Hi,
Since the last (big) update, I have some troubles to make offlineimap
working.
I read this Offlineimap throwing error now - #6 by mithrial but it doesn’t apply to me, I think.
I have offlineimap 8.0.0-1 installed.
I have python versions 2 and 3.
Here is the traceback. Is this about a python error?
Thanks.
ERROR: Exceptions occurred during the run!
ERROR: While attempting to sync account 'myaccount'
a bytes-like object is required, not 'str'
Traceback:
File "/usr/lib/python3.9/site-packages/offlineimap/accounts.py", line 298, in syncrunner
self.__sync()
File "/usr/lib/python3.9/site-packages/offlineimap/accounts.py", line 374, in __sync
remoterepos.getfolders()
File "/usr/lib/python3.9/site-packages/offlineimap/repository/IMAP.py", line 681, in getfolders
imapobj = self.imapserver.acquireconnection()
File "/usr/lib/python3.9/site-packages/offlineimap/imapserver.py", line 593, in acquireconnection
self.__authn_helper(imapobj)
File "/usr/lib/python3.9/site-packages/offlineimap/imapserver.py", line 445, in __authn_helper
if func(imapobj):
File "/usr/lib/python3.9/site-packages/offlineimap/imapserver.py", line 371, in __authn_plain
imapobj.authenticate('PLAIN', self.__plainhandler)
File "/usr/lib/python3.9/site-packages/imaplib2/imaplib2.py", line 712, in authenticate
typ, dat = self._simple_command('AUTHENTICATE', mechanism.upper())
File "/usr/lib/python3.9/site-packages/imaplib2/imaplib2.py", line 1705, in _simple_command
return self._command_complete(self._command(name, *args), kw)
File "/usr/lib/python3.9/site-packages/imaplib2/imaplib2.py", line 1425, in _command
literal = literator(data, rqb)
File "/usr/lib/python3.9/site-packages/imaplib2/imaplib2.py", line 2268, in process
ret = self.mech(self.decode(data))
File "/usr/lib/python3.9/site-packages/offlineimap/imapserver.py", line 211, in __plainhandler
passwd = self.__getpassword()
File "/usr/lib/python3.9/site-packages/offlineimap/imapserver.py", line 179, in __getpassword
self.password = self.repos.getpassword() or \
File "/usr/lib/python3.9/site-packages/offlineimap/repository/IMAP.py", line 585, in getpassword
l_pass = self.localeval.eval(passwd)
File "/usr/lib/python3.9/site-packages/offlineimap/localeval.py", line 45, in eval
return eval(text, names)
File "<string>", line 1, in <module>
File "/home/alex/.offlineimap.py", line 20, in get_passmyaccount
return check_output("gpg -dq ~/.mutt/pwmyaccount.gpg", shell=True).strip("\n")
Press any key to continue...
