I installed OBS via the gui (and pacman) and when I try and run OBS it doesn’t launch and outputs this in the log, if you need any other info just ask
8:49:22.368: Window System: X11.0, Vendor: The X. Org Foundation, Version: 1.21.1
18:49:22.368: Qt Version: 6.5.1 (runtime), 6.5.1 (compiled)
18:49:22.368: Portable mode: false
18:49:22.396: OBS 29.1.3-1 (linux)
18:49:22.396: ---------------------------------
18:49:22.396: audio settings reset:
18:49:22.396: samples per sec: 48000
18:49:22.396: speakers: 2
18:49:22.396: max buffering: 960 milliseconds
18:49:22.396: buffering type: dynamically increasing
18:49:22.398: ---------------------------------
18:49:22.398: Initializing OpenGL...
18:49:22.438: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1650/PCIe/SSE2
18:49:22.438: OpenGL loaded successfully, version 3.3.0 NVIDIA 535.54.03, shading language 3.30 NVIDIA via Cg compiler
18:49:22.458: ---------------------------------
18:49:22.458: video settings reset:
18:49:22.458: base resolution: 1920x1080
18:49:22.458: output resolution: 1280x720
18:49:22.458: downscale filter: Bicubic
18:49:22.458: fps: 30/1
18:49:22.458: format: NV12
18:49:22.458: YUV mode: Rec. 709/Partial
18:49:22.459: NV12 texture support not available
18:49:22.459: P010 texture support not available
18:49:22.459: Audio monitoring device:
18:49:22.459: name: Default
18:49:22.459: id: default
18:49:22.459: ---------------------------------
18:49:22.465: Failed to load 'en-US' text for module: 'decklink-captions.so'
18:49:22.473: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
18:49:22.480: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
18:49:22.480: Failed to initialize module 'decklink.so'
18:49:22.602: [pipewire] Available captures:
18:49:22.602: [pipewire] - Desktop capture
18:49:22.602: [pipewire] - Window capture
18:49:22.621: v4l2loopback not installed, virtual camera disabled
18:49:22.638: NVENC supported
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
