ISP - there is a lot of network after them which they do not control
The way you change dns servers used by NetworkManager is not by editing /etc/resolv.conf
It is done by changing the “Method” tab from “Automatic DHCP” to “Automatic DHCP - Addresses only”
and then putting your nameservers, separated by comma and no whitespace in between
in the “DNS Servers” field
For IPv6, I use the “Method” “Ignore” instead of “Disabled” - don’t know whether that makes a difference.
