Octopi not responding
Symptom: an endless spin within the Octopi window (screenshot disallowed).
Updating and restarting the system has not worked around the problem. Removing then installing Octopi has not worked around the problem.
How might I resolve it?
Background
If I recall correctly: prior to the system update, Octopi failed repeatedly to check for updates (the button below the File menu).
I might have forced a quit of the application, but not during an installation.
Pamac works.
Welcome here, @grahamperrin
I would try to deinstall it and remove the settings in home folder by
sudo pacman -Rsn octopi
sudo rm /home/$USER/.config/octopi/*
Also, check if you find any file or folder of Octopi in your cache folder /home/$USER/.cache, then delete this as well.
Finally, clean your pacman cache and try to reinstall:
sudo pacman -Sc
sudo pacman-mirrors -f && sudo pacman -Syyu octopi
Thanks.
I forced a quit of the application then followed the steps above but still, no go.
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ sudo pacman -Rsn octopi
[sudo] password for grahamperrin:
checking dependencies...
:: removing octopi breaks dependency 'octopi' required by octopi-notifier-frameworks
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ sudo pacman -Rsn octopi octopi-notifier-frameworks
Packages (6) alpm-octopi-utils-1.0.2-1  expac-10-2  pkgfile-21-2  qtermwidget-0.15.0-1  octopi-0.9.0-24  octopi-notifier-frameworks-0.9.0-24
Total Removed Size:  8.20 MiB
:: Do you want to remove these packages? [Y/n] y
(1/6) removing octopi-notifier-frameworks        [####################################################################] 100%
(2/6) removing octopi        [####################################################################] 100%
(3/6) removing qtermwidget        [####################################################################] 100%
(4/6) removing pkgfile        [####################################################################] 100%
(5/6) removing expac        [####################################################################] 100%
(6/6) removing alpm-octopi-utils        [####################################################################] 100%
(1/4) Reloading system manager configuration...
(2/4) Arming ConditionNeedsUpdate...
(3/4) Updating icon theme caches...
(4/4) Updating the desktop file MIME type cache...
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ pwd
/home/grahamperrin
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ sudo rm /home/grahamperrin/.config/octopi/*
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ ls -d .cache/*ctop*
ls: cannot access '.cache/*ctop*': No such file or directory
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ ls .cache/*ctop*
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ sudo pacman -Sc
Packages to keep:
  All locally installed packages
Cache directory: /var/cache/pacman/pkg/
:: Do you want to remove all other packages from cache? [Y/n] y
removing old packages from cache...
Database directory: /var/lib/pacman/
:: Do you want to remove unused repositories? [Y/n] n
[grahamperrin@momh167-gjp4-virtualbox-manjaro ~]$ sudo pacman-mirrors -f && sudo pacman -Syyu octopi octopi-notifier-frameworks
::INFO Downloading mirrors from repo.manjaro.org
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
  0.350 Germany        : https://mirror.alpix.eu/manjaro/
  0.461 Poland         : http://ftp.vectranet.pl/manjaro/
  0.857 Poland         : ftp://ftp.vectranet.pl/manjaro/
  0.343 Ukraine        : http://mirrors.colocall.net/manjaro/
  0.708 Ukraine        : ftp://mirrors.colocall.net/manjaro/
  0.199 Netherlands    : http://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.341 Netherlands    : ftp://ftp.snt.utwente.nl/pub/linux/manjaro/
  0.577 Hungary        : https://quantum-mirror.hu/mirrors/pub/manjaro/
  0.335 Hungary        : http://quantum-mirror.hu/mirrors/pub/manjaro/
  0.280 Belgium        : https://mirror.futureweb.be/manjaro/
  0.207 Belgium        : http://mirror.futureweb.be/manjaro/
  0.426 Australia      : https://manjaro.lucassymons.net/
  1.325 South_Africa   : http://manjaro.mirror.ac.za/
  ..... Taiwan         : http://free.nchc.org.tw/manjaro/
  0.322 Netherlands    : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.330 Netherlands    : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjaro/
  0.463 Bulgaria       : https://mirrors.netix.net/manjaro/
  0.291 Germany        : https://mirror.atysleaks.org/manjaro/
