ODROID-M1 not booting from SD card / NVMe
Hello,
I have a problem using Manjaro on my ODROID-M1.
  1. I start with a fresh installation from “Manjaro-ARM-gnome-om1-22.12.img.xz” and after I copied image to SD / NVMe, I get black screen on boot.
  2. I start with a fresh installation from “Manjaro-ARM-gnome-om1-22.10.img.xz” and after I copied image to SD / NVMe, I get Manjaro booting and usable but when I run a pacman -Syu, system will be broken on next boot, I get black screen on boot.
During pacman -Syu, mkinitcpio regenerate itself and say :
WARNING: Possibly missing firmware for module: rockchipdrm
I think the problem come from here but I’m not able to provide a correction to the upstream build itself.
  1. I tried to build my own img.xz with:
buildarmimg -d om1 -e gnome -n
Again, during mkinitcpio generation of itself it say :
My own “Manjaro-ARM-gnome-om1-23.02.img.xz” give me the very same result as Manjaro-ARM-gnome-om1-22.12.img.xz”.
Similar problem with another board → https://forum.manjaro.org/t/rock-3a-not-booting-from-sd-card/132745
Help from the Manjaro Team will be very appreciate!
Wish You well!
As we discussed in PMs.
I can’t replicate the behavior on my Odroid M1 with the same image (Gnome 22.12) you tried.
The main difference between our devices, seems to be the version of Petitboot. Mine is from 2021, while yours is from 2022.
So you could try booting while disabling the SPI, where petitboot is located, by holding down the contact button while it’s booting for like 5 seconds. The blue LED should start blinking when the kernel is running and you can release the button.
This is a different issue, and the fix for it is already implemented for the Odroid M1.
Hello Delor3an91, have you managed to solve this problem? I have the exact same issue. Thank you
Hi,
The last Odroid M1 stable image I built boot on emmc module and ssd disc, sd card and nvme disc not tested.
Tomorrow I’ll have time to test it, sd card and nvme disc.
Your feedback is welcome :slight_smile:
Which image are you using ?
I can try to test the same image. Let me know which drive method are you trying to use.
emmc, Sdcard, ssd or nvme ?
