Hello,
I am having GPU Problems that I can’t seem to fix myself. I have a Nvidia GT 1030 GPU installed in my PC and am using the video-nvidia-390xx drivers. Since support for these drivers seems to have been dropped in the latest kernel, I switched to kernel 5.4 LTS. Nonetheless, when I run glinfo, the default OpenGl renderer seems to be llvm:
$ glinfo | grep RENDERER
GL_RENDERER: llvmpipe (LLVM 11.0.1, 256 bits)
So far, none of the suggested solutions I found on this forum have worked for me.
Hello,
Like what solution, this for instance ?
It shouldn’t … Try to auto install
sudo mhwd -a pci nonfree 0300
and see if the nvidia.conf will be filled … reboot the system after that. The thing is, in the announcement wiki was mentioned to backup the old nvidia.conf
If you do not have video-vesa installed, then drop the video-nvidia-390xx and install (trough mhwd) the video-nvidia driver.
In short, you will have to:
sudo mhwd -r pci video-vesa
sudo mhwd -r pci video-nvidia-390xx
sudo mhwd -i pci video-nvidia
Thanks for your response.
I red the mentioned thread and because of it I switched to kernel 5.4 (from 5.10).
Should I try the suggested steps of uninstalling any nvidia named program and reinstalling them?
I tried your suggested commands but ran into an error:
$ sudo mhwd -i pci video-nvidia
Error: config ‘video-nvidia’ does not exist!
What is the output of mhwd -l from terminal ?
Also mhwd -li
and inxi -Fazy
mhwd -l:
0000:01:00.0 (0300:10de:1d01) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
mhwd -li:
Installed PCI configs:
inxi -Fazy:
Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=5b93264e-4bce-4c99-80b7-482a56d2d9e2 rw quiet apparmor=1
security=apparmor resume=UUID=0a4fb2c9-e835-4933-aace-1e3c7622a4f6
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85-PRO GAMER v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2103 date: 08/19/2014
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Quad Core model: Intel Core i5-4690 bits: 64 type: MCP arch: Haswell
family: 6 model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
bogomips: 27947
Speed: 1394 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1394 2: 1376
3: 1393 4: 1392
Type: l1tf
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ZOTAC driver: nvidia
v: 390.141 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1d01
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: HDMI-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: llvmpipe (LLVM 11.0.1 256 bits) v: 4.5 Mesa 20.3.3
compat-v: 3.1 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: NVIDIA GP108 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb8
Device-3: Sennheiser Sennheiser PC 8.2 USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-10.3:4 chip ID: 1395:0099
serial: <filter>
Sound Server: ALSA v: k5.4.89-1-MANJARO
Device-1: Intel Ethernet I217-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
port: f040 bus ID: 00:19.0 chip ID: 8086:153b
Local Storage: total: 1.36 TiB used: 114.23 GiB (8.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 4B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1A01
ID-1: / raw size: 448.4 GiB size: 440.36 GiB (98.21%)
used: 114.23 GiB (25.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 215 Uptime: 1h 28m wakeups: 6 Memory: 15.58 GiB
used: 3.47 GiB (22.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1660 pacman: 1653 lib: 430 flatpak: 0 snap: 7 Shell: Bash v: 5.1.0
running in: tilix inxi: 3.2.02
Ok, not sure, but it seems the
jayce.m:
GeForce GT 1030
is only supported by the video-nvidia-390xx driver. I wonder what is the content of /etc/X11/mhwd.d/nvidia.conf
and if /etc/modprobe.d/mhwd-gpu.conf has this content in it:
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
and if the file /etc/modules-load.d/mhwd-gpu.conf has this:
nvidia
nvidia-drm
/etc/X11/mhwd.d/nvidia.conf :
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 390.141 (dvs-builder@U64-P08-12) Mon Dec 28 16:12:07 UTC 2020
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 390.141 (dvs-builder@U64-P08-12) Mon Dec 28 16:13:08 UTC 2020
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "AUS BE27A"
HorizSync 30.0 - 120.0
VertRefresh 49.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GT 1030"
Option "NoLogo" "1"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Extensions"
Option "COMPOSITE" "Enable"
EndSection
Section "InputClass"
Identifier "Keyboard Defaults"
MatchIsKeyboard "yes"
Option "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
/etc/modprobe.d/mhwd-gpu.conf has the said content in it, /etc/modules-load.d/mhwd-gpu.conf does too.
Looks good to me overall, but not quite sure what would be wrong on your end.
Run this command and reboot:
sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
maybe force the reinstall of the driver with:
sudo mhwd -f -i pci video-nvidia-390xx
pobrn
1 February 2021 17:33
9
anon89812132:
jayce.m:
GeForce GT 1030
The device seems to be supported by the latest driver .
@jayce.m Please reinstall mhwd-db by running sudo pacman -Syu mhwd-db, and check if mhwd -l offers video-nvidia. If it does, remove video-nvidia-390xx, and install video-nvidia.
@pobrn thank you, that did the trick
system
Closed
16 February 2021 17:41
11