  0.338 Germany        : http://mirror.atysleaks.org/manjaro/
  0.946 Canada         : https://mirror.csclub.uwaterloo.ca/manjaro/
  ..... China          : https://mirrors.tuna.tsinghua.edu.cn/manjaro/
  2.047 Brazil         : https://www.caco.ic.unicamp.br/manjaro/
  1.698 Japan          : http://ftp.riken.jp/Linux/manjaro/
  ..... Japan          : ftp://ftp.riken.jp/Linux/manjaro/
::ERROR ftp error: timeout('timed out') 'ftp://ftp.riken.jp/Linux/manjaro/'
  0.321 Norway         : http://mirror.terrahost.no/linux/manjaro/
  0.541 Spain          : https://ftp.caliu.cat/pub/distribucions/manjaro/
  0.439 Spain          : http://ftp.caliu.cat/pub/distribucions/manjaro/
  0.300 Germany        : https://manjaro.moson.eu/
  0.245 Germany        : http://manjaro.moson.eu/
  0.296 Germany        : https://mirror.23media.com/manjaro/
  0.236 Germany        : http://mirror.23media.com/manjaro/
  0.719 Canada         : https://osmirror.org/manjaro/
  0.324 France         : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
  0.517 France         : ftp://ftp.free.org/mirrors/repo.manjaro.org/repos/
  1.294 Chile          : https://mirror1.cl.netactuate.com/manjaro/
  1.279 Chile          : http://mirror1.cl.netactuate.com/manjaro/
  ..... Chile          : ftp://mirror1.cl.netactuate.com/manjaro/
  0.843 United_States  : http://distro.ibiblio.org/manjaro/
  0.281 France         : http://kibo.remi.lu/
  0.566 Italy          : https://manjaro.mirror.garr.it/manjaro/
  0.611 Greece         : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.474 Greece         : http://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  1.002 Greece         : ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/
  0.776 Ukraine        : https://fastmirror.pp.ua/manjaro/
  0.654 Ukraine        : http://fastmirror.pp.ua/manjaro/
  1.645 India          : https://mirrors.piconets.webwerks.in/manjaro-mirror/
  0.821 India          : http://mirrors.piconets.webwerks.in/manjaro-mirror/
  2.054 South_Korea    : https://mirror.d-tl.com/manjaro/
  0.447 Belarus        : http://mirror.datacenter.by/pub/mirrors/manjaro/
  1.553 Chile          : http://manjaro.dcc.uchile.cl/
  1.058 Iran           : https://repo.iut.ac.ir/repo/manjaro/
  0.675 Iran           : http://repo.iut.ac.ir/repo/manjaro/
  0.333 Switzerland    : https://manjaro.osmir.ch/
  0.271 Switzerland    : http://manjaro.osmir.ch/
  0.302 France         : https://mirror.oldsql.cc/manjaro/
  0.360 Germany        : https://ftp.halifax.rwth-aachen.de/manjaro/
  0.681 Germany        : ftp://ftp.halifax.rwth-aachen.de/manjaro/
  0.719 United_States  : https://mirror.clarkson.edu/manjaro/
  0.297 United_Kingdom : https://uk.mirrors.fossho.st/manjaro/
  0.187 United_Kingdom : http://uk.mirrors.fossho.st/manjaro/
  0.344 Russia         : https://mirror.yandex.ru/mirrors/manjaro/
  0.362 Portugal       : http://ftp.dei.uc.pt/pub/linux/manjaro/
  1.004 United_States  : https://mirror.math.princeton.edu/pub/manjaro/
  2.117 Australia      : https://mirror.aarnet.edu.au/pub/manjaro/
  1.666 Australia      : http://mirror.aarnet.edu.au/pub/manjaro/
  0.305 Denmark        : https://mirrors.dotsrc.org/manjaro/
  2.769 China          : https://mirrors.ustc.edu.cn/manjaro/
  0.443 Bulgaria       : https://manjaro.ipacct.com/manjaro/
  1.454 Philippines    : http://mirror.rise.ph/manjaro/
  ..... Philippines    : ftp://mirror.rise.ph/manjaro/
  0.261 United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/
  0.708 Austria        : http://mirror.inode.at/manjaro/
  1.347 United_States  : https://mirrors.ocf.berkeley.edu/manjaro/
  0.498 Poland         : https://mirror.tuchola-dc.pl/manjaro/
  0.319 Germany        : http://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.580 Germany        : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
  0.337 Austria        : http://mirror.easyname.at/manjaro/
  0.799 Austria        : ftp://mirror.easyname.at/manjaro/
  1.224 Costa_Rica     : https://mirrors.ucr.ac.cr/manjaro/
  0.205 United_Kingdom : http://manjaro.mirrors.uk2.net/
  0.288 Netherlands    : https://mirror.koddos.net/manjaro/
  1.244 South_Africa   : http://mirror.is.co.za/mirrors/manjaro.org/
  0.332 France         : https://manjaro.ynh.ovh/
  0.518 Bulgaria       : http://manjaro.telecoms.bg/
  0.299 Germany        : https://manjaro.moson.org/
  0.246 Germany        : http://manjaro.moson.org/
