Hi,
I need your help guys. I tried finding the issue myself but I’m not knowledgeable enough to sort that one.
I put that here because it’ s an issue that only append once my manjaro is launched. Nor windows neither grub have this issue. I suspect gdm but cannot confirm.
So I have a dual screen setup. One of them (the main one of course) has a obvious red shift since an update like there is pink everywhere.
Can you help me please? It’s a little annoying.
Falav
2 August 2021 07:44
2
Hello, do you have a moon crescent icon on the upper right corner?
Try to see if Night shift mode is enabled. It automatically dims screen brightness/colors depending of the hour if enabled.
No , I disable night shift mode but the issue is still there.
My issue is only concerning one of my 2 displays. The other one is fine.
I even try changing the color balance (in gnome settings) but again it’s a setting that concern the 2 screens together so…not a solution. (or maybe I missed something)
Fabby
2 August 2021 15:54
4
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text .
The output to xrandr would be helpful as well.
Does this happen already before you log in?
Have you tried the redshifted monitor on another computer already? (I.E. Is is a HW problem and the update was just a coincidence)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Hi, thanks for the advices.
The issue is happenning at the login screen too but not at grub. I have a dual boot for windows and it’s not happenning on windows too. I just try on my laptop (which is on manjaro too) and no issue.
$inxi:
Kernel: 5.10.53-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=66aa89b9-efca-49c4-a27d-7a15e20e2d36 rw quiet
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Desktop Mobo: ASUSTeK model: P9X79 WS v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 4802 date: 06/02/2015
RAM: total: 31.3 GiB used: 2.7 GiB (8.6%)
Info: 6-Core model: Intel Core i7-3930K bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2D (45) stepping: 7 microcode: 71A
cache: L2: 12 MiB bogomips: 76873
Speed: 1201 MHz min/max: 1200/3800 MHz Core speeds (MHz): 1: 1201 2: 1201
3: 1201 4: 1201 5: 2083 6: 1856 7: 1201 8: 1201 9: 1201 10: 1201 11: 1201
12: 1201
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 dca de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: CardExpert driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1401 class-ID: 0300
Device-2: Logitech Webcam C210 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 2-1.8.2:4 chip-ID: 046d:0819 class-ID: 0102 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1d20
class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: CardExpert
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:0fba
class-ID: 0403
Device-3: Logitech Webcam C210 type: USB driver: snd-usb-audio,uvcvideo
Device-4: Logitech USB Headset type: USB driver: snd-usb-audio
bus-ID: 2-1.8.6:6 chip-ID: 046d:0a01 class-ID: 0102
Sound Server-1: ALSA v: k5.10.53-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
Device-2: Intel 82574L Gigabit Network vendor: ASUSTeK driver: e1000e
v: kernel port: b000 bus-ID: 0b:00.0 chip-ID: 8086:10d3 class-ID: 0200
IF: enp11s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-9523494e2b53 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth8eb02d4 state: up speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 7.97 TiB used: 260.43 GiB (3.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD40EZRX-00SPEB0
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 0A80 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20EZRX-00D8PB0
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS38 rev: 1.00
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 475.96 GiB size: 467.49 GiB (98.22%)
used: 259.03 GiB (55.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 66aa89b9-efca-49c4-a27d-7a15e20e2d36
ID-2: /boot/efi raw-size: 1001 MiB size: 999 MiB (99.80%)
used: 292 KiB (0.0%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: D88B-BFDE
ID-3: /home/media raw-size: 931.45 GiB size: 915.83 GiB (98.32%)
used: 1.4 GiB (0.2%) fs: ext4 dev: /dev/sde3 maj-min: 8:67 label: N/A
uuid: cde3d4d2-80b8-432f-aa3a-dc449f7865cb
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs
label: R\xc3\xa9cup\xc3\xa9ration uuid: A42C28752C2844A0
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: C428-96BD
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 232.25 GiB fs: ntfs label: N/A
uuid: BCC829A0C8295A42
ID-5: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
ID-6: /dev/sdc2 maj-min: 8:34 size: 3.64 TiB fs: ntfs label: Media
uuid: 52F4E270F4E255AF
ID-7: /dev/sdd1 maj-min: 8:49 size: 128 MiB fs: <superuser required>
ID-8: /dev/sdd2 maj-min: 8:50 size: 931.45 GiB fs: ntfs label: Windows_Data
uuid: 8E7CB5567CB539B3
ID-9: /dev/sdd3 maj-min: 8:51 size: 800 GiB fs: ext4 label: N/A
uuid: e1c10955-6507-4769-95cf-32b62de6420a
ID-10: /dev/sdd4 maj-min: 8:52 size: 80 GiB fs: ext4 label: N/A
