One of two monitors not working
mhwd --listinstalled
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
inxi
  Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=f6db8094-8b00-40af-86b9-9358d75dffd1 rw quiet splash apparmor=1
  Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
  Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: H81M-PLUS v: Rev X.0x serial: <superuser required>
    BIOS: American Megatrends v: 2205 date: 05/26/2015
  System RAM: available: 15.49 GiB used: 1.93 GiB (12.5%)
  Info: model: Intel Core i3-4170 bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1400 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1400 2: 1400 3: 1400 4: 1400 bogomips: 29608
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs invpcid invpcid_single lahf_lm lm mca mce
    md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 4th Generation Core Processor Family Integrated Graphics
    vendor: ASUSTeK driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm
    built: 2013 ports: active: VGA-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:041e class-ID: 0380
  Device-2: NVIDIA GM206 [GeForce GTX 950] vendor: ASUSTeK driver: nouveau
    v: kernel non-free: 530.xx+ status: current (as of 2023-05) arch: Maxwell
    code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
    empty: DVI-D-1,DVI-I-1,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:1402
    class-ID: 0300 temp: 40.0 C
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
    compositor: gnome-shell driver: gpu: i915,nouveau display-ID: 0
  Monitor-1: DP-1 model: Idek Iiyama PL2530H serial: <filter> built: 2020
    res: 1920x1080 dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93")
    diag: 623mm (24.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: VGA-1 model: Belinea/Maxdata B1925S1W serial: <filter>
    built: 2006 res: 1440x900 dpi: 85 gamma: 1.2 size: 410x256mm (16.14x10.08")
    diag: 502mm (19.8") ratio: 15:9, 16:10 modes: max: 1440x900 min: 720x400
  API: OpenGL v: 4.3 Mesa 23.0.3 renderer: NV126 direct-render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    chip-ID: 8086:0c0c class-ID: 0403
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-3: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
    class-ID: 0403
  Device-4: Intel USB PnP Sound Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8086:0808 class-ID: 0300
  API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
    vendor: ASUSTeK H81M-C driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 935.25 GiB used: 7.44 GiB (0.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Verbatim model: STORE N GO
    size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2.66
    scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224FB rev: SB00
    dev-links: cdrom
  ID-1: / raw-size: 931.51 GiB size: 915.81 GiB (98.31%) used: 7.44 GiB (0.8%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: f6db8094-8b00-40af-86b9-9358d75dffd1
  ID-1: /dev/sdb1 maj-min: 8:17 size: 3.45 GiB fs: iso9660
  ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: D0A3-C7FC
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 3-4:2 info: Verbatim Flash Drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 200mA chip-ID: 18a5:0302 class-ID: 0806
    serial: <filter>
  Device-2: 3-10:3 info: Intel USB PnP Sound Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Evision RGB Keyboard type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 3299:2736 class-ID: 0301
  Device-2: 5-2:3 info: SteelSeries ApS Aerox 3 type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 400mA chip-ID: 1038:1836 class-ID: 0300
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 40.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 489
  Processes: 220 Uptime: 9m wakeups: 0 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1134 libs: 312 tools: gnome-software,pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.27
OK…sheesh, now my head is hurting…
What happens when you run:
:question:
optirun glxspheres64                                             ✔
zsh: correct 'optirun' to '_optirun' [nyae]? zsh: command not found: optirun
Both of them return this.
Ah! I was under the impression bumblebee is installed, but apparently not:
find-the-command: "optirun" may be found in package "extra/bumblebee"
So install that first:
pamac install bumblebee
…and then try again.
Choose optional dependencies for bumblebee:
1:  bbswitch: switch on/off discrete card
2:  nvidia: NVIDIA kernel driver
3:  virtualgl: alternative back-end for optirun
4:  lib32-virtualgl: run 32bit applications with optirun
5:  lib32-primus: faster back-end for optirun
Enter a selection (default=none):
should I choose any of those?
They being optional, perhaps choose #2, the Nvidia driver.
I haven’t done this before, I only have 1 GPU, so I’m just guessing here.
After installing bumblebee, and rebooting my pc, now only my VGA monitor lights up and works, and this is the output of the commands you mentioned earlier:
[  150.042621] [ERROR]The Bumblebee daemon has not been started yet or the socket path /var/run/bumblebee.socket was incorrect.
