OpenRazer on Manjaro KDE not working
Hey, after years of Logitech I bought Razer products (Razer Huntsman Elite TKL and Razer Viper Ultimate) because I use Windows only for gaming and mainly Linux. With internal memory I thought I can set up the keyboard and the mouse and don’t need any software anymore, but thats wrong. I found OpenRazer and both devices are supported.
  1. run sudo gpasswd -a $USER plugdev
  2. install AUR (en) - openrazer
  3. reboot
  4. install RazerGenie GitHub - z3ntu/RazerGenie: Qt application for configuring your Razer devices under GNU/Linux.
First run it found 3 devices (third one is the dock for the mouse) but just show ID or serial number and after reboot “no devices found” :confused:
Kernel 5.14 Plasma 5.22.5
Mouse wireless with dock
Keyboard over USB
Try to read this? Troubleshooting · openrazer/openrazer Wiki · GitHub
Strange… after lsusb | grep 1532 nothing happen, like its loading but never end :confused:
Now lsusb even dont work… after reboot I try lsusb and find all devices but still it’s not working
Bus 001 Device 003: ID 1532:0243 Razer USA, Ltd Huntsman Tournament Edition
Bus 001 Device 005: ID 1532:007e Razer USA, Ltd RC30-030502 Mouse Dock
Bus 001 Device 004: ID 1532:007b Razer USA, Ltd RC30-0305 Gaming Mouse Dongle [Viper Ultimate (Wireless)]
Came across this issue with a RZ03-0203 Gaming Keyboard [BlackWidow Chroma V2] .
After those steps the device wasn’t recognized so used polychromatic throubleshoot and checked the red flags. Was super useful and easy to see the issues I was having and the reasons so, In my case:
$ dkms install -m openrazer-driver/3.1.0
$ sudo pacman -S linux515-headers
Unplug the keyboard, plug it again and restart openrazer-daemon and voila!
I hope that helps some how
For reference: Troubleshooting · openrazer/openrazer Wiki · GitHub
If somebody need help, here u go
Hey
I already ask for help and still can’t set it up.
Thread is closed and I find a way but still can’t set it up on Manjaro but on EndeavourOS I can, so maybe this time somebody can help me.
What I did on EndeavourOS:
1. sudo pacman -S linux-headers
2. install
openrazer-daemon
openrazer-driver-dkms
openrazer-meta
python-openrazer
polychromatic
3. sudo gpasswd -a USERNAME plugdev
4. Reboot
After that I can open Polychromatic and anything work out of box.
On Manjaro, when I type in “sudo pacman -S linux-headers” it ask me “which one” and if I take “linux516-headers” its not working.
I test KDE on EndeavourOS because on Manjaro its still full of bugs with multi monitor setup and Radeon RX6000 GPU. Now I use Manjaro GNOME with 5.16 Kernel.
For kernel 5.16 you need to install linux516-headers and same terminology is used for other kernels also. Can you switch to 5.15 kernel instead and try there. Also share some sys info:
If it work on EndeavourOS it is a no-brainer which one to use.
@ishaan2479 I already try it but I still can not understand, whats the problem and why the Terminal on EndeavourOS ask me this question.
@linux-aarhus for a noob like me Manjaro is much better (UI and dont need Terminal). I just try it because I read “KDE on Manjaro is broken with dual monitor setup”
