Obs studio wont launch
I have it installed but when i click on it nothing happens how do i fix?
Open it from terminal and share the error you get. Nobody can guess what issue is on your machine. Also share from terminal
inxi -Faz
inxi -faz shown with
  Kernel: 6.1.21-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=d3172992-6074-45f2-a6db-1ffe06550750 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Alienware product: Alienware Aurora Ryzen Edition
    v: 2.3.3 serial: <superuser required> Chassis: type: 3
  Mobo: Alienware model: 0NWN7M v: A00 serial: <superuser required>
    UEFI: Alienware v: 2.3.3 date: 11/15/2022
  Info: model: AMD Ryzen 5 3500 bits: 64 type: MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 2632 high: 3589 min/max: 2200/4120 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2196 2: 3589
    3: 2195 4: 3562 5: 2053 6: 2200 bogomips: 43137
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Dell driver: nvidia
    v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-03) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.0
    chip-ID: 10de:1f82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x403mm (27.83x15.87")
    s-diag: 814mm (32.04")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 38
    size: 1280x720mm (50.39x28.35") diag: 1469mm (57.82") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce GTX
    1650/PCIe/SSE2 direct-render: Yes
  Device-1: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0b:00.1
    chip-ID: 10de:10fa class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.4
    chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.1.21-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-3: PipeWire v: 0.3.67 status: off tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
  Device-1: Realtek driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:2600 class-ID: 0200
  Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 05:00.0 chip-ID: 168c:003e class-ID: 0280
  IF: wlp5s0 state: up mac: <filter>
  Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-9:3
    chip-ID: 0cf3:e007 class-ID: e001
  Hardware-1: Advanced Micro Devices [AMD] Device driver: N/A v: N/A port: N/A
    bus-ID: 02:00.1 chip-ID: 1022:43bd rev: N/A class-ID: 0104
  Local Storage: total: 238.47 GiB used: 135.39 GiB (56.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEMKF256G8 NVMe
    256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 7004
    temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 135.39 GiB (58.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 57.1 C mobo: N/A
  Processes: 246 Uptime: 8m wakeups: 0 Memory: 15.55 GiB
  used: 4.81 GiB (31.0%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1181
  pm: pacman pkgs: 1169 libs: 392 tools: pamac pm: flatpak pkgs: 3 pm: snap
  pkgs: 9 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
and i couldnt find a way to open obs from terminal
You simply type obs in terminal and pres Enter
my bad still new to linux
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/en-GB.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-GB.ini
info: Using preferred locale 'en-GB'
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: AMD Ryzen 5 3500 6-Core Processor
info: CPU Speed: 4092.021MHz
info: Physical Cores: 6, Logical Cores: 6
info: Physical Memory: 15926MB Total, 172MB Free
info: Kernel Version: Linux 6.1.21-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.4.3 (runtime), 6.4.2 (compiled)
info: Portable mode: false
qt.core.qmetaobject.connectslotsbyname: QMetaObject::connectSlotsByName: No matching signal for on_tbar_position_valueChanged(int)
info: OBS 29.0.2-2 (linux)
info: ---------------------------------
info: audio settings reset:
	samples per sec: 48000
	speakers:        2
	max buffering:   960 milliseconds
	buffering type:  dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1650/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 530.41.03, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
	base resolution:   1920x1080
	output resolution: 1280x720
	downscale filter:  Bicubic
	fps:               30/1
	format:            NV12
	YUV mode:          Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: cannot open shared object file: No such file or directory
warning: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
warning: Failed to load 'en-GB' text for module: 'frontend-tools.so'
warning: Failed to load 'en-GB' text for module: 'linux-alsa.so'
warning: Failed to load 'en-GB' text for module: 'linux-capture.so'
warning: Failed to load 'en-GB' text for module: 'linux-jack.so'
warning: Failed to load 'en-GB' text for module: 'linux-pipewire.so'
info: [pipewire] No captures available
warning: Failed to load 'en-GB' text for module: 'linux-pulseaudio.so'
warning: v4l2loopback not installed, virtual camera disabled
info: NVENC supported
Segmentation fault (core dumped)
I suggest to install manjaro-pipewire package and reboot, then test again.
done that, clicking on obs studio wont work and when i ran it from terminal it said this
info: Using EGL/X11
info: CPU Speed: 2049.528MHz
info: Physical Memory: 15926MB Total, 14383MB Free
	speakers:        2
	fps:               30/1
	format:            NV12
Ok, my last guess. Install nvidia-vaapi-driver to replace the libva-vdpau-driver. But since is an AUR package, let’s make sure things are properly set. From terminal run:
sudo pacman -Syu base-devel --needed
then run:
pamac build nvidia-vaapi-driver-git
It will ask for reboot. Test after that the OBS.
i tried that and it didnt work, but at the end of the second command it shown with this error
Checking keyring… [1/1]
Checking integrity… [1/1]
Loading package files… [1/1]
Checking file conflicts… [1/1]
Error: Failed to commit transaction:
conflicting files:
  • nvidia-vaapi-driver-git: /usr/lib/dri/nvidia_drv_video.so already exists in filesystem (owned by libva-vdpau-driver)
Remove it first
sudo pacman -R libva-vdpau-driver
then do the build.
This has worked and i can now use obs. Thanks so much for the help