[  150.042641] [ERROR]Could not connect to bumblebee daemon - is it running?
Update: Tried removing bumblebee and using optimus, same thing happens. I think I’m gonna have to switch distros.
This may be a good way to find which driver needs to be installed. :rofl:
Then come back and install these in manjaro :innocent:
Or even easyier:
Try with a live-linux (any distro). If your 2nd monitor works, look which driver is active. Then come back into your installation. Someone will be able to help you activate this driver in manjaro.
:footprints:
How can I list the drivers? is it
mhwd --listinstalled?
because I tried installing nobara and when I booted through my usb stick, the second monitor worked
Ok guys. I’m on a live version of Nobara 38, and both the monitors work, how can I see the list of all drivers?
Ok, I’m guessing here, but I have the ouput of lsmod:
Module                  Size  Used by
ufs                   106496  0
hfsplus               172032  0
hfs                   102400  0
minix                  61440  0
vfat                   24576  0
msdos                  20480  0
fat                   102400  2 msdos,vfat
jfs                   258048  0
xfs                  2535424  0
snd_seq_dummy          16384  0
snd_hrtimer            16384  1
nf_conntrack_netbios_ns    16384  1
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nft_fib_inet           16384  1
nft_fib_ipv4           16384  1 nft_fib_inet
nft_fib_ipv6           16384  1 nft_fib_inet
nft_fib                16384  3 nft_fib_ipv6,nft_fib_ipv4,nft_fib_inet
nft_reject_inet        16384  6
nf_reject_ipv4         16384  1 nft_reject_inet
nf_reject_ipv6         24576  1 nft_reject_inet
nft_reject             16384  1 nft_reject_inet
nft_ct                 24576  8
nft_chain_nat          16384  3
nf_nat                 65536  1 nft_chain_nat
nf_conntrack          192512  4 nf_nat,nft_ct,nf_conntrack_netbios_ns,nf_conntrack_broadcast
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
ip_set                 65536  0
nf_tables             356352  229 nft_ct,nft_reject_inet,nft_fib_ipv6,nft_fib_ipv4,nft_chain_nat,nft_reject,nft_fib,nft_fib_inet
nfnetlink              20480  3 nf_tables,ip_set
qrtr                   57344  4
binfmt_misc            28672  1
snd_hda_codec_realtek   192512  1
snd_hda_codec_generic   114688  1 snd_hda_codec_realtek
snd_hda_codec_hdmi     94208  2
intel_rapl_msr         20480  0
snd_hda_intel          65536  6
intel_rapl_common      36864  1 intel_rapl_msr
snd_intel_dspcfg       36864  1 snd_hda_intel
x86_pkg_temp_thermal    20480  0
snd_intel_sdw_acpi     20480  1 snd_intel_dspcfg
intel_powerclamp       16384  0
snd_hda_codec         217088  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
coretemp               20480  0
kvm_intel             458752  0
snd_usb_audio         442368  2
snd_hda_core          139264  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_usbmidi_lib        49152  1 snd_usb_audio
i915                 3850240  3
kvm                  1331200  1 kvm_intel
snd_hwdep              20480  2 snd_usb_audio,snd_hda_codec
irqbypass              16384  1 kvm
snd_rawmidi            53248  1 snd_usbmidi_lib
snd_seq               106496  7 snd_seq_dummy
nouveau              3420160  27
joydev                 28672  0
eeepc_wmi              16384  0
asus_wmi               81920  1 eeepc_wmi
snd_seq_device         16384  2 snd_seq,snd_rawmidi
rapl                   24576  0
snd_pcm               180224  5 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
intel_cstate           24576  0
ledtrig_audio          16384  2 snd_hda_codec_generic,asus_wmi
iTCO_wdt               16384  0
at24                   28672  0
sparse_keymap          16384  1 asus_wmi
intel_uncore          258048  0
intel_pmc_bxt          16384  1 iTCO_wdt
snd_timer              53248  3 snd_seq,snd_hrtimer,snd_pcm