  ..... Hong_Kong      : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  ..... Hong_Kong      : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
  0.726 Georgia        : https://manjaro.grena.ge/
  0.516 Georgia        : http://manjaro.grena.ge/
  0.284 Germany        : https://mirror.netcologne.de/manjaro/
  0.998 United_States  : https://us.mirrors.fossho.st/manjaro/
  0.816 United_States  : http://us.mirrors.fossho.st/manjaro/
  ..... Bangladesh     : http://mirror.xeonbd.com/manjaro/
  1.630 Brazil         : http://linorg.usp.br/manjaro/
  0.295 France         : https://manjaro.mcofficer.me/
  2.313 Uruguay        : https://manjaro.repo.cure.edu.uy/
  1.565 Uruguay        : http://manjaro.repo.cure.edu.uy/
  0.889 Russia         : https://mirror.truenetwork.ru/manjaro/
  0.675 Russia         : http://mirror.truenetwork.ru/manjaro/
  0.416 Sweden         : https://ftp.lysator.liu.se/pub/manjaro/
  0.589 Sweden         : ftp://ftp.lysator.liu.se/pub/manjaro/
  1.952 Singapore      : https://download.nus.edu.sg/mirror/manjaro/
  0.323 Germany        : https://mirror.netzspielplatz.de/manjaro/packages/
  1.812 Pakistan       : https://repo.inara.pk/manjaro/
  1.527 Pakistan       : http://repo.inara.pk/manjaro/
  1.376 Kenya          : https://manjaro.mirror.liquidtelecom.com/
  1.098 Kenya          : http://manjaro.mirror.liquidtelecom.com/
  1.493 Denmark        : https://www.uex.dk/public/manjaro/
  ..... China          : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
  ..... Japan          : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
  2.079 Brazil         : https://manjaro.c3sl.ufpr.br/
  0.430 Czech          : https://mirror.dkm.cz/manjaro/
  1.219 Indonesia      : https://mirror.deace.id/manjaro/
  0.883 Indonesia      : http://mirror.deace.id/manjaro/
  1.813 New_Zealand    : http://manjaro.mirrors.theom.nz/
  0.486 Iceland        : https://mirrors.opensource.is/manjaro/
  0.325 Iceland        : http://mirrors.opensource.is/manjaro/
  ..... Iceland        : ftp://mirrors.opensource.is/manjaro/
::ERROR ftp error: error_perm('550 Failed to change directory.') 'ftp://mirrors.opensource.is/manjaro/'
  2.317 Thailand       : https://mirror.kku.ac.th/manjaro/
  1.851 Thailand       : http://mirror.kku.ac.th/manjaro/
  ..... Thailand       : ftp://mirror.kku.ac.th/manjaro/
  0.277 Netherlands    : https://manjaro.mirrors.lavatech.top/
  0.594 Netherlands    : http://manjaro.mirrors.lavatech.top/
  0.681 Italy          : https://ct.mirror.garr.it/mirrors/manjaro/
  0.881 United_States  : https://mirrors.gigenet.com/manjaro/
  0.769 United_States  : http://mirrors.gigenet.com/manjaro/
  1.971 Chile          : https://mirror.ufro.cl/manjaro/
  1.212 United_States  : https://repo.ialab.dsu.edu/manjaro/
  0.795 United_States  : http://repo.ialab.dsu.edu/manjaro/
  0.439 Turkey         : http://ftp.linux.org.tr/manjaro/
  1.073 Turkey         : ftp://ftp.linux.org.tr/manjaro/
  0.589 China          : https://mirrors.aliyun.com/manjaro/
  0.876 United_States  : https://mirror.dacentec.com/manjaro/
  0.663 Italy          : https://ba.mirror.garr.it/mirrors/manjaro/
  0.367 Sweden         : https://mirror.zetup.net/manjaro/
::INFO Writing mirror list
::United_Kingdom  : https://uk.mirrors.fossho.st/manjaro/stable
::United_Kingdom  : http://manjaro.mirrors.uk2.net/stable
::Belgium         : https://mirror.futureweb.be/manjaro/stable
::Germany         : https://mirror.23media.com/manjaro/stable
::Germany         : https://manjaro.moson.eu/stable
::Germany         : https://manjaro.moson.org/stable
::United_Kingdom  : https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable
::Switzerland     : https://manjaro.osmir.ch/stable
::France          : http://kibo.remi.lu/stable
::Germany         : https://mirror.netcologne.de/manjaro/stable
::Netherlands     : https://mirror.koddos.net/manjaro/stable
::France          : https://manjaro.mcofficer.me/stable
::France          : https://mirror.oldsql.cc/manjaro/stable
::Denmark         : https://mirrors.dotsrc.org/manjaro/stable
::Norway          : http://mirror.terrahost.no/linux/manjaro/stable
::Germany         : https://mirror.netzspielplatz.de/manjaro/packages/stable
::Netherlands     : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable
::France          : https://manjaro.ynh.ovh/stable
::Hungary         : https://quantum-mirror.hu/mirrors/pub/manjaro/stable
::Germany         : https://mirror.atysleaks.org/manjaro/stable
