Openshot Problem after upgrading packages
After upgrading 126 packages October 18th. I can not start Openshot. If I try to start it from a terminal I get the following message
openshot-qt %F or /usr/bin/openshot-qt
Loaded modules from: /usr/lib/python3.9/site-packages/openshot_qt
INFO app: ------------------------------------------------
INFO app:             Tue Oct 19 09:11:22 2021
INFO app:               Starting new session
ERROR app: OpenShotApp::Import Error
  File "/usr/lib/python3.9/site-packages/openshot_qt/classes/app.py", line 99, in __init__
    from classes import settings, project_data, updates
  File "/usr/lib/python3.9/site-packages/openshot_qt/classes/project_data.py", line 48, in <module>
    import openshot
  File "/usr/lib/python3.9/site-packages/openshot.py", line 15, in <module>
    import _openshot
ImportError: /usr/lib/libopenshot.so.21: undefined symbol: _ZN2cv3dnn14dnn4_v202106083Net20setPreferableBackendEi
  File "/usr/bin/openshot-qt", line 33, in <module>
    sys.exit(load_entry_point('openshot-qt==2.6.1', 'gui_scripts', 'openshot-qt')())
  File "/usr/lib/python3.9/site-packages/openshot_qt/launch.py", line 186, in main
    app = OpenShotApp(argv)
    import openshot
    import _openshot
INFO app:             OpenShot's session ended
INFO app: ================================================
I use Stable. I have tried
sudo pamac build openshot-git and get this.
ERROR: An error occurred in build().
Afbryder…
Finished with result: exit-code
Main processes terminated with: code=exited/status=4
Service runtime: 29.162s
CPU time consumed: 26.469s
I do have the same issue.
Don’t use sudo with pamac!
Try a different AUR helper like paru or yay.
yay openshot: Same result, I can not start openshot :frowning:
openshot-git might work, but you need compile it with some AUR helper (yay, paru etc.) or makepkg.
Somehow libopenshot 0.2.7-2 didn’t make it into the last stable snap. I’ve just pushed it.
Now i works. Thanks a lot.
