Hi,
I tried to solve it on my own for a while but it seems I need some help. I don’t know what exactly caused this but reinstalling does not fix the issue. Here what I get when I try to run it:
nvtop: symbol lookup error: nvtop: undefined symbol: nvmlDeviceGetGraphicsRunningProcesses_v2
I use the driver version 440.100
with Manjaro bspwm.
cscs
November 16, 2020, 2:47am
2
When asking questions in the forum it is most helpful to everyone for you to provide some basic information.
When sharing information to either give or receive assistance, please be aware of the following:
1 ) In almost every situation not explicitly involving appearance, Text is preferred over Images.
2 ) When providing code or text output, please format it so the content is easy to read.
How to Format “Code” in the Forum
Its easy to make your text and code easy on the eyes
Firs…
(notice the first command - inxi -Fazy
Thanks, didn’t know about inxi
command. Here is the output:
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=ccb46516-3a3c-4c19-b622-21b6cddef426 rw quiet udev.log_priority=3
Desktop: bspwm 0.9.7-2-g342c2e3 info: lemonbar dm: LightDM 1.30.0
Distro: Manjaro Linux
Type: Desktop System: HP product: HP Pavilion Gaming Desktop 690-0xxx v: N/A
serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: HP model: 843B v: 00 serial: <filter> UEFI: AMI v: F.31
date: 05/27/2019
Info: 6-Core model: Intel Core i5-9400F bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: A (10) microcode: D6
L2 cache: 9216 KiB
bogomips: 34814
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Type: l1tf
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Hewlett-Packard
driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:2182
Display: x11 server: X.org 1.20.9 compositor: picom v: git-dac85
driver: nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 1660 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:1aeb
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus ID: 1-9:12 chip ID: 046d:082d
serial: <filter>
Device-4: Logitech G430 Surround Sound Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:4 chip ID: 046d:0a4d
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A port: 4000 bus ID: 02:00.0
chip ID: 10ec:c821
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
chip ID: 10ec:8168
Local Storage: total: 4.31 TiB used: 3.38 TiB (78.4%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 80002C00 scheme: GPT
ID-2: /dev/sda vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb model: SSD 480GB size: 447.13 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 7A scheme: MBR
ID-1: / raw size: 445.13 GiB size: 437.14 GiB (98.21%)
used: 365.04 GiB (83.5%) fs: ext4 dev: /dev/sdb2
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb1
System Temperatures: cpu: 41.0 C mobo: 27.8 C gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 43%
Processes: 223 Uptime: 1h 07m Memory: 31.23 GiB used: 1.77 GiB (5.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1235 lib: 410 Shell: Zsh v: 5.8 running in: server inxi: 3.1.08
nvtop
requires the 455xx
drivers and modules.
Weird, it was working fine until recently. I updated the driver to 455xx and it’s working again.
Though updating process was kinda painful. mhwd
or Manjaro-Settings-Manager
couldn’t remove 440xx
because of dependencies. They also couldn’t install 455xx
because of the conflict with 440xx
. So I force uninstall 440xx
, broke the system, had to login to tty
to install 455xx
with mhwd -i pci video-nvidia-455xx
. I think everything works fine now.
Thanks for the replies.
system
Closed
December 1, 2020, 6:15pm
6