::Netherlands     : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Russia          : https://mirror.yandex.ru/mirrors/manjaro/stable
::Germany         : https://mirror.alpix.eu/manjaro/stable
::Portugal        : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::Sweden          : https://mirror.zetup.net/manjaro/stable
::Australia       : https://manjaro.lucassymons.net/stable
::Czech           : https://mirror.dkm.cz/manjaro/stable
::Spain           : https://ftp.caliu.cat/pub/distribucions/manjaro/stable
::Bulgaria        : https://manjaro.ipacct.com/manjaro/stable
::Belarus         : http://mirror.datacenter.by/pub/mirrors/manjaro/stable
::Bulgaria        : https://mirrors.netix.net/manjaro/stable
::Poland          : https://mirror.tuchola-dc.pl/manjaro/stable
::Georgia         : https://manjaro.grena.ge/stable
::France          : http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable
::Bulgaria        : http://manjaro.telecoms.bg/stable
::Italy           : https://manjaro.mirror.garr.it/manjaro/stable
::Germany         : http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable
::Sweden          : https://ftp.lysator.liu.se/pub/manjaro/stable
::China           : https://mirrors.aliyun.com/manjaro/stable
::Netherlands     : https://manjaro.mirrors.lavatech.top/stable
::Ukraine         : https://fastmirror.pp.ua/manjaro/stable
::Italy           : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Iran            : https://repo.iut.ac.ir/repo/manjaro/stable
::Russia          : https://mirror.truenetwork.ru/manjaro/stable
::Germany         : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Italy           : https://ct.mirror.garr.it/mirrors/manjaro/stable
::Ukraine         : http://mirrors.colocall.net/manjaro/stable
::Austria         : http://mirror.inode.at/manjaro/stable
::Canada          : https://osmirror.org/manjaro/stable
::United_States   : https://mirror.clarkson.edu/manjaro/stable
::United_States   : https://mirrors.gigenet.com/manjaro/stable
::United_States   : https://repo.ialab.dsu.edu/manjaro/stable
::Austria         : http://mirror.easyname.at/manjaro/stable
::United_States   : https://us.mirrors.fossho.st/manjaro/stable
::India           : https://mirrors.piconets.webwerks.in/manjaro-mirror/stable
::United_States   : http://distro.ibiblio.org/manjaro/stable
::Poland          : http://ftp.vectranet.pl/manjaro/stable
::United_States   : https://mirror.dacentec.com/manjaro/stable
::Indonesia       : https://mirror.deace.id/manjaro/stable
::Canada          : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Greece          : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::United_States   : https://mirror.math.princeton.edu/pub/manjaro/stable
::Turkey          : http://ftp.linux.org.tr/manjaro/stable
::Kenya           : https://manjaro.mirror.liquidtelecom.com/stable
::Costa_Rica      : https://mirrors.ucr.ac.cr/manjaro/stable
::South_Africa    : http://mirror.is.co.za/mirrors/manjaro.org/stable
::South_Africa    : http://manjaro.mirror.ac.za/stable
::United_States   : https://mirrors.ocf.berkeley.edu/manjaro/stable
::Denmark         : https://www.uex.dk/public/manjaro/stable
::Pakistan        : https://repo.inara.pk/manjaro/stable
::Chile           : http://manjaro.dcc.uchile.cl/stable
::Uruguay         : https://manjaro.repo.cure.edu.uy/stable
::Brazil          : http://linorg.usp.br/manjaro/stable
::Australia       : https://mirror.aarnet.edu.au/pub/manjaro/stable
::New_Zealand     : http://manjaro.mirrors.theom.nz/stable
::Singapore       : https://download.nus.edu.sg/mirror/manjaro/stable
::Chile           : https://mirror.ufro.cl/manjaro/stable
::Brazil          : https://www.caco.ic.unicamp.br/manjaro/stable
::South_Korea     : https://mirror.d-tl.com/manjaro/stable
::Brazil          : https://manjaro.c3sl.ufpr.br/stable
::Bangladesh      : http://mirror.xeonbd.com/manjaro/stable
::Japan           : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::Chile           : https://mirror1.cl.netactuate.com/manjaro/stable
::Taiwan          : http://free.nchc.org.tw/manjaro/stable
::China           : https://mirrors.ustc.edu.cn/manjaro/stable
::Thailand        : https://mirror.kku.ac.th/manjaro/stable
::Philippines     : http://mirror.rise.ph/manjaro/stable
::China           : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Hong_Kong       : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable
::China           : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
:: Synchronising package databases...
