Okular does not load recent files/tabs on restart
Okular does not load recent files/tabs on restart as it did before.
Okular Version 21.08.0
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
Qt Version: 5.15.2
Kernel Version: 5.10.60-1-MANJARO (64-bit)
Graphics Platform: X11
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=a3d17ce4-9aaf-437d-a73a-439edc842272 rw quiet acpi_rev_override=1
  pcie_port_pm=off resume=UUID=1a692f9b-337c-4cfa-81e9-a514be6aa511
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Dell product: G3 3779 v: N/A serial: <filter> Chassis:
  type: 10 serial: <filter>
  Mobo: Dell model: 04R93M v: A00 serial: <filter> UEFI: Dell v: 1.2.1
  date: 07/18/2018
  ID-1: BAT0 charge: 17.7 Wh (100.0%) condition: 17.7/56.0 Wh (31.6%)
  volts: 17.1 min: 15.2 model: Samsung SDI DELL W7NKD87 type: Li-ion
  serial: <filter> status: Full
  RAM: total: 15.49 GiB used: 6.39 GiB (41.2%)
  Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: EA cache: L2: 9 MiB bogomips: 52815
  Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Dell
  driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1c20 class-ID: 0302
  Device-3: Realtek Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
  chip-ID: 0bda:568a class-ID: 0e02 serial: <filter>
  loaded: modesetting,nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
  s-diag: 693mm (27.3")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  OpenGL: renderer: NVIDIA GeForce GTX 1060 with Max-Q Design/PCIe/SSE2
  v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel
  bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 3b:00.0
  IF: enp59s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
  Local Storage: total: 2.05 TiB used: 321.3 GiB (15.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174
  type: HDD rpm: 5400 serial: <filter> rev: SDM2 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 256GB
  size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: SSD serial: <filter> rev: 0P10 scheme: GPT
  ID-1: / raw-size: 27.94 GiB size: 27.38 GiB (97.98%) used: 21.84 GiB (79.8%)
  fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
  uuid: a3d17ce4-9aaf-437d-a73a-439edc842272
  used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: EFI
  uuid: 45D5-9BC5
  ID-3: /data raw-size: 559.16 GiB size: 549.38 GiB (98.25%)
  used: 163.36 GiB (29.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Data
  uuid: 27bc111f-0627-4f8e-aad9-f5b08eb60e14
  ID-4: /home raw-size: 193.15 GiB size: 189.12 GiB (97.91%)
  used: 22.69 GiB (12.0%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: f19fe205-c411-40ff-b63a-165435acb85d
  ID-5: /music raw-size: 745.06 GiB size: 732.36 GiB (98.30%)
  used: 51.05 GiB (7.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Music
  uuid: 04b74089-4a64-43f4-afa9-ffea7b6cb0b5
  ID-6: /var raw-size: 93.14 GiB size: 91.17 GiB (97.89%)
  used: 17.44 GiB (19.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: var
  uuid: a51c81a4-a4b9-422e-912f-e08a5c8d0d31
  ID-7: /video raw-size: 465.66 GiB size: 457.35 GiB (98.22%)
  used: 44.91 GiB (9.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Video
  uuid: 821ea29a-ea1f-4aeb-8658-e293f9046d4b
  ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdb4 maj-min: 8:20 label: N/A
  uuid: 1a692f9b-337c-4cfa-81e9-a514be6aa511
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-2:10 info: ASUSTek ASUS ROG GAMING MOUSE GX900
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 0b05:1795 class-ID: 0301
  Device-2: 1-5:3 info: Realtek Integrated Webcam type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:568a
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 47 C
  Processes: 434 Uptime: 23h 32m wakeups: 11 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1860
  pacman: 1854 lib: 446 flatpak: 0 snap: 6 Shell: Bash v: 5.1.8
  running-in: konsole inxi: 3.3.06
$ pamac search okular
okular                                                     [Установленные] 21.08.0-1                    extra
    Document Viewer
(p.s. | grep Installed is not applied, as something wrong with my locale settings. Установленные means Installed )
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. The output to pamac search okular | grep Installed would be helpful as well as you might have accidentally installed the snap / flatpak / AppImage version instead of the native version.
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
Information added.
That all looks good…
So what you’re saying is that if you go to File → Recent the list is always empty???
:thinking:
No, as I said ā€œOkular does not load recent files/tabsā€ (literally).
Before this time it remembered and loaded all the previous tabs of opened files even after system restart.
Now, on restart it opens empty (no tabs) and ā€œRecentā€ section contains only some recent files - not all.
Ah! That was functionality that was that was moved to the recent file list a few months ago to bring all KDE applications in line with one another.
(Can’t remember when and can’t find it in the changelog in a few minutes, but it was a while ago…
Sorry! :sob:
I haven’t noticed that but that would be a bug and should be filed upstream…
:crossed_fingers:
So, there’s no hope that that feature (recovering recent tabs on reopen/restart) would be returned?
(had to look for better document reader)
You can look for an existing bug on the KDE bug tracker and subscribe to it to voice your opinion to the KDE developers or if there is none yet, create one yourself…
:crossed_fingers:
It seems the request is stalled :
https://bugs.kde.org/show_bug.cgi?id=442225
I’ve used 10 of my votes to add to your bug, which is the best I can do at the moment.
:sob:
Thanks for that.