mei_pxp                20480  0
platform_profile       16384  1 asus_wmi
iTCO_vendor_support    16384  1 iTCO_wdt
mei_hdcp               28672  0
rfkill                 40960  4 asus_wmi
snd                   143360  31 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
drm_buddy              20480  1 i915
mxm_wmi                16384  1 nouveau
pktcdvd                69632  0
i2c_algo_bit           20480  2 i915,nouveau
drm_ttm_helper         16384  1 nouveau
soundcore              16384  1 snd
i2c_i801               40960  0
mei_me                 61440  2
ttm                   102400  3 drm_ttm_helper,i915,nouveau
pcspkr                 16384  0
i2c_smbus              20480  1 i2c_i801
drm_display_helper    208896  2 i915,nouveau
mei                   192512  5 mei_hdcp,mei_pxp,mei_me
wmi_bmof               16384  0
lpc_ich                28672  0
cec                    86016  2 drm_display_helper,i915
zram                   32768  2
isofs                  65536  1
squashfs               86016  1
crct10dif_pclmul       16384  1
crc32_pclmul           16384  0
crc32c_intel           24576  2
polyval_clmulni        16384  0
polyval_generic        16384  1 polyval_clmulni
uas                    36864  0
ghash_clmulni_intel    16384  0
r8169                 114688  0
sha512_ssse3           53248  0
usb_storage            86016  2 uas
video                  73728  3 asus_wmi,i915,nouveau
wmi                    45056  5 video,asus_wmi,wmi_bmof,mxm_wmi,nouveau
be2iscsi              192512  0
bnx2i                  81920  0
cnic                   81920  1 bnx2i
uio                    32768  1 cnic
cxgb4i                 69632  0
cxgb4                 688128  1 cxgb4i
tls                   151552  1 cxgb4
cxgb3i                 53248  0
cxgb3                 233472  1 cxgb3i
mdio                   16384  1 cxgb3
libcxgbi              110592  2 cxgb4i,cxgb3i
libcxgb                32768  2 libcxgbi,cxgb3i
qla4xxx               475136  0
iscsi_boot_sysfs       20480  2 be2iscsi,qla4xxx
iscsi_tcp              32768  0
libiscsi_tcp           45056  4 libcxgbi,iscsi_tcp,cxgb4i,cxgb3i
libiscsi               90112  8 be2iscsi,libiscsi_tcp,bnx2i,libcxgbi,iscsi_tcp,qla4xxx,cxgb4i,cxgb3i
scsi_transport_iscsi   192512  7 be2iscsi,libiscsi_tcp,bnx2i,libcxgbi,iscsi_tcp,qla4xxx,libiscsi
loop                   40960  7
v4l2loopback           77824  0
videodev              372736  1 v4l2loopback
mc                     90112  2 videodev,snd_usb_audio
ip6_tables             40960  0
ip_tables              40960  0
i2c_dev                28672  0
fuse                  208896  5
Are the required drivers shown in the lsmod output?
These commands should show it:
and
mhwd
[liveuser@localhost-live ~]$ mhwd --listinstalled
bash: mhwd: command not found...
inxi
  Kernel: 6.3.12-203.fsync.fc38.x86_64 arch: x86_64 bits: 64 compiler: gcc
    v: 2.39-9.fc38 parameters: BOOT_IMAGE=/images/pxeboot/vmlinuz
    root=live:CDLABEL=Nobara-38 rd.live.image quiet rhgb
  Desktop: GNOME v: 44.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 43.0
    Distro: Nobara release 38 (Thirty Eight) base: RHEL 38
  System RAM: available: 15.47 GiB used: 4.83 GiB (31.2%)
    family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x19
  Speed (MHz): avg: 913 high: 1066 min/max: 800/3700 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1066 2: 983 3: 800 4: 804
    bogomips: 29598
    dtherm dts epb ept ept_ad erms est f16c flexpriority fma fpu fsgsbase fxsr
    ht invpcid invpcid_single lahf_lm lm mca mce mmx monitor movbe msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss sse
    sse2 sse4_1 sse4_2 ssse3 syscall tm tm2 tpr_shadow tsc tsc_adjust vme vmx
    vnmi vpid xsave xsaveopt xtopology xtpr
    vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
  Type: srbds status: Vulnerable: No microcode
    class-ID: 0300 temp: 54.0 C
