On network issues
Hello all,
as many I’ve had some trouble with internet after some upgrades with kernel 6.
today it happened again and what’s strange is that not even tethering my phone with usb would work
hlshw -C network         WARNING: you should run this program as super-user.
  *-network:0
       description: Wireless interface
       product: Comet Lake PCH-LP CNVi WiFi
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlan0
       version: 00
       serial: a4:42:3b:01:23:81
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=6.6.7-1-MANJARO firmware=77.ad46c98b.0 QuZ-a0-hr-b0-77.u latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:9133c000-9133ffff
  *-network:1 DISABLED
       description: Ethernet interface
       product: Ethernet Connection (10) I219-LM
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: eno2
       version: 00
       serial: 74:78:27:85:77:c3
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.6.7-1-MANJARO firmware=0.6-4 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:137 memory:91300000-9131ffff
  *-network DISABLED
       physical id: e
       bus info: usb@1:2
       logical name: enp0s20f0u2
       serial: 22:99:12:98:53:44
       capabilities: ethernet physical
       configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=6.6.7-1-MANJARO duplex=half firmware=RNDIS device link=no multicast=yes port=twisted pairere`
then I do
sudo systemctl start dhcpcd
sudo systemctl restart NetworkManager.service
and I get the tethering connection back on but the icon on taskbar still says disconnected and no wireless connection shows up (wireless doesn’t work at all)
It’s driving me nuts,
any help please I’m lost
Please look at your own post and tell me how readable it is. Does it look ok to you?
yes sorry, I fixed it as you typed your reply. as I mentioned I’m having difficulties with connection
Maybe post some info about what you are even using. I think it’s
inxi -Fazi
Another thing is, running dhcpcd with NetworkManager is usually not necessary/recommended.
  Kernel: 6.6.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=e3416a73-0a57-4a9c-bc11-48948434a9c4 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
  Type: Laptop System: Dell product: Latitude 5410 v: N/A
  Mobo: Dell model: 030CV1 v: A01 serial: <superuser required> UEFI: Dell
    v: 1.7.0 date: 08/02/2021
  ID-1: BAT0 charge: 52.4 Wh (100.0%) condition: 52.4/68.0 Wh (77.1%)
    volts: 17.1 min: 15.2 model: BYD DELL 3PCVM12 type: Li-poly serial: <filter>
    status: full
  Info: model: Intel Core i5-10310U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
    built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xF8
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 400/4400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 35210
  Type: retbleed mitigation: Enhanced IBRS
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB:
    conditional, RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
  Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
    chip-ID: 1bcf:28c4 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9b41 memory: 14.88 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.269 layers: N/A device: 0 type: integrated-gpu
    name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1
    device-ID: 8086:9b41 surfaces: xcb,xlib,wayland
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Dell driver: snd_hda_intel
    chip-ID: 8086:02c8 class-ID: 0403
  API: ALSA v: k6.6.7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF: wlan0 state: down mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4e class-ID: 0200
  IF: eno2 state: down mac: <filter>
  IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
  IP v6: <filter> scope: link
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0026
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: no address: <filter> bt-v: 5.2 lmp-v: 11
    status: discoverable: no pairing: no
  Device-2: OPPO RMX2111 driver: rndis_host v: kernel type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:5 chip-ID: 22d9:276a
    class-ID: 0a00 serial: <filter>
  Local Storage: total: 238.47 GiB used: 86.83 GiB (36.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SSSTC model: CL1-3D256-Q11 NVMe
    SSSTC 256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 22301116
    temp: 25.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 86.83 GiB (37.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 47.0 C pch: 45.0 C mobo: 42.0 C
  Fan Speeds (rpm): cpu: 0
  Processes: 255 Uptime: 1h 25m wakeups: 0 Memory: total: 16 GiB note: est.
  available: 15.23 GiB used: 4.08 GiB (26.8%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1435 libs: 407 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.2.21 running-in: konsole
  inxi: 3.3.31
I appreciate that, wireless came back that way last week. I’ll avoid it anyway
So can you repeat, what problems do you have exactly? What’s not working?
Wireless not working. Can’t detect any connection. It was fine until kernel 6.1.
The card is an Intel ax201, never had problems with Manjaro
Are you using Bluetooth while being on Wi-Fi?
I also figure out some problem with the Internet with Bluetooth and Wi-Fi. topic
What is your output of:
sudo systemctl status NetworkManager.service
sudo systemctl status dhcpcd
and
sudo systemctl status wpa_supplicant.service
You might try the latest kernel 6.6.x iteration which fixed a recent regression, and has solved WiFi issues for many users. See if it also resolves your issue.
I hope this helps. Cheers.
Well, actually it’s just the latest that caused problems
I see.
Then, at the risk of stating the obvious, it must be something else.
