Only problem there is that it doesn’t work. When I set nvidia-settings --assign=CurrentMetaMode="1920x1080_75", my monitor restarts and the OSD says that it’s now running at 75Hz. However, after a reboot it reverts back to 60Hz. Also GWE OC and fan control never works, still asks for the coolbits to be set to 8.
My assumption is that even though xorg.conf is set correctly, it’s not used. What can I do to make this configuration loaded at boot?
Manjaro uses MHWD that is not using xorg.conf.
Use the correct file then, remove yours. To modify with your custom lines, check /etc/X11/mhwd.d/nvidia.conf
To make sure all is fine, run this command after you modify it: sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf
Ok, I modified /etc/X11/mhwd.d/nvidia.conf, now it contains the coolbits and 75Hz option. However after running sudo mhwd-gpu --setmod nvidia --setxorg /etc/X11/mhwd.d/nvidia.conf, nothing happens:
Review this line and add the connector to it. For example: Option "metamodes" "DVI-I-1:1920x1080_75 +0+0"
Needs to correspond the port that monitor is connected …
All Coolbits options should be under Section "Device", NOTSection "Screen" as you have it now … Change that too. To take effect you need to reboot. No need to run that command again.
You can remove the NoLogo line and maybe you have to use "Coolbits" "12" … Not sure about the refresh rate issue tho. Did you set 75Hz in Monitor Settings of your DE?
Interesting. Maybe go with "Coolbits" "28" … but what is funny, on my end i just tested and GWE works and no coolbits in my config, and i get no notification as i should have one or the other.
