One of two monitors not working
I just installed Manjaro today, and I have 2 monitors, the main one is connected to my Nvidia GPU via display port and works just fine, however the second one, connected to my motherboard is not being detected by the system. It’s stuck on a gray screen with three dots if that helps. I’m new to Arch so I’m not sure what could cause the issue. I installed all the updates that the software manager prompted me to, however it did not fix the issue.
Well, this is Manjaro not Arch, so…
Anyway, please provide the outputs of:
mhwd --list
and
mhwd --list
> 0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:01:00.0 (0300:10de:1402) Display controller nVidia Corporation:
          video-nvidia            2023.03.23               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0380:8086:041e) Display controller Intel Corporation:
inxi
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=c1f38d85-5b3e-4d8c-a8bc-027ad1709495 rw quiet splash apparmor=1
  Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: H81M-PLUS v: Rev X.0x serial: <superuser required>
    BIOS: American Megatrends v: 2205 date: 05/26/2015
  System RAM: total: 16 GiB available: 15.49 GiB used: 2.77 GiB (17.9%)
  Info: model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2901 high: 3703 min/max: 800/3700 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2779 2: 3703 3: 1423
    4: 3702 bogomips: 29608
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
    vendor: ASUSTeK driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: VGA-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:041e class-ID: 0380
  Device-2: NVIDIA GM206 [GeForce GTX 950] vendor: ASUSTeK driver: nvidia
    v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1402 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: nvidia gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
  Monitor-1: VGA-1 mapped: DP-0 model: Belinea/Maxdata B1925S1W
    serial: <filter> built: 2006 res: 1920x1080 dpi: 90 gamma: 1.2
    size: 544x303mm (21.42x11.93") diag: 502mm (19.8") ratio: 15:9, 16:10
    modes: max: 1440x900 min: 720x400
  API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce GTX
    950/PCIe/SSE2 direct-render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio
    vendor: ASUSTeK 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:8c20 class-ID: 0403
  Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
  Device-4: Intel USB PnP Sound Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8086:0808 class-ID: 0300
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.73 status: off tools: pw-cli
    vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 935.25 GiB used: 11.79 GiB (1.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Verbatim model: STORE N GO
    size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.66
    scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224FB rev: SB00
    dev-links: cdrom
  ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 11.79 GiB (1.3%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: c1f38d85-5b3e-4d8c-a8bc-027ad1709495
  ID-1: /dev/sdb1 maj-min: 8:17 size: 3.45 GiB fs: iso9660
  ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: D0A3-C7FC
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 3-4:2 info: Verbatim Flash Drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 18a5:0302 class-ID: 0806
    serial: <filter>
  Device-2: 3-10:3 info: Intel USB PnP Sound Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Evision RGB Keyboard type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 3299:2736 class-ID: 0301
  Device-2: 5-2:3 info: SteelSeries ApS Aerox 3 type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1836 class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 60 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 16%
  Processes: 238 Uptime: 29m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1160 libs: 321 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.28
Also sorry, I thought that Manjaro being Arch based means I could use some knowledge about Arch
Both seem to have a driver…
Please provide the outputs of:
glxinfo | grep server
and
prime-run glxinfo | grep server
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
zsh: command not found: prime-run
Although Manjaro is based on Arch, and a lot of it is the same, and we even recommend the Arch-wiki for a lot of things, it’s not Arch.
Oh okay, sorry about that
No worries, man!
OK, this :point_up: tells me your system is using only the Nvidia card, as you mentioned. But this: :point_down:
…shows both are available and both’s drivers are installed…so I don’t think it’s disabled in BIOS/UEFI, but you can check to confirm.
Because I am stumped…
Or, check in the BIOS/UEFI that the on-board is not primary. (If there is such an option.) And run the above :point_up_2: 2 commands again and see let’s what it spits out then.
Any pointers on where to look? :grin:
yeah… :point_down:
:man_shrugging:
Okay, I’m gonna snoop around and let you know, keep your fingers crossed!
So, I found nothing… But it’s kinda weird, since I don’t recall having this issue on windows or Mint. I never had to tweak anything in bios. I hope someone can find a solution, because I really like Manjaro so far.
Year, I really don’t know what else to do. Originally thought it might be a missing driver, but :point_down:
…shows no hybrid driver available, from what I can see.
So, I don’t know…
That’s a shame, let’s hope someone else might be able to find a solution. The only thing that comes to my mind is a kernel change maybe? If that’s even possible, of course.
You can change to a newer or different kernel, although I highly doubt it will make a difference.
Check here for more information:
You should maybe have a look at Bumblebe and/or Optimus as well.
Ok, so this is odd… I installed bumblebee, and now the second monitor works fine, but the GPU one is stuck on the gray screen… :joy:
Erm…OK.
Well, what happens when you run:
optirun glxgears -info
If it fails, try the following command (from virtualgl):
optirun glxspheres64
Wait, sorry, I tried reinstalling the OS, and now before installing any updates, the screen gets detected, I can mouse over it, but it’s just a black screen.
That’s a good start then. Please provide the output of:
mhwd --listinstalled
and
