“Oh no! Something has gone wrong.” On login
Hi I updated my system and when I rebooted, I couldn’t login. I just get this message:
A problem has occurred and the system can’t recover. All extensions have been disabled as a precaution.
So far I have tried to reinstall gnome-shell, reinstall gnome-session, remove the pacman cache with paccache, and manually disabling gnome extensions.
What can I do?
I hope this is enough information. I’m still learning a lot about using Linux, so bear with me, and let me know if you need any additional information.
Welcome to the forum! :wave:
Well, were you able to login with all extensions disabled?
No. I tried again right after the first message. When that didn’t work, I tried the other things I listed.
This ended up being the solution.
I also experienced the choppiness described. I hope that is also gone now.