  Display: x11 server: X.Org v: 1.20.14 with: Xwayland v: 23.1.2
    compositor: gnome-shell driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: nouveau gpu: i915,nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3360x1080 s-dpi: 96 s-size: 889x286mm (35.00x11.26")
    s-diag: 934mm (36.77")
  Monitor-1: DP-1 pos: primary,top-right model: Idek Iiyama PL2530H
    serial: <filter> built: 2020 res: 1920x1080 dpi: 90 gamma: 1.2
    size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
  Monitor-2: VGA-1 mapped: VGA-1-1 pos: bottom-l
    model: Belinea/Maxdata B1925S1W serial: <filter> built: 2006 res: 1440x900
    hz: 60 dpi: 89 gamma: 1.2 size: 410x256mm (16.14x10.08")
  API: OpenGL v: 4.3 Mesa 23.1.3 renderer: NV126 direct-render: Yes
    class-ID: 0403
    class-ID: 0403
    lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8086:0808 class-ID: 0300
  API: ALSA v: k6.3.12-203.fsync.fc38.x86_64 status: kernel-api
  Server-1: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Local Storage: total: 935.25 GiB used: 10.53 GiB (1.1%)
    scheme: GPT
    dev-links: cdrom
  ID-1: / raw-size: 25 GiB size: 24.44 GiB (97.75%) used: 10.53 GiB (43.1%)
    fs: ext4 dev: /dev/dm-0 maj-min: 253:0 mapped: live-rw label: N/A uuid: N/A
  Kernel: swappiness: 60 (default) cache-pressure: 50 (default 100)
  ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) priority: 100
    dev: /dev/zram0
  ID-1: /dev/dm-1 maj-min: 253:1 mapped: live-base size: 25 GiB fs: ext4
    label: Anaconda uuid: 3a1a246c-e5f4-41e1-aaaa-67ba448e5174
  ID-2: /dev/sda1 maj-min: 8:1 size: 1024 MiB fs: ext4 label: N/A
    uuid: c31e556e-5269-4a64-807d-361220d43324
  ID-3: /dev/sda2 maj-min: 8:2 size: 913.49 GiB fs: btrfs label: N/A
    uuid: 48acbb5a-d95d-4b0c-a0f2-699d3b8d13d4
  ID-4: /dev/sda3 maj-min: 8:3 size: 17.02 GiB fs: swap label: swap
    uuid: 63ee9f43-6a7d-4599-89b6-bd16cfaa36b5
  ID-5: /dev/sdb1 maj-min: 8:17 size: 3.09 GiB fs: iso9660
  ID-6: /dev/sdb2 maj-min: 8:18 size: 11.6 MiB fs: vfat label: ANACONDA
    uuid: EA04-C3B3
  ID-7: /dev/sdb3 maj-min: 8:19 size: 300 KiB fs: <superuser required>
  Device-1: 1-4:2 info: Verbatim Flash Drive type: mass storage
    serial: <filter>
  Device-2: 1-10:3 info: Intel USB PnP Sound Device type: audio,HID
  Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-4: 3-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 54.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 0
  Processes: 347 Uptime: 14m wakeups: 0 Init: systemd v: 253
  target: graphical (5) default: graphical tool: systemctl Compilers:
  gcc: 13.1.1 Packages: pm: rpm pkgs: N/A note: see --rpm
  tools: dnf,gnome-software,yum pm: flatpak pkgs: 0 Shell: Bash v: 5.2.15
Hmmmm…here:
It shows that your Nvidia card is using the Open-source drivers. So I’m guessing that’s what you selected on startup with the Live Environment?
We need to see the proprietary one’s output and if i t works. Could you please reboot and be sure to select them on startup?
I can’t select them, they just boot up automatically, I don’t get prompted to choose.
That’s…different from what I experienced when I used a Live USB last time…
I am terribly sorry, but if that’s the case, I have absolutely no, nothing, nadda of an idea how to continue…
:sob:
Edit:
It would have, should have been a menu like this:
https://forum.manjaro.org/uploads/default/original/3X/2/6/26435800466e90b118839b80ef2f6e71d84ee5b7.png
I think you missed the part that I live booted Nobara 38…
Edit:
So I’m guessing to live boot Manjaro and select both of the options to see whether any of them work?
You mentioned it worked. But the inxi output showed the Open-source drivers. So we need to see if it works with the proprietary drivers as well. And get the inxi output for that, too.
Nope. The boot choice should be similar, if not the same between that and previous versions.
