Hi everyone! Recently I have made the switch from windows to Linux Manjaro and I have noticed that my download speed is extremely slow. Prior to the switch, I had down speeds of up to 35MBs/s and now it wont go beyond 2MBs/s (best case scenario, usually its a few KBs).
This goes for ALL kinds of downloads (updates, games, apps, etc.). I tried the sudo pacman-mirrors commands several times to no avail.
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a7b75c7b-510b-40c2-8cb6-5244fe76df28 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 80WK v: Lenovo Y520-15IKBN
serial: <superuser required> Chassis: type: 10 v: Lenovo Y520-15IKBN
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: 4KCN30WW date: 08/31/2017
ID-1: BAT0 charge: 42.1 Wh (100.0%) condition: 42.1/45.0 Wh (93.6%)
volts: 12.5 min: 11.2 model: SANYO L14S3P24 type: Li-poly serial: <filter>
status: Full
RAM: total: 15.51 GiB used: 3.29 GiB (21.2%)
Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: EA
cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB bogomips: 20004
Speed: 1492 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1200 2: 1203
3: 1196 4: 1197
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts erms est f16c flush_l1d fma
fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 5986:06b0 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 03:00.0
chip-ID: 168c:003e class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 1-11:4 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 368.58 GiB (31.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 57MS4109 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: LCM2 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 16.38 GiB (7.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a7b75c7b-510b-40c2-8cb6-5244fe76df28
label: NO_LABEL uuid: CD98-0583
ID-3: /run/media/f3ll/Data raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 352.2 GiB (37.8%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: F4ACF66EACF62B2E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-6:3 info: Acer EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:06b0
Device-3: 1-11:4 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0cf3:e300 class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 33.0 C pch: 35.5 C mobo: N/A
Processes: 220 Uptime: 2h 22m wakeups: 1 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1283 lib: 388
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.09
Could someone help me?
Thank you!
