Fish
December 31, 2021, 12:48pm
1
Hi,
I’m using the newest version of Manjaro Mate on my Laptop and my Desktop Computer. For around two months I encounter a problem: While using Skype, Zoom or other browser based conference programs, there is occasionally no sound or my voice turns into chipmunk voice. Usually, I have to restart the program to get it working or worse, I need to reboot.
This problem happens on both, my Desktop Computer and Laptop, where different hardware is used. Without changing any configurations, it gets randomly ‘fixed’, but the problem occurs at the next conference again.
Please tell us a bit more about your system:
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to this tutorial, so if you’re reading this in response to a question, please click the link above this text to bring you to the full and unabridged text of the tutorial…
Fish
December 31, 2021, 8:54pm
3
I tried it with Kernel 5.15, 5.10 and 5.4. I still encounter the same problems.
This would be the output from my desktop computer, hope it helps:
Kernel: 5.4.164-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a0d8f633-4d02-4ce1-99e7-6d006db82eab rw quiet
cryptdevice=UUID=bf087e11-54c1-4d67-b6ce-33c9d3db4444:luks-bf087e11-54c1-4d67-b6ce-33c9d3db4444
root=/dev/mapper/luks-bf087e11-54c1-4d67-b6ce-33c9d3db4444
resume=/dev/mapper/luks-bf087e11-54c1-4d67-b6ce-33c9d3db4444 apparmor=1
Desktop: MATE 1.26.0 info: mate-panel wm: marco 1.26.0 vt: 7
Type: Desktop Mobo: ASUSTeK model: M5A78L-M/USB3 v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 2101
date: 12/02/2014
RAM: total: 7.51 GiB used: 5.13 GiB (68.3%)
RAM Report:
Info: model: AMD FX-6300 bits: 64 type: MT MCP arch: Piledriver
family: 0x15 (21) model-id: 2 stepping: 0 microcode: 0x6000852
Topology: cpus: 1x cores: 6 smt: enabled cache: L1: 288 KiB
desc: d-6x16 KiB; i-3x64 KiB L2: 6 MiB desc: 3x2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3351 high: 3937 min/max: 1400/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3067 2: 1647
3: 3937 4: 3923 5: 3683 6: 3852 bogomips: 42204
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
disabled, RSB filling
Device-1: AMD RS780L [Radeon 3000] vendor: ASUSTeK driver: radeon v: kernel
bus-ID: 01:05.0 chip-ID: 1002:9616 class-ID: 0300
Device-2: Logitech Webcam Pro 9000 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 2-2:2 chip-ID: 046d:0809
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: marco v: 1.26.0 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9")
s-diag: 523mm (20.6")
Monitor-1: DVI-0 res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.7x11.7") diag: 559mm (22")
OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 5.4.164-1-MANJARO LLVM 13.0.0)
v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK M4A785TD driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD RS780 HDMI Audio [Radeon 3000/3100 / HD 3200/3300]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:05.1
chip-ID: 1002:960f class-ID: 0403
Device-3: Logitech Webcam Pro 9000 type: USB
Sound Server-1: ALSA v: k5.4.164-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: ASUSTeK P8 series driver: r8169 v: kernel port: e800 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: luks-bf087e11-54c1-4d67-b6ce-33c9d3db4444 maj-min: 254:0
type: LUKS dm: dm-0 size: 945.06 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 945.06 GiB
Device-2: luks-6bb6e9c8-c377-4b55-9316-ab7a4906480d maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: sda2 maj-min: 8:2 size: 8.8 GiB
Local Storage: total: 953.87 GiB used: 395.2 GiB (41.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 3A0
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS30 rev: 1.01
dev-links: cdrom
Features: speed: 40 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 945.06 GiB size: 929.23 GiB (98.32%)
used: 395.18 GiB (42.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-bf087e11-54c1-4d67-b6ce-33c9d3db4444 label: N/A
uuid: a0d8f633-4d02-4ce1-99e7-6d006db82eab
ID-1: swap-1 type: partition size: 8.8 GiB used: 19.2 MiB (0.2%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-6bb6e9c8-c377-4b55-9316-ab7a4906480d label: N/A
uuid: cc27866b-d9a3-492a-8cc6-480777a6b3f7
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 2-2:2 info: Logitech Webcam Pro 9000 type: Video,Audio
power: 500mA chip-ID: 046d:0809 class-ID: 0102 serial: <filter>
Hub-3: 3-0:1 info: Full speed or root hub ports: 6 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-5: 5-0:1 info: Full speed or root hub ports: 3 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-6: 6-0:1 info: Full speed or root hub ports: 3 rev: 1.1 speed: 12 Mb/s
Device-1: 6-3:2 info: Areson Corp 2.4G Wireless Receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 25a7:fa10 class-ID: 0301
Hub-7: 7-0:1 info: Full speed or root hub ports: 3 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: SiGma Micro USB Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1c4f:0043 class-ID: 0300
Hub-8: 8-0:1 info: Full speed or root hub ports: 3 rev: 1.1 speed: 12 Mb/s
Hub-9: 9-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 68.0 C mobo: 47.0 C
Fan Speeds (RPM): cpu: 2743 case-1: 0
Power: 12v: 12.03 5v: N/A 3.3v: 3.34 vbat: N/A
Processes: 328 Uptime: 7h 30m wakeups: 0 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 2438
pacman: 2423 lib: 500 snap: 15 Shell: Bash v: 5.1.12
running-in: mate-terminal inxi: 3.3.11
