I have Manjaro loaded on a Surface 3 (not pro) and I cant get the on screen keyboard to pop up when i disconnect the keyboard. Everything else works fine and even the touch screen works, sort of. But no way to type anything in without the on screen keyboard. Is there a way to get this fixed
What edition of Manjaro?
In KDE you need to install maliit-keyboard to get the onscreen keyboard working.
Welcome back to the forum!
- Please read this:
How to provide good information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you want to notify me that you did provide this information, please
this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