uuid: dd55434d-9602-4401-88c5-61dc2ded88bb
ID-11: /dev/sdd5 maj-min: 8:53 size: 32 GiB fs: swap label: N/A
uuid: 1ddff389-5fa9-47a0-a704-d057b074437d
ID-12: /dev/sde1 maj-min: 8:65 size: 128 MiB fs: <superuser required>
ID-13: /dev/sde2 maj-min: 8:66 size: 931.45 GiB fs: ntfs label: WindowsData
uuid: 52065BD3065BB6A7
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Belkin F5U237 USB 2.0 7-Port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 050d:0237 class-ID: 0900
Device-1: 2-1.8.2:4 info: Logitech Webcam C210 type: Video,Audio
power: 500mA chip-ID: 046d:0819 class-ID: 0102 serial: <filter>
Device-2: 2-1.8.4:5 info: Laview Mionix Naos 7000 type: Mouse,HID
power: 200mA chip-ID: 22d4:130c class-ID: 0300 serial: <filter>
Device-3: 2-1.8.6:6 info: Logitech USB Headset type: Audio
driver: snd-usb-audio interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-4: 2-1.8.7:7 info: Dell Dell Universal Receiver
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 413c:301c class-ID: 0300
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 3-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Hub-8: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-9: 4-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-10: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-11: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 358 Uptime: 3m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: pacman: 1744 lib: 475
flatpak: 0 Shell: Zsh v: 5.8 running-in: guake inxi: 3.3.06
$xrandr :
Screen 0: minimum 8 x 8, current 5360 x 1440, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 3440x1440+0+0 (normal left inverted right x axis y axis) 797mm x 333mm
3440x1440 59.97*+ 99.98 49.99
2560x1440 59.95
2560x1080 60.00 59.94
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+3440+121 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1600x900 60.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DVI-D-0 disconnected (normal left inverted right x axis y axis)
So … investigation investigation.
$journalctl -p3 -b -1 :
aoû 02 08:27:15 Finux kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
aoû 02 08:27:15 Finux kernel: EDAC sbridge: Couldn't find mci handler
aoû 02 08:27:15 Finux kernel: EDAC sbridge: Failed to register device with error -19.
aoû 02 08:27:16 Finux kernel: EDAC sbridge: CPU SrcID #0, Ha #0, Channel #0 has DIMMs, but ECC is disabled
aoû 02 08:27:16 Finux kernel: EDAC sbridge: Couldn't find mci handler
aoû 02 08:27:16 Finux kernel: EDAC sbridge: Failed to register device with error -19.
aoû 02 08:27:31 Finux gdm-password][1429]: gkr-pam: unable to locate daemon control file
aoû 02 08:27:36 Finux systemd[2009]: Failed to start Application launched by gnome-session-binary.
aoû 02 08:27:39 Finux gdm-launch-environment][825]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
aoû 02 08:27:59 Finux pulseaudio[2100]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Fabby
2 August 2021 18:36
7
inxi and xrandr look normal, and as you’re on Gnome and I’m on KDE, I can’t help you much further and can only tell you it’s probably a Gnome setting and not an underlying nVidia or kernel setting…
Falav
2 August 2021 18:43
8
If you disable the dual screen, is your main screen alone still reddish?
I tried unplugging the second screen and no, “Turning off and on again” didn’t work but I didn’t think about it so thanks.
So I found a “solution”.
What did I do. I had my main monitor on a DP cable and my sub on a HDMI. I tried switching the two cable and surprise no more redshift on my main but no signal on my sub. But It was not reboot-proof and the redshift came back after a reboot.
Then I deleted the color profile of my main and selected it again (in settings → color ). That’s the solution.
But my DP cable has no signal anymore so no sub. I had to switch to a DVI cable to get it back . So There is still weird things happening but I can work again so it’s solved I guess?
Maybe it’s time for a re-installation? Not sure to choose manjaro again tough. This computer became my working tool thanks to coronavirus . Having a problem on my personal computer well it’s the game of rolling release but since it became needed to earn money well I found it a little too dangerous to play that game now. (with my current knowledge it is)
Hi polyphonus
the same red screen appears after upgrading the kernel into 5-10.53.
The first gamma block of the grey scale was turned on red instead the black block.
I came back into the kernel 5-4-135.
After morealess 3 days, the graphics card itself has launch as a sort of reset and the screen returned on black color , without red - Gamma grey blocks was being OK.
[philline0@philline0-hplx ~]$ inxi
CPU: Quad Core Intel Core i7 Q 720 (-MT MCP-) speed/min/max: 931/933/1600 MHz Kernel: 5.4.135-1-MANJARO x86_64 Up: 45m
Mem: 1619.7/3867.5 MiB (41.9%) Storage: 238.47 GiB (20.5% used) Procs: 202 Shell: Bash inxi: 3.3.06
Sincerly
system
Closed
23 August 2021 18:31
12
