I mentioned that it worked when I live booted Nobara 38, another distro.
Currently I’m on a live boot of Nobara and both monitors work.
I’m gonna etch the Manjaro iso to my usb, and get back to you on a live boot of that.
Apologies then. I though for a moment or two that is the name of the new Manjaro release, just now remembered that it’s actually Ultima Thule
Ok, I’m on the GNOME version of Manjaro, booted up using Open Source Drivers, and the second monitor gets detected, but it’s a black screen. I can mouse over it an see the cursor, but other than that, nothing.
Edit:
Booted up on propiretary drivers now, the display doesn’t get detected.
Well, that’s something then. Can you put a background on?
And then, please post the previous outputs again:
I can’t do anything on the second screen. I can drag windows over it, and interact with them blindly, but they don’t show up over there.
mhwd
Warning: config '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
Warning: config '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
inxi
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2213 quiet
systemd.show_status=1 splash driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Desktop System: ASUS product: All Series v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: H81M-PLUS v: Rev X.0x serial: <superuser required>
BIOS: American Megatrends v: 2205 date: 05/26/2015
System RAM: available: 15.49 GiB used: 2.67 GiB (17.2%)
Info: model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 844 high: 979 min/max: 800/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 800 3: 800 4: 979
bogomips: 29608
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
built: 2013 ports: active: VGA-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:041e class-ID: 0380
Device-2: NVIDIA GM206 [GeForce GTX 950] vendor: ASUSTeK driver: nouveau
v: kernel non-free: 530.xx+ status: current (as of 2023-05) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
empty: DVI-D-1,DVI-I-1,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:1402
class-ID: 0300 temp: 38.0 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915,nouveau display-ID: 0
Monitor-1: DP-1 model: Idek Iiyama PL2530H serial: <filter> built: 2020
res: 1920x1080 dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: VGA-1 model: Belinea/Maxdata B1925S1W serial: <filter>
built: 2006 res: 1440x900 dpi: 85 gamma: 1.2 size: 410x256mm (16.14x10.08")
diag: 502mm (19.8") ratio: 15:9, 16:10 modes: max: 1440x900 min: 720x400
API: OpenGL v: 4.3 Mesa 23.0.3 renderer: NV126 direct-render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Device-4: Intel USB PnP Sound Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8086:0808 class-ID: 0300
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 935.25 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Verbatim model: STORE N GO
size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.66
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224FB rev: SB00
dev-links: cdrom
Message: No partition data found.
ID-1: /dev/sda1 maj-min: 8:1 size: 1024 MiB fs: ext4 label: N/A
uuid: c31e556e-5269-4a64-807d-361220d43324
ID-2: /dev/sda2 maj-min: 8:2 size: 913.49 GiB fs: btrfs label: N/A
uuid: 48acbb5a-d95d-4b0c-a0f2-699d3b8d13d4
ID-3: /dev/sda3 maj-min: 8:3 size: 17.02 GiB fs: swap label: swap
uuid: 63ee9f43-6a7d-4599-89b6-bd16cfaa36b5
ID-4: /dev/sdb1 maj-min: 8:17 size: 3.45 GiB fs: iso9660
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: D0A3-C7FC
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-4:2 info: Verbatim Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 18a5:0302 class-ID: 0806
serial: <filter>
Device-2: 3-10:3 info: Intel USB PnP Sound Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: Evision RGB Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 400mA chip-ID: 3299:2736 class-ID: 0301
Device-2: 5-2:3 info: SteelSeries ApS Aerox 3 type: mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1836 class-ID: 0300
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 55.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 913
Processes: 227 Uptime: 3m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1240 libs: 315 tools: gnome-software,pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
I mean’ they DO show up, but I can’t see them. lol
The same. What driver did you boot with? Open-source or proprietary?
I booted up on open source, because on proprietary:
OK, I’m officially stumped. I don’t know what it could be, if it’s not some kind of hardware-related issue…
Sorry!
Yeah, I’d also say that it’s a hardware issue, but that doesn’t explain it working on Nobara 38 or Windows.
Don’t worry about it, this PC is a mortal enemy of mine.
Hello again, after some time of hopping distros, I came to a conclusion that the monitor problem was a GNOME issue. I’m now using the KDE Plasma version, and everything works fine with no tweaking needed. So, if anyone faces the same issue, steer away from GNOME!