 core        168.6 KiB  1258 KiB/s 00:00 [####################################################################] 100%
 extra        2010.2 KiB  1117 KiB/s 00:02 [####################################################################] 100%
 community        6.2 MiB   970 KiB/s 00:07 [####################################################################] 100%
 multilib        191.8 KiB  1109 KiB/s 00:00 [####################################################################] 100%
resolving dependencies...
Total Download Size:   1.80 MiB
Total Installed Size:  8.20 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 pkgfile-21-2-x86_64        24.8 KiB  8.07 MiB/s 00:00 [####################################################################] 100%
 expac-10-2-x86_64        15.5 KiB  0.00   B/s 00:00 [####################################################################] 100%
 alpm-octopi-utils-1.0.2-1-x86_64                                                      15.1 KiB  0.00   B/s 00:00 [####################################################################] 100%
 qtermwidget-0.15.0-1-x86_64                                                          211.2 KiB  1295 KiB/s 00:00 [####################################################################] 100%
 octopi-0.9.0-24-x86_64                                                              1001.4 KiB  1032 KiB/s 00:01 [####################################################################] 100%
 octopi-notifier-frameworks-0.9.0-24-x86_64                                           570.6 KiB  1097 KiB/s 00:01 [####################################################################] 100%
(6/6) checking keys in keyring        [####################################################################] 100%
(6/6) checking package integrity        [####################################################################] 100%
(6/6) loading package files        [####################################################################] 100%
(6/6) checking for file conflicts        [####################################################################] 100%
(6/6) checking available disk space        [####################################################################] 100%
(1/6) installing alpm-octopi-utils        [####################################################################] 100%
(2/6) installing qtermwidget        [####################################################################] 100%
(3/6) installing pkgfile        [####################################################################] 100%
==> Run 'pkgfile --update' to initialize the database
(4/6) installing expac        [####################################################################] 100%
(5/6) installing octopi        [####################################################################] 100%
Optional dependencies for octopi
    gist: for SysInfo report
    pacaur: for AUR support
    trizen: for AUR support
    yay: for AUR support
    octopi-notifier-qt5: for notifications
    octopi-notifier-frameworks: for notifications with Knotifications support [pending]
    pacmanlogviewer: to view pacman log files
(6/6) installing octopi-notifier-frameworks        [####################################################################] 100%
I ran lsof -c octopi, forced another quit, removed two temporary files (the first of which was explicitly a lockfile, the second was a stream), reopened Octopi, no better.
Re-ran lsof -c octopi, forced another quit, removed two more recent temporary files from the same path:
[momh167-gjp4-virtualbox-manjaro ~]# rm /tmp/qtsingleapp-Octopi-1d88-3e8-lockfile
– then restarted the OS.
Success!
Thinking back to the original symptoms … the VirtualBox guest in which I run Manjaro was unused for maybe a few weeks. Expecting updates to be applicable, I vaguely recall being surprised by the absence of the icon for octopi-notifier … then manually starting Octopi and running a check for updates. It responded but gave an unexpected response (I can’t recall what, exactly) … that’s probably when I first forced a quit. I was warned against doing so but I proceeded, thinking that no harm would come.
In retrospect, I should have thought of lock files before anything else.