I found Manjaro Not Recognizing Intel Wi-Fi 6 AX201 from back in 2021; there was no apparent solution found. Whether or not it’s the same issue, I can’t say. I also found these, neither of which produced any joy:
Is the linux-firmware package installed?
pacman -Qi linux-firmware
pacman -Qi linux-firmware         ✔
Version         : 20231211.f2e52a1c-1
Description     : Firmware files for Linux
Architecture    : any
URL             : https://git.kernel.org/?p=linux/kernel/git/firmware/linux-firmware.git;a=summary
Licenses        : GPL2  GPL3  custom
Groups          : None
Provides        : None
Depends On      : linux-firmware-whence
Optional Deps   : None
Required By     : linux61  linux66
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 524,37 MiB
Packager        : Mark Wagie <mark@manjaro.org>
Build Date      : lun 11 dic 2023, 16:32:36
Install Date    : mer 13 dic 2023, 22:05:42
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
no, BT not active
sudo systemctl status NetworkManager.service         ✔
● NetworkManager.service - Network Manager
     Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
             └─50-iwd.conf
     Active: active (running) since Sat 2023-12-16 09:42:37 CET; 1min 42s ago
       Docs: man:NetworkManager(8)
   Main PID: 2408 (NetworkManager)
      Tasks: 4 (limit: 18690)
     Memory: 8.0M
        CPU: 101ms
     CGroup: /system.slice/NetworkManager.service
             └─2408 /usr/bin/NetworkManager --no-daemon
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9720] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
dic 16 09:42:37 gianluca-latitude5410 systemd[1]: Started Network Manager.
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9739] manager: NetworkManager state is now ASLEEP
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9765] device (wlan0): new IWD device state is disconnected
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9767] Wi-Fi P2P device added on phy0
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9770] manager: (/net/connman/iwd/0): new 802.11 Wi-Fi P2P device (/org/freedeskto>
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9778] ovsdb: disconnected from ovsdb
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9779] manager: startup complete
dic 16 09:42:37 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716157.9791] modem-manager: ModemManager available
dic 16 09:42:38 gianluca-latitude5410 NetworkManager[2408]: <info>  [1702716158.0197] agent-manager: agent[ca95c0061edea0d6,:1.35/org.kde.plasma.networkmanagemen>
lines 1-23/23 (END)
sudo systemctl status dhcpcd         ✔
[sudo] password for gianluca:
● dhcpcd.service - DHCP/ IPv4LL/ IPv6RA/ DHCPv6 client on all interfaces
     Loaded: loaded (/usr/lib/systemd/system/dhcpcd.service; disabled; preset: disabled)
     Active: active (running) since Sat 2023-12-16 09:42:26 CET; 4min 39s ago
   Main PID: 2095 (dhcpcd)
      Tasks: 5 (limit: 18690)
     Memory: 3.3M
        CPU: 127ms
     CGroup: /system.slice/dhcpcd.service
             ├─2095 "dhcpcd: [manager] [ip4] [ip6]"
             ├─2097 "dhcpcd: [privileged proxy]"
             ├─2098 "dhcpcd: [network proxy]"
             ├─2099 "dhcpcd: [control proxy]"
             └─2123 "dhcpcd: [BPF ARP] enp0s20f0u3 192.168.35.60"
dic 16 09:42:31 gianluca-latitude5410 dhcpcd[2097]: ps_bpf_recvmsg: Invalid argument
dic 16 09:42:33 gianluca-latitude5410 dhcpcd[2097]: enp0s20f0u3: leased 192.168.35.60 for 3599 seconds
dic 16 09:42:33 gianluca-latitude5410 dhcpcd[2097]: enp0s20f0u3: adding route to 192.168.35.0/24
dic 16 09:42:33 gianluca-latitude5410 dhcpcd[2097]: enp0s20f0u3: adding default route via 192.168.35.158
dic 16 09:42:33 gianluca-latitude5410 dhcpcd[2097]: ps_bpf_recvmsg: Invalid argument
dic 16 09:42:35 gianluca-latitude5410 dhcpcd[2097]: ps_bpf_recvmsg: Invalid argument
dic 16 09:42:40 gianluca-latitude5410 dhcpcd[2097]: enp0s20f0u3: no IPv6 Routers available
sudo systemctl status wpa_supplicant.service         ✔  6s 
○ wpa_supplicant.service - WPA supplicant
     Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; preset: disabled)
     Active: inactive (dead)
NetworkManager and dhcpcd is running what happen if you
sudo systemctl disable --now dhcpcd
only 1 should be running Wiki
A reminder of the note from @anon51566685 (Post #4): Running dhcpcd with NetworkManager is usually not necessary/recommended.
Especially not when you already connect to a router (or WiFi router) that provides a dhcp server; or an ISP that provides a dhcp service;
dhcpcd should be disabled in most cases.
I disabled dhcpcd as you said, internet is still on (still tethering on a phone) but no sign of wireless. connections don,t seem to appear
ok, I rebooted and if I only restart networkmanager, internet doesn’t work at all (not even tethering);
if I start only dhcpcd tethering works
it seems the problem is networkmanager, the icon is dead but wireless now works on my configured usual one (restarted only dhcpcd)
How could I restore “normality” with networkmanager?
Probably show what you modified here.
Also: Do you really need iwd as backend? wpa_supplicant is the default.
It wasn’t wanted))) I don’t know what happened.
How do I get everything back on default, like network manager, epa supplicnt?
I’m Not an expert really
